Dry or wet weight David?
Being a 240z they are lighter than the 260’s and that iron L6 being replaced by alloy would also help
Ive got 35kg in the ladder chassis, will be another 8kg in those rails, lpg donut tank a good 5kg extra the diff will have another 3kg extra, AMG seats another 10kg, planned rear inner interior mods and reo probably 10kg
Thats 70kg just there on top of the original 1,100 kg 260 wet weight
Semi dry or wet depends on how you look at it....glass half full? 1080 kg was the weight with what ever was in the fuel tank which wasn't much so call it dry.
M3 engine is still an iron block. Internets says that M3 engine is only a few kg's heavier than L 6, but I've got R200, and Skyline brakes which are much heavier so STD 240Z weight of 1045 plus my add ons makes 1080 seem spot on.
Notched out the roll bar area and added and RHS section for streangth due to its now dog leg shape
The front graft welded up brilliantly and as the new rail section is securely welded to the remains of the lower torsion rod mount I don’t think I will have to plate it with a gusset to reinforce it, it’s now purely more of an asthetic section.
Still needs finishing welds which I’ll do later. Now onto the second rail and removal of the remaining floor pan.
Happy days.
Rail #2 underway
Removed drivers floor pan, de-spotted and cleared all the overlap metal to adjoining sill, front firewall and rear bulkhead
the remaining tunnel section with the reinforcement will also be removed and replaced along with a new horse shoe reinforcement.
Photos unfortunately don’t load in correct sequence
Progress on drivers side rail today with attention on the rear dog leg extension
All in all going well, checking the geometry, I ran a length across them both and then measured the distance from each sill, each side has a gap of 53mm and are squared and level.
Hopefully I will get the chance to finish this one off tomorrow before I move onto the floor pan and trans tunnel.
Posted (edited)
Great work John.
It’s a very strong platform to bolt the big banger to. Thumbs up.
Jeff
Edited by CBR Jeff
Good to see progress John. Are you going to cage the car as those rails will have no crumple factor?
Thanks Jeff
Yes should adequatodeal with the M112’s torque or a future addition of 2 more cylinders in the M156 AMG V8 which is identical as far as  transmission bolt pattern and engine mounts just a fraction longer
Thanks Jeff
Thanks Peter
Crumple points have to be added fore and aft on each side of the engine cross member still
No internal roll bars planned, but a reinforcing ladder brace between the two rear shock towers is in the plan
2nd rail fabricated
test fit of the Ladder chassis done to check clearances
angle grinder 1 John nil after a piece of metal hit me in the face
Z and John doing ok otherwise
3 hours ago, peter t said:
Awesome. New gen supa car with Z body.
Not a Supa car Peter
it will be quick but not a drag or track car
just after the driving experience
On 1/28/2019 at 11:08 PM, Sirpent said:
Thanks Jeff
Slowly, just pissed off I lost more than 2 hours due to the mig failure
26 years off the road...........
Pissed off about losing 2 hours! ;D
Good to see you back at it again John
Nice to be back Simon
Another day of fabrication removing the remaining tunnel section and fabricating a new cross support.
After centering all up I realized that the entire sections are not symmetrical and are off some 15mm to the passenger side, meaning the drivers foot well and gearshift position are 15mm more to the left.
All good, I’m having new custom pans cut, bent and pressed which should be ready this week.
Happt to report, no exploding cutting discs and flying metal this week.
John
Well that’s it for the weekend
Ran out of gas as I was finishing off the gussets in the rail floor pan cross member
Managed to weld in the ladder chassis pick up bolts, close the ends after reducing the deck height by 5mm and welding one gusset in
All in all, extremely happy with the progress96E1E695-8C6C-49C6-BC4A-BA40E82783E4.thumb.jpeg.d0b4dcad64a554441070e1f27163aceb.jpeg1A35F1BC-B726-4FA0-9D48-1F1861BF3A3A.thumb.jpeg.7d530d62ceb14bfe1ae57079129da133.jpeg
Well that’s the second rail in and blended front and rear into the body along with the (What I’m calling) the tunnel horse show with ladder chassis bolt points
Now for the pans which are almost ready to pick up along with some additional weld clean ups
cheers
John
Well that’s the second rail in and blended front and rear into the body along with the (What I’m calling) tunnel horse shoe with ladder chassis bolt points
cheers
John
Time on the rotisserie today making a new lock mechanism
 Cars upright now ready the pans
That’s all she wrote for this long weekend
Added some additional gussets at the horse shoe and sat the rare spares pan in just to get an idea how all will sit with the new pans on order and am satisfied all will line up exceptionally well
