Author Topic: V8Datto’s Early 240Z Build  (Read 9222 times)
Offline V8Datto
  • Registered User
Re: V8Datto’s Early 240Z Build
« Reply #60 on: April 11, 2011, 08:51:50 PM »
Sandblaster time. I like the sandblasters, it means progress
Because the car would be back at the sandblasters we only got them to do the minimum needed
Early HS30
If you didn't build it, it's not yours
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #61 on: April 12, 2011, 03:53:20 AM »
Looking good mate!
I've been informed this now has the rear 1/4's back on?
Offline V8Datto
  • Registered User
« Reply #62 on: April 12, 2011, 02:35:06 PM »
Yes the panel/rust repair work is 99% complete, these photos are from last year some time.
Early HS30
Offline V8Datto
  • Registered User
« Reply #63 on: June 05, 2011, 09:32:51 PM »
All the parts & panels were sand blasted/painted & ready to go back on, Time to start the reassembly.
Using screws I started reassembling everything into place before welding to make sure it all went back correctly
« Last Edit: June 05, 2011, 09:43:04 PM by V8Datto »
Early HS30
Offline V8Datto
  • Registered User
« Reply #64 on: June 05, 2011, 09:59:09 PM »
In a short amount of time I realized I was missing the full length L&R drip rails, Then I realized I hadn't see them since I removed them from the Z. A quick search and we found them hiding in the back of Robs shop full of holes.
Plenty of rust in this area, Rob made up all the new sections I then sandblasted and painted ready to go
Early HS30
Offline zzzzed
  • mick the zed freek
  • Registered User
« Reply #65 on: June 05, 2011, 10:10:10 PM »
awesome effort  ;D
meh
240z in the making
Offline KatoKid
  • Donating Member
  • Registered User
  • Location: South Mexico.... where the low lifes cant find me.
  • Not so New Member but not a Newbie either
« Reply #66 on: June 06, 2011, 04:27:24 AM »
Unbelievable!
Husaberg...its half a KTM
My Project: http://www.viczcar.com/forum/index.php/topic,6400.0.html
71 240Z #000728
77 260Z 2+2 Gone but not forgotten.
2012 Husaberg 570FE....giddy up!
Offline Sirpent
  • Donating Member
  • Registered User
  • John.O.
    • Sirpent Zed
« Reply #67 on: June 06, 2011, 06:48:20 AM »
Seriously sensational work, beyond what any one would reasonably expect !
RS30 #005067 Restoration
"Das Drehkraftmonster RS32 AMG"
Full pictorial at
http://www.facebook.com/sirpentz
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #68 on: June 06, 2011, 08:30:57 AM »
Quote
Well this is well and truly yours - again outstanding effort.
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline V8Datto
  • Registered User
« Reply #69 on: June 07, 2011, 09:45:31 AM »
Thanks, words of encouragement are very welcome.
Rear hatch reassembly
I quite enjoyed this, fairly easy and good to see it go back together.
After Rob welded all the supports back into the hatch I grinded, re-sandblasted and repainted
A bit of a stuff up on my part here, where the hatch skin folds over needs to be sealed so the epoxy primer was sandblasted off and por was applied
Hold together and slowly fold over the seam
Center will stay with the screws until it can be checked on the car, then Rob can do the final welds
« Last Edit: June 07, 2011, 10:01:08 AM by V8Datto »
Early HS30
Offline V8Datto
  • Registered User
« Reply #70 on: June 07, 2011, 10:00:02 AM »
Also if anyone is wondering why I'm not doing any of the main/fiddly welding it's because I have a problem with heating up the steel too much,
Under the car in the chassis was fine but on the top outside panels every weld pulls on the thin steel.
I just don't have the experience with the thin metal and would end up making more work
Early HS30
Offline Gareth. J.
  • Donating Member
  • Registered User
« Reply #71 on: June 07, 2011, 02:40:37 PM »
Great work Mossy, with all that POR15 I don't think you'll ever see rust again. This will be an awesome recreation once it's complete, shame they weren't done this way from the factory cause there'd be a whole lot more left.
Offline V8Datto
  • Registered User
« Reply #72 on: June 16, 2011, 08:02:23 PM »
So......
from this stage forward Rob took on most of the work, I helped along the way with fitting, measuring, grinding, sandblasting & painting etc, while Rob took care of fabrication and welding stuff
First thing to do was replace all the structural parts and then move on to the outside panels.
Iner wiper area done
Front supports
Rear end frame in place and welded
The next stage was to test fit all the panels, a lot of measuring, remeasuring and then remeasure again was needed here. Having 3-4 Z shells of different years next to us was a big advantage. No guessing required
Don't ask how many times we removed and refit these rear quarters to get them right. I seriously don't remember, it seemed to take forever
Early HS30
Offline Scoota G
  • R.O.E.
  • Donating Member
  • Registered User
  • Mark
« Reply #73 on: June 16, 2011, 08:23:36 PM »
Hmmmm True Grit.
Get Some !!!!
Technology costs a money and a money we don't got.
Offline zzzzed
  • Registered User
« Reply #74 on: June 16, 2011, 08:35:36 PM »
now thats ddedication ;D
meh
240z in the making
