Hi Guys,
Me and my brother have been looking into some blasting options. Upon research we found out about "wet" sand blasting, results seem to be good by just using an attachment on a karcher see link-
http://www.justtools.com.au/prod4035.htm
Anyone have any experience using these, also most likely means there is no need for any heavy duty respirator as the silica particles wont travel due to being wet?
Benny
My father in law uses this all the time on his Hudson Chaises.It's very effective in removing the build up of stuff from the rail but won't recommend on thin metal as rips in to it.
Bruce
I have one of those attachments.
They work well but you do need a fairly high pressure unit. around 3000 psi
I just use ordinary builders sand that i sieve with a wooden frame with a piece of flywire attached.
You need to make sure the sand is fully dry or it can clog the nozzle
Hi Guys,
Benny
I thought so to...  ;)  This is the process... blast with either wet or dry... then sand the panel)raw) then lock it in with choice of primer/epoxy. I dont see a problem with it... seems to be much gentler on panels too seeing you dont have the heat. We do have the option of buying a 20Gallon pressured dry blaster aswell just looking at all options
Lurchie's got old faithful out again , ha ha
Water and bare steel are not each others friend.
even if you "lock" it in straight away.
Tears will be falling
even when sanding afterwards preparing the surface?
Benny at the end of the day its your car
You may get the paint off however you like.
Will whoever told you that this is a good way
To blast warranty your paint work?
I could bet my left nut it WILL rust.
Mate i don't even like wiping down a steel panel
With a damp cloth after de oxidine. But if you dont
It will be worse.
I personally would not blast wet.
Paul
  • 2 years later...
Hi Benny
Hope all is going well.
I was thinking of trying this as well - it been a while since you posted - did you ever try this? How did go ? Was there any rust problems that eventuated or any special treatment of after west blasting.
Thanks for any advice.
Cheers AK
Hi Guys,
Benny
What do you think is going to happen at all the seams, panel overlaps, crevices, pockets, inside rails & folded areas you can't access, when spraying wet sand around?
Also, high pressure will warp panels & take the tension out of the metal.
Don't use sand, wet or dry, period.
After the advice in this thread, I'd be surprised if anyone still wants to to this.
