C.A.R.
Everything posted by C.A.R.
  1. I agree with Ash. Real safety issue with the Alum. threaded collars...
  2. Hahahaha I love to see that...!
  3. Cool. I'm pleased to hear it
  4. ETA till completion?
  5. Go get a PBR HD Clutch kit from Bursons - $180 last time I bought one IIRC. No difference in pedal pressure or harshness in use, yet will last quite a bit longer with more clamping force. FWIW I always get a Clutch Kit (new Pressure plate, Driven plate & T/O bearing) just for reliability sake.
  6. Your Wemen! How much for your Wemen?! Looks good Hoke. Perfect upgrade for a high powered L6 Zed.
  7. Front is low enough for road use, rear could go down another inch IMHO. I've got some spare front strut top mounts that I'll be fitting to the rear of my 2+2 this week. That should give everyone an idea of how much it drops them by.
  8. Strange, most of my bushes are SuperPro
  9. Comon Dave/Ben post up the new Pics!!!
  10. http://www.fulcrumsuspensions.com/superpro.html Not as harsh/noisy as Nolathane but not as soft as rubber
  11. Having a cage is fine as long as it doesn't impinge on anything.
  12. I'm glad we weren't spooning overnight, on the Phillip Island Cruise Sulio...
  13. This is true (rather embarrassingly!). I didn't pick it until Simon told me...
  14. Rust really isn't an issue, unless it's terminal. There's plenty of rust replacement panels available. Just take a magnet with you. Yes it will. I'll be running a GT30r with a .82 housing on my L28et. Also, may I suggest you brush up on your information regarding these cars. Theres many books about them & even more info on the net Oh, and if you start posting in 'hectic langwige' such as Turbz & Zorst & Fulli sikk Br000000!!!, you may well find your credibility plummet around here... Catch my drift? BTW, Welcome to the forum
  15. Ash & Dimitri, I was informed about that valve years ago when I 'was' going start on the R31 rear conversion. I don't believe many people know about it - all the US conversions I've read up on don't mention it either Simon, with the amount of trouble you'd go to fit fit the Z32/R32/R33 calipers, I think I'd rather go Wilwood... I may however do a 'Hilux/Landcruiser + S13 rotor' Tutorial one day...
  16. Here here, Dimitri!
  17. Step 5 (Nearly done!): Remove the REAR line on the master cylinder. Undo the large 17mm nut in the M/C & remove. With a small ‘Eazy-out’ remove the flared pipe seat, behind this will be the little plastic 'Residual Pressure Valve' & spring. Discard the plastic valve & spring. Refit the flared pipe seat back into the M/C. Screw the large nut back in, then screw the line back in. Then bleed the M/C at the union, followed by the rear calipers. Bolt the road wheels back on & lower the car back down & take for a test drive! (Removing the Residual Pressure Valve eliminates the rear calipers locking on when they heat up). More information & pics here: http://ozdat.com/forum/viewtopic.php?t=1257&start=15 Note: If you have some trouble getting the alum. caliper brackets to bolt up, a light sand with a flap wheel or sanding disc to the bracket should give you enough clearance to have them bolting up nicely. If you have any more trouble with this conversion, please email me at: Lurch (at) Ozdat.com – but don’t expect a speedy reply!
  18. Step 3 (it gets easier from here): Now you should now have a nice bare hub. Using the M10 bolts, bolt the Alum. caliper bracket onto the forward edge of the hub. It is recommended that you ‘Loctite’ the bolts in place (pic9) Now, slide the 280ZX Disc Rotor over the studs on the hub (the road wheel holds the disc in place). Step 4 (Getting there): Unbolt the upper handbrake cable mount (close to the diff, under the floor) (pic10). Fit the angle bracket to the body, and then bolt the rubber mount that the cable goes through to the top side of the bracket (pic11). Next, bolt on the caliper with the bleed nipple facing UPWARDS using the other M10 bolts BEHIND the ‘ears’ of the caliper brackets. Slide the handbrake cable through the outer holder. Using the old spring clip; push this into place to hold the cable. Secure the clip in place with a couple of cable ties OR tech screw the clip to the mount. (I am still working on a better solution to these). Then fit the end of the cable to the caliper leaver with the old pin & split pin (pic12). Secure the cable to the lower wishbone with a LOOSELY tied cable tie so as not to distort the cable too much (pic13). Next, using the shortened bundy brake lines, fit these to the calipers, and then screw them into the original rubber hoses (Pic2).
  19. Step 1: Jack up car. Place car securely on jack stands. Remove roads wheels. Remove brake drums & then disassemble the rear brakes. Clamp a rubber brake line ‘pincher’ onto the rubber brake line to prevent any fluid loss. Also remove the handbrake cable & brake line (pics 3a & 3b). Withdraw the slave cylinder. (Pic3) DO NOT THROW ANYTHING AWAY! Step 2 (the worst part of the conversion): Undo the 4 14mm headed bolts that secure the backing plate to the hub. Give the B/P a tap forward with a hammer to ‘pop’ it off its step on the hub (pic4) Now, with the B/P loose, cut down to the centre of the B/P with the 1mm cutting disc on the angle-grinder. Do this at opposite sides of the B/P. Cut down as far as you can WITHOUT cutting into the hub or anything else. Next, with your centre punch, punch a centre pop a few mm below the end of your cut (pic5) Drill the hole thru the backing plate with an 8mm drill bit (pic6). Once through, drill ‘downwards’ towards the hub until you’ve got 2 continuous ‘splits’ in the backing plate – TAKE YOUR TIME! (Pic 7 & 8 ). (The backing plate is about 3mm thick & of fairly soft steel, you shouldn’t have any trouble cutting & drilling the backing plates in halves this way – just be careful).
  20. This article is a step-by-step guide to mounting the rear calipers & rotors from a S1 280ZX onto the rear of your 240/260Z. You should be able to complete this conversion in a weekend PROVIDING you have the required parts & tools. It is also recommended that you recondition the calipers prior to use, fit new pads & rotors. Please note, unless you want to go to the HUGE trouble of removing your rear hub, it is easier to simply cut the backing plates off. Be aware, once you have removed the backing plates it’s very hard to return to drums… This conversion will also fit under most 14” rims. Items you’ll need: Caliper brackets to mount the 280ZX calipers (available here: http://www.viczcar.com/forum/index.php/topic,1861.0.html ) 280ZX Calipers & the original 8 mounting bolts & spring washers. (or you can buy new M10, 30mm long bolts & washers). 280ZX Disc Rotors. 2 M8 bolts with nuts & washers. 2 handbrake cable mounting brackets (see below) Old ‘bundy’ brake lines from the 280ZX shortened to suit or, Custom braided brake lines. Tools: Power drill. Drill bits (various sizes). Angle grinder with 1mm cutting disc. Metric spanner set. Pliers . Hammer. Centre punch. Cold chisel. PPE: Goggles or safety glasses Earplugs or ear muffs. Gloves. Before you start: You need make up 2 brackets for the handbrake cable. Cut 2 pieces of 50x50x3 angle (Alum or steal) 50mm long. Drill 8mm hole in each side in the centre (Pic1). Next, get the old 280ZX bundy brake line shortened to around 100mm long by a brake shop with a 90deg turn at one end (Pic2).
  21. C.A.R.
    No caption
    Your Shed is looking slightly cleaner then the last time I was there, Ash :-P Looking damn goo though mate! :-D
  22. Need pics mate. Too hard to diagnose without seeing the extent of the rust.
  23. No. '100mm Backspace' = The distance from the mounting face to the outside of the inside rim (approx).
  24. Craig. CRAIG!!! Come in Craig... Also, can you please fill in your location 'Matsdat'. It makes it much easier to answer your questions when we know your geological location
