daretobedifferent Posted August 31, 2017 Posted August 31, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent gav240z, KatoKid, Rickers and 1 other 4 Quote
Administrators gav240z Posted August 31, 2017 Administrators Posted August 31, 2017 I like the video but can hardly hear you? Maybe get a lapel mic for your next video? PS: That's a lot of work you have there! But probably no more than HS30 00051. Quote
Rickers Posted August 31, 2017 Posted August 31, 2017 This is great - thanks for sharing, I'll be following along! If you don't mind, I have a question... How did you decide where to cut the qtr/roof join? I'm under the impression that the join between the roof/qtr is hidden by lead, and well I've never worked with lead before so any advice on removal of the QTR would be great! cheers Quote
CBR Jeff Posted August 31, 2017 Posted August 31, 2017 Thanks Trung As Gav said it's a bit hard to hear you but a quite room and full volume fixed that. Great work so far and as they say no guts no glory. I'm looking forward to future instalments. Jeff Quote
gilltech Posted August 31, 2017 Posted August 31, 2017 Will be watching progress with interest. Good luck and keep it coming. Have you been able to source replacement quarter panels etc? I'll be interested to see how accurately the body shell can be realigned compared to the factory tolerance specs. Quote
daretobedifferent Posted August 31, 2017 Author Posted August 31, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent Rickers 1 Quote
Rickers Posted August 31, 2017 Posted August 31, 2017 Thanks for the feedback guys. ... @Rickers I cut the rear quarter off right before the window rail section, so unfortunately I didn't make the cut at the factory join. BUT I think I'll go for the cut at the lead join in the future and remove that piece as well. If you look at your rear hatch window rail section, you can actually see where the rear quarter ends. If you make a cut from that point onwards it'll be exactly where the lead join occurs, however you'll end up cutting a section of the window rail as well which I'm trying to avoid for now. I managed to import an entire rear RH section off a 240z from Japan (rear quarter still attached to strut tower and a part of the boot). I'll definitely keep you updated when I figure out the best technique. Thanks for the info! It'll make it much easier for me. Good luck with everything and I'm looking forward to the next video. cheers Quote
daretobedifferent Posted September 8, 2017 Author Posted September 8, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent gav240z and Ponyo240z 2 Quote
Brabham Posted September 9, 2017 Posted September 9, 2017 Looks like a good project, will be interesting to see it come together. The floors didn't look too bad in the video. You may want to see if the chassis can be straightened first before investing more time in it. Good luck with the build and the videos will help others in a similar situation. Cheers gav240z 1 Quote
daretobedifferent Posted September 9, 2017 Author Posted September 9, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent Quote
mossy Posted September 9, 2017 Posted September 9, 2017 Looks like a good project, will be interesting to see it come together. The floors didn't look too bad in the video. I was thinking the same thing, the passenger floor looks like it would have come up good after blasting, was it worse than it looked in the video? Quote
daretobedifferent Posted September 9, 2017 Author Posted September 9, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent mossy 1 Quote
Administrators gav240z Posted September 9, 2017 Administrators Posted September 9, 2017 Much better video quality this time, I could hear you! Rear of floor did look bad. I am hoping to salvage my floors. They are not too bad, a bit of panel beating and blasting might make them look decent again. Quote
gilltech Posted September 9, 2017 Posted September 9, 2017 Impressive work, following with interest. I haven't been able to source (or afford) any NOS panels or full rear quarter replacement sections Are there any such things as rear quarters available anywhere except from another car? Quote
Administrators gav240z Posted September 9, 2017 Administrators Posted September 9, 2017 Yes Niles got that passenger side 1/4 panel.. (in Switzerland) and I got this driver side 1 recently. Cost a small fortune, but the 1/4 panel on HS30 00051 has had a bit of a hit and needs many hours spent on it to put right so this seemed like a better idea. They do come up for sale, but not often! I managed to also get a NOS hood/bonnet recently. Well at least I think it is, will find out when I collect it soon! Ponyo240z 1 Quote
daretobedifferent Posted September 15, 2017 Author Posted September 15, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent CBR Jeff 1 Quote
CBR Jeff Posted September 16, 2017 Posted September 16, 2017 Couple of great videos Trung. Nice work. Just be sure to brace the shell as you pull things off. If you construct a jig as you remove structure you should be able to straighten or move parts back to the original location. Then as you replace the structure it will remain in the correct position. Have a look at George's 0019 build thread at some of the photos of the shell that Paul took when he was repairing it for some good guidance. Jeff Quote
daretobedifferent Posted September 16, 2017 Author Posted September 16, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent taylor and CBR Jeff 2 Quote
gilltech Posted September 16, 2017 Posted September 16, 2017 I managed to also get a NOS hood/bonnet recently. Well at least I think it is, will find out when I collect it soon! Was that the hood for sale by Datsun Parts recently? I was wondering if it is a repro and if so whether Chris might have tapped into a panel source somewhere. However, if it's a one-off NOS Nissan part he dug up then that sinks that hope. Quote
Administrators gav240z Posted September 16, 2017 Administrators Posted September 16, 2017 It was from Japan, before the reproductions that appeared on eBay, so I am hoping it's a Nissan OEM part! Also may have found a NOS passenger side rear 1/4 panel for an early 240Z... they are still out there! Quote
daretobedifferent Posted September 28, 2017 Author Posted September 28, 2017 (edited) -- Edited July 13, 2023 by daretobedifferent Rickers, HomeBuiltByJeff and CBR Jeff 3 Quote
CBR Jeff Posted September 28, 2017 Posted September 28, 2017 (edited) Nice Job Trung. Soon there is going to be nothing left of the original car. Keep going and It will be a beach buggy!!! Jeff Edited September 28, 2017 by CBR Jeff Quote
Administrators gav240z Posted September 28, 2017 Administrators Posted September 28, 2017 haha, yep certainly taking it down to it's bare bones..hope you like plug welding? Quote
