LLN260Z Posted February 22, 2018 Posted February 22, 2018 Hey guys, I have searched the net, forums and the workshop manual on what hose or outlet goes where. I bought a set of early 240z su carbs and gave them to Wilson Carburetors in airport west to rebuild them. Before that I test fitted it to make sure I can everything covered before I get the su back. Originally car had holley 4160 fitted so some hoses and connections are all over the place. I took a photo of my su fitted and circled the parts I am unsure of. I also don't have the stock airbox so I was thinking of running individual air filters. If someone can tell me or link me a set that would go straight on would be great. 1. 2. 3. 4. 5. 6. (I think this is for coolant line, and there is another outlet on the right side which I think is coolant return line) RAP260 1 Quote
gilltech Posted February 22, 2018 Posted February 22, 2018 1. is for the crankcase breather, long pipe projecting out of upper LH side of motor, basic emissions 2. and 3. these connect to the airbox, or indivdual air cleaner bases if you go that way 4. connects across to your brake booster for vacuum, god knows what you currently have? 5. blanking plug - original, not used, leave as is 6. from memory is part of water circulation, it used to connect to the side of the thermostat housing IIRC Go online and download some photos from all angles of stock original 240Z engine bays and the above will make sense. Hope that helps. LLN260Z and gav240z 2 Quote
LLN260Z Posted February 22, 2018 Author Posted February 22, 2018 Brake booster should be easy got that hose. Water circulation makes sense now too. 1. Just get a hose from crankcase to the bar. What about the vacuum lines that goto the carbon canister and distributor advance? Quote
Administrators gav240z Posted February 22, 2018 Administrators Posted February 22, 2018 3. is for fuel vapour (it's a breather for the fuel float chamber) that goes into the orange airbox (which you're missing). Distributor advance connects to the left hand carb body (just in front of where the SU mounts to the insulator part of the manifold). You also appear to be missing your fuel rail. The Carbon Canister won't be used with these SU's since there is no emissions set up on the 240z's (AU market). Like there is with 260z's. LLN260Z 1 Quote
Administrators gav240z Posted February 22, 2018 Administrators Posted February 22, 2018 Member SpecialP3 http://www.viczcar.com/forum/user/101180-specialp3/ Has 1 of the best engine bay's going around for an AU market car. The problem with looking at North American cars is that they had additional emissions equipment (on their 240z's) that we didn't get. Refer to album images here. http://www.viczcar.com/forum/gallery/member/101180-specialp3/ LLN260Z 1 Quote
LLN260Z Posted February 22, 2018 Author Posted February 22, 2018 So helpful and clean. I have the fuel line that was clear for me. Been given to get cleaned. With 3, where can I connect it to? Also can I remove the carbon canister fully or will I have issues with registration? Quote
GTI-Z Posted February 22, 2018 Posted February 22, 2018 I wonder where the hose that is coming out of the thermostat housing is going to ? Quote
gilltech Posted February 22, 2018 Posted February 22, 2018 I wonder where the hose that is coming out of the thermostat housing is going to ? Just plug the water circulation system at the thermostat housing end with an aftermarket blanking plug if you can't find an automotive one, and remove the Tee in the heater hose at the other end, you don't need all that. Individual aftermarket air cleaners will generally come with a fitting on the back to connect those small carby hoses to, you can just about see where they would be in Gav's first photo. Or maybe better to get hold of a proper 240Z air cleaner, put everything back to stock, unless you like the resto-mod look. LLN260Z 1 Quote
LLN260Z Posted February 22, 2018 Author Posted February 22, 2018 (edited) I wonder where the hose that is coming out of the thermostat housing is going to ?In my pic or in general? In my pic its not connected to anything right now Where can I get those individual air filters from? Edited February 22, 2018 by LLN260Z Quote
gilltech Posted February 22, 2018 Posted February 22, 2018 I wonder where the hose that is coming out of the thermostat housing is going to ? In my pic or in general? In your pic. We can't see if it's connected to anything. I'm guessing probably not and the end of the hose is plugged? Anyway, you don't need the water circulation thru the base of the carbs (unless you're doing a correct restoration), so remove the hose fitting and install a blanking plug. Quote
LLN260Z Posted February 22, 2018 Author Posted February 22, 2018 In your pic. We can't see if it's connected to anything. I'm guessing probably not and the end of the hose is plugged? Anyway, you don't need the water circulation thru the base of the carbs (unless you're doing a correct restoration), so remove the hose fitting and install a blanking plug. It was connected to the base of the holley carb. So since it is there I will plumb it to the su carbs. If that doesnt work well will blank it. Will removing the carbon canister restrict me from getting the car passed through rwc? Quote
Administrators gav240z Posted February 22, 2018 Administrators Posted February 22, 2018 Given you have a 77 model 260z and not a 74 model 260z you may find "dodging emissions" a little more difficult. Having said that I'd be surprised. Was the Holley carb connected up to the carbon canister in any way? Quote
LLN260Z Posted February 22, 2018 Author Posted February 22, 2018 Only this vacuum like hose was connected to the canister from holley carb. The return fuel line from tank was also connected to the canister. Quote
Administrators gav240z Posted February 22, 2018 Administrators Posted February 22, 2018 I see, well a 74 model 260z had no canister as far as I recall. Example of a 74 260z 2+2 here with no canister in the engine bay. https://photos.app.goo.gl/yOt9AKZ4yXPkI2ti1 My 75 model 260z 2+2 had it though, but it was never hooked up (running British SU's - HS6's) but I never had an issue getting a roadworthy despite a plethora of hoses going to nowhere! I would say you'd be unlucky to get pulled up on it. https://www.quora.com/What-is-the-purpose-of-a-charcoal-canister 1/3rd of car emissions came from fuel evaporating out of the tank in the 1960’s. The canister was invented to collect these fumes and then pump them into the engine to burn off. The added bonus was that it allowed the tank to pressurize and stop varnish build up and further evaporation while locking out moisture. It increases the economy marginally, makes fuel systems last longer, and prevents a lot of smog. All with very simple plumbing. Perhaps someone with a stock looking engine bay could help post a photo of how the canister is plumbed up? Quote
jalexquijano Posted February 22, 2018 Posted February 22, 2018 3. is for fuel vapour (it's a breather for the fuel float chamber) that goes into the orange airbox (which you're missing). Distributor advance connects to the left hand carb body (just in front of where the SU mounts to the insulator part of the manifold). You also appear to be missing your fuel rail. The Carbon Canister won't be used with these SU's since there is no emissions set up on the 240z's (AU market). Like there is with 260z's. What a beautiful engine!!! Quote
gilltech Posted February 22, 2018 Posted February 22, 2018 What a beautiful engine!!! Sure is. And you can see in there that he's retained the water circulation system. But I disconnected and later removed the water circulation system on my '74 260 more than 3 decades ago after one of the hoses failed right on Xmas holidays when I needed the car, deciding it was potentially unreliable with so many hose and pipe connections involved, any one of which could leak. And never looked back with either the flat tops or round tops I installed later. The KISS principle for me. Quote
Administrators gav240z Posted February 23, 2018 Administrators Posted February 23, 2018 I actually prefer the look of Special3p's engine bay, I can't stand those K&N filters. The OEM airbox is superior and looks 100x better. LLN260Z, cracker and OdinZ 3 Quote
LLN260Z Posted April 3, 2018 Author Posted April 3, 2018 Wow last post was in Feb. so I finally got my su carbs back from a rebuild. 7weeks later and $1250(rebuild and hydroblast cost) I am keen to fit them tonight and see how it goes. Here is a photo of before and after. Quote
LLN260Z Posted April 3, 2018 Author Posted April 3, 2018 After RAP260, Yamahacam, gav240z and 1 other 4 Quote
Administrators gav240z Posted April 3, 2018 Administrators Posted April 3, 2018 Yellow passivate coating on those fasteners would make them look epic! Quote
LLN260Z Posted April 3, 2018 Author Posted April 3, 2018 I wish I can afford doing that right now. After spending $1800 on getting these su carbs and rebuilt is kind of making me regret not spending the extra $600 ish getting new triple webbers. If only I had known what the total rebuild cost would have been. How much is it get those parts electroplated roughly? Quote
Administrators gav240z Posted April 3, 2018 Administrators Posted April 3, 2018 I don't think the process is expensive, but making sure you don't lose any of the pieces and putting it back together.. Quote
RAP260 Posted April 3, 2018 Posted April 3, 2018 Looking really nice Did the rebuild cost include restoring the heat shield and manifold? I have just done the same thing as you . I just replaced my 4 barrel with SU. I ended up going with the Midel HS6 conversion. Seemed expensive for just the carbs and linkage, but was happy not to wait 7 weeks Quote
LLN260Z Posted April 3, 2018 Author Posted April 3, 2018 I don't think the process is expensive, but making sure you don't lose any of the pieces and putting it back together.. This is the reason why I gave it to the experts haha Looking really nice Did the rebuild cost include restoring the heat shield and manifold? I have just done the same thing as you . I just replaced my 4 barrel with SU. I ended up going with the Midel HS6 conversion. Seemed expensive for just the carbs and linkage, but was happy not to wait 7 weeks Yea I gave the complete set to them including fuel rails. 4 barrel felt so useless huh? 7week wait tested my patience a lot, hopefully no nasty surprises What air filters are you running? Quote
