Administrators gav240z Posted September 17, 2017 Administrators Posted September 17, 2017 Model: Nissan Fairlady Z-L (chassis code: S30-06569)Location: Melbourne (CBD area)Price and Payment Conditions: POA (but over $50k+ spent on modifications alone).Item Condition: ExcellentBody: Body was sandblasted and stripped back many years ago (bare metal restoration)Mechanical: Extensively modified L28 currently running low boost. You'd want to be careful before turning the wick up on this thing!Registration: YesEngineers Certificate: YesContact Details: Frank Mattesich (0438853416) Vehicle history: Chassis # S30-006569 would have been built in 1971. (HS30-H confirmed this). Purchased by an Illawarra BHP executive whilst stationed in Japan. The date of import to Australia is not exactly known but can be assumed that it was in 1971 as that is the date of first registration in Australia. The car is designated as Fairlady Z-L and is an early car with many of the early features. As a Fairlady Z-L it has the Rally Clock, Passenger foot rest, mesh grille, chrome trim headlight covers etc.. The car was sold to a Wollongong (NSW) person about 1980 who maintained the vehicle (including engine swap but no notification to RTA) until I purchased in 1999. Since purchasing the car I have extensively modified the car over the period. A note on original motor and matching no.'s for domestic market S30Z's. It would also have originally been fitted with an L20A, but as Japanese market cars don't have the engine number stamped on their ID plate, fitting another L20A with the right number range back into the car and the 71A gearbox would satisfy returning it to original if that was desired? The list of modifications is extensive and would easily exceed $50k+ on their own. The attached pages outline the modifications and relevant comments. Not all changes require Engineer Certification but never the less they are here for the record. Description New/ refurbished Non Standard Modifications/Additions/Comments ENGINE 3.Litre L28 Bored and stroked 8.3 Compression Ratio Head Refurbished N54 Ported and Heat treatment Valves New Standard reground , new seals and guides Valve springs New/NS Heavy duty Camshaft NEW/NS Turbo Cam Rocker arms Ref Reground Camshaft Sprocket New/NS Adjustable Rocker Cover NS Polished (Nissan Turbo) Block P79 Cleaned and de burred Oil Passages NS Cleaned and all passages freed Pistons New/NS Forged (SPS) Heat treated Crankshaft Ref/NS LD28 (Diesel) re ground straightened and balanced Connecting Rods New/NS AT H beam Bolts New/NS ARP Head and Rods Head gasket New/NS 1 mm steel Timing chain New Chain Tensioner New Oil Pan New/NS Solid cast aluminium/Slosh gates (7 Lt.) Harmonic Balancer New/NS Custom made / Degree Marked Bore NS Bored Engine Mounts New/NS Custom made INDUCTION Turbo New/NS Garret T3/4 larger intake Heat coated, Exhaust manifold Ref/NS Standard cast Turbo Heat coated, S/S Cover. 6 Thermo couples Waste gate New/NS External 35mm Turbosmart Outlet on “snail” BOV New/NS Turbosmart (Plumb back) Boost control New/NS Grreddy (.Regulator and Relief valves) Intercooler New/NS Custom Aluminium Air filter New/NS CUSTOM BOX FRESH AIR PCV system New/NS PCV Valves /Check Valves, Oil Separators Vacuum Pump GMZ ENGINE LUBRICATION Oil pump New/NS Heavy duty Turbo oil pump Oil cooler New/NS CUSTOM Oil pressure sender New Updated model Oil Filter S/S Cover COOLING SYSTEM Water pump New Radiator New/NS Aluminium Overflow New/NS Tank placed higher in motor Temp coupling New/NS New coupling Electric fans New/NS Twin 10 inch electric fans ECU controlled Plumbing New/Ns Rubber hoses replaced with s/s pipe or braid s/s hoses FUEL SYSTEM Throttle bodies New/NS 6 throttle bodies (EFI) Plenum New/NS Stainless Steel Custom built with trumpets internal (7 Litres plus) Injectors New/NS 6 Seimens type (700cc) on fuel rail Runners New/NS Extra length (300mm) Water injection New/NS Aquamist 5 Bar ( ECU injector Controlled) Throttle linkages New/NS S/S rod ends/bar and Sliding uni joint Fuel filter/s New/NS 1 pre pump 1 water filter separator Fuel pumps New/NS Carter lift pump/ Bosch high pressure sports Slosh tank New/NS S/S Rear mounted Fuel regulator New/NS Rising rate(Turbosmart) Fuel Lines New/NS S/S Braided Delivery and Return Fuel Tank New Cleaned and Modified for return pipes Sender calibrated ELECTRICAL ECU New/NS AUTRONIC SM3 Lights New/NS H4 Halogen Plus Driving & fog lights(New Globes Through out) Battery New Heavy duty Starter motor New Aftermarket HIGH GEAR Alternator New/NS 120 Amp Fuse block New Alternate placement WIPERS New/ NS Honda 2 speed S/S arms(Custom) IGNITION Distributor Less New/NS AUTRONIC 500R CDI 6 INDIVIDUAL COILS INSTRUMENTS Standard gauges Speedo, Tacho, Fuel level, Oil pressure, Amps, Water Temp, Clock ( Dials refurbished to WHITE FACE) Additional Gauges New/NS Air/Fuel Ratio New/NS Vac /Boost Internal (electric) Engine Bay (mechanical) New/NS Waste gate pressure New/NS Fuel Pressure Internal (electric) Engine Bay (mechanical) New/NS Exhaust Temp Collector and individual Cylinder New/NS Oil Temp New/NS Cylinder Head Temp New/NS Air - Fresh - Ex- Turbo - Intercooler New/NS Boost /Vac New/NS Fuel Temperature New/NS Volt Meter New/NS Fuel – Fuel Flow (In /out) - Fuel Used - Fuel Remaining (Litres) - Hours of Fuel (Remaining Hours) New/NS Boost setting Gauges CLUTCH New/NS Heavy Duty Large Ferrari( New thrust bearing) FLYWHEEL New/NS Heavy Duty Larger/ new bolts GEARBOX Ref/Ns 5 Speed Z 31 Mount New Standard PROP SHAFT New/NS Heavy Duty Balanced DIFFERENTIAL R200 3.7 New/NS LSD Torsen type (Quaife) New/NS Aluminium Finned (LSD) rear cover New/NS Seals /Bearings Mount/s New/NS For R200 Aluminium Moustache Bar FRONT AXLE All Powdercoated Bearings New Wheel Studs New/NS Longer Rod ends New Arms New/NS Adjustable Camber /toe/Track Compression rod New/NS TechnoToy Block New/NS Lift by 2” to correct Bump Stop Struts New/NS Shortened /Welded s**** Mech. Springs New/NS King 200lb Adjustable Sway Bar New Rubbers(synthetic) Cross member New/NS 260Z (Geometry lifted 20mm) Shocks New/NS Koni Adjustable Strut Bar New Cusco REAR AXLE Bearings New 260Z Stubs Studs New/NS Struts New/NS Shortened/Welded S**** Mech. Springs New/NS King 250lb Sway Bar New Rubbers(synthetic) Shocks New/NS Koni Adjustable Half shafts Z32 CVS (modified) Transverse link New/NS Adjustable Track/Camber/Toe ChromeMolly (ArizonerZ Powder coated) BRAKES FRONT Discs New/NS Z32 4 pot Calliper Ferrodo Shoes S/S Braided lines DBA Rotor Blank drilled 4 stud 298 mmx28mm ventilated/ drilled/ slotted REAR Discs New/NS Skyline/Z32 Ferodo Shoes S/S Braided Lines Handbrake Re aligned to suit Rear Brakes NS Precision Brakes Caliper Master Vac NS Refurbished increased capacity using existing body Brake Proportioning Valve New/NS Adjustable (Plumbed in Engine Bay) Check valve New New with new hoses WHEELS New/NS 16” Superlites TYRES New Yokohama A509 225/60/R14 STEERING Ref/NS 260Z Rack EZ ELECTRIC POWER STEERING EXHAUST New/NS 3 inch 316 stainless Mandrel Bent 1.5 inch 316 S/S Dump Pipe Heat Coated Muffler New/NS Stainless (Straight through) BODY Bare metal Panels /straightened/Fish oiled Paint New/NS 2 Pack ( Ford Royal Red) Seals New All seals rubbers replaced Badges New Under body Painted new plugs Bumpers Ref Re chromed Locks New Inspection Lids NS Vents stamped in Door Mechanisms Refurbished Seats New/NS Mitsibushi FTO. New Platforms fabricated Fully adjustable Spoilers New/NS Front and rear Trim New/NS Red Velour & leather Interior including Seats Glass New Front and Rear Replaced Head light Covers New/NS Mirrors New/NS Left /Right and Rear Seat Belts New To suit Seats Bolts/Screws New Hardware Replated Braces New/NS Front (CUSC O) & Rear Struts Grill New/NS S/S MESH (RaceMesh) AUDIO NS Kamemichi Radio head 6 Speakers 6 Stack CD Player Amplifier SECURITY Alarm NS General and immobiliser GENERAL Tuning Silverwater Automotive Services (David Alexander) Peter McDonnell PMC RACING Performance Power (Rear Wheel) 250 Kw @ 5500 436 Nm @4400 Boost Set at 1 Bar 0-60 0-100 Quarter mile Weight 1300 Kilos(Full Tank Distribution 50/50 Links: https://www.shannons.com.au/club/enthusiasts/fmattesich/garage/1971-datsun-fairlady-z-240z/ http://www.viczcar.com/forum/gallery/member/100255-erminio/ http://www.classiczcars.com/gallery/album/466-wipers-and-washer/ http://www.classiczcars.com/gallery/album/103-new-album/ Claude and OdinZ 2 Quote
dat240z Posted September 17, 2017 Posted September 17, 2017 Certainly done a lot of work and spent a stack of cash with some nice bits attached. Its a shame its trapped in the late 80's/90's styling era though. Will be interesting to see what it goes for. Quote
Administrators gav240z Posted September 17, 2017 Author Administrators Posted September 17, 2017 Certainly done a lot of work and spent a stack of cash with some nice bits attached. Its a shame its trapped in the late 80's/90's styling era though. Will be interesting to see what it goes for. Yes interior is a bit dated. Frank has had the car for many many years now and done a lot of work in that time. Fixing the interior would be a cheap exercise relatively speaking and whilst the paint is a bit modern for the era in my opinion. I think it's similar to the ZG maroon colour and with a few subtle changes could be made to look a bit more true JDM. Frank is now 70 years of age, he just isn't using it the same as he used to and wants to see it go to a good home and be cherished and maintained correctly. Not go to a young bloke who might not have much respect for the kind of power it makes and end up hurting themselves in it. Quote
44014 Posted September 17, 2017 Posted September 17, 2017 Its definitely got good bones, Once you get the interior done in some black vinyl or leather, Fix up the Ronald McDonald engine bay. Change the wheels and get rid of the chrome rimmed headlight covers, Kamaeri spoiler. You would have a fairly nice car. I would estimate around the 55k to 60k with the current market. Quote
ZED83 Posted September 18, 2017 Posted September 18, 2017 Think it needs more AN fittings lol Andrew_L26 1 Quote
Administrators gav240z Posted September 20, 2017 Author Administrators Posted September 20, 2017 Recent photos and videos of the car can be found here: https://drive.google.com/drive/folders/0B_tGt5V5rGDVOWJwMnVvSHkwYW8?usp=sharing 44014 1 Quote
44014 Posted September 20, 2017 Posted September 20, 2017 Where does the flux capacitor get mounted? Recent photos and videos of the car can be found here: https://drive.google.com/drive/folders/0B_tGt5V5rGDVOWJwMnVvSHkwYW8?usp=sharing Quote
Administrators gav240z Posted September 21, 2017 Author Administrators Posted September 21, 2017 Where does the flux capacitor get mounted? Anywhere you want really, but there might be space in the storage bins Quote
Scotty_Rah Posted September 26, 2017 Posted September 26, 2017 Think it needs more AN fittings lol Needs more red velvet too! Quote
OdinZ Posted January 30, 2018 Posted January 30, 2018 The more and more I look at this, the more I like it. Looks good in person too, even with the paint chipped in a few places. I would be surprised if this goes for less than $45k. Not many cars in that show room look better in my opinion, even with all of the chrome......well maybe the 930 Turbo Quote
Zedstar Posted February 2, 2018 Posted February 2, 2018 The more and more I look at this, the more I like it. Looks good in person too, even with the paint chipped in a few places. I would be surprised if this goes for less than $45k. Not many cars in that show room look better in my opinion, even with all of the chrome......well maybe the 930 Turbo Here's your chance! https://www.shannons.com.au/auctions/2018-shannons-melbourne-late-summer-classic-auction/UC8AKA6P68945VC0/ OdinZ 1 Quote
OdinZ Posted February 2, 2018 Posted February 2, 2018 Here's your chance! https://www.shannons.com.au/auctions/2018-shannons-melbourne-late-summer-classic-auction/UC8AKA6P68945VC0/ Haha, yes I know. That's where I went and saw it in person, in the Shannon's showroom, as much as I would love to buy this, I am sure it will get beyond my reach. Zedstar 1 Quote
Zedstar Posted February 2, 2018 Posted February 2, 2018 Haha, yes I know. That's where I went and saw it in person, in the Shannon's showroom, as much as I would love to buy this, I am sure it will get beyond my reach. Will be test of the market for modified vs original/stock Z's. Haven't seen a 240 with this amount of work done up for auction before. gav240z and OdinZ 2 Quote
Zedstar Posted February 20, 2018 Posted February 20, 2018 https://www.shannons.com.au/auctions/2018-shannons-melbourne-late-summer-classic-auction/UC8AKA6P68945VC0/ Reasonable result for highly modded Zed. gav240z 1 Quote
ERMINIO Posted May 6, 2021 Posted May 6, 2021 My Fairlady has gone back to Japan. The purchaser was Harry Kojima. Frank gav240z and OdinZ 2 Quote
Administrators gav240z Posted May 7, 2021 Author Administrators Posted May 7, 2021 36 minutes ago, ERMINIO said: My Fairlady has gone back to Japan. The purchaser was Harry Kojima. Frank Hey Frank, Hope you don't regret letting it go? More on Harry here. He's been around turbo Z's a while. Quote
ERMINIO Posted May 7, 2021 Posted May 7, 2021 not since i met with Harry after the sale. (really nice fellow) I'm glad that she will be looked after. I would have been not able to enjoy the fact i could not work on her . (Apartment building) I must say that modifying and testing was very satisfying. Only regret Should have asked for more Shannons wanted a quick sale. Should have hung out. Anyway I think she will be around for a lot longer than me back at her place of birth. All the best Frank gav240z 1 Quote
Administrators gav240z Posted July 28, 2021 Author Administrators Posted July 28, 2021 https://www.goo-net-exchange.com/usedcars/NISSAN/FAIRLADY_Z/700900018830190614001/index.html The car is back in Japan and now for sale again. Quote
