Groundhog
Everything posted by Groundhog
  1. All, I remember seeing a thread on restoring of the wiring harness with new plugs and connectors. My search items havent been successful in finding it or the company that does this kind of work. Any leads? Thks Groundhog
  2. Yes. Still have some. Send me a message with your address and donation acknowledgement. GH
  3. Nice choice of colour there!
  4. Mike I don't make them. I had the ones for the 2+2 remade by a sign company. The VIN plate only fits the Australian delivered 2+2 or GRS 30. If you do get a repro plate, look closely at the details. Details to look out for are Chassis No. vs Car No. , VIN No. spacing of characters, type and size of font, rounded corners vs square corners, screw hole size and placement, plate size overall, Model No. and Vehicle size being correct. There are other 240 owners who have had plates made. Cheers Groundhog
  5. Chasing a 3.9 ratio for a R200 Long Nose LSD. Gears only, not the whole diff. I have a 4.4 ratio that I want to change to 3.9. Prefer a crown wheel out of a LSD, as the bolt holes are bigger, however beggars can;t be chosers and I can adapt an open diff 3.9 if I have too. PM me if you can help.
  6. I made my door seals and quarter vent seals from Kia Sportage 2000 door seals. Has to be 2000 model.
  7. I have rears if you need them. Two types to choose from .pm me.
  8. Does anyone know if these are still available locally in Australia or via Nissan? I know i can get them ex USA. Replacing rear wheel bearings on 260z.
  9. Did you get your seat mounts? I have a pair that need a bit of lube, cheap. $10 per side.
    I'm at Bald Hills 0448 775 084
  10. I have some for sale. Machined them up myself. PM me an offer if you want them or details. EDIT My bad. Can't find them. BUMP If you can help out please reply.
  11. I have some for sale. Machined them up myself. PM me an offer if you want them or details.
  12. Chasing some sections of seat cover in ivory basket weave that i can use to patch mine. Mine has a cigarette burn and worn basket weave. Trying to keep my original seats as passenger seat is good. Backrest cover would be perfect to get some pieces if intact. Don't need the seats, just the old covers. PM me pls.
  13. https://www.thezstore.com/page/TZS/PROD/classic02d/50-1451
  14. I looked at buying some vented hatch lids from the US, but didnt like the fact that they were aluminium lids only and the freight cost. I couldn't find anyone here in Oz interested in venting the spare lids that I had. So I thought I'd try it for myself. Bought a vented sheet from RodLouvers.com Then made up steel former top and bottom that fitted over the louvers and shaped them myself. Took the hinge and clip from the old lids bottom of photo and brazed them onto the new lids. The louvre sheet was a bit short so I had to add a piece on top, but overall it turned out ok.
  15. There's always someone out there with the obsession.
  16. THe cream interior had black armrests on the 74 model so you have the right ones for your model. Mine is a 77' and the armrests are colour matched. The front fender mirrors are interesting for being a Japanese style. Do you have an ADR plate fitted in the engine bay? Cars that came into Australia by other routes like returning servicemen, NZ, PNG etc didnt get the ADR plate. (I can see the VIN plate) Gilltech has a 260Z similar to yours from NZ. Being an early 260 his has lots of 240Z features including the shorter radiator/higher cross member. A good guy to chat about features on your early 260.
  17. David. Still for sale. In NZ atm home 17 Feb. Will contact then if thats ok.
  18. I would not recommend buying a car with a sunroof unless it's cheap!
  19. The last job was rebuilding the choke switch. I had to remake the bottom contact plate as the tang had broken off. Pretty simple really, just fiddly work. Then it was a case of take it for its first test drive. Running a bit rich but I'll get it sorted.
  20. I have a set of cam towers with oiler bar and C-grind cam. They come as a package as the cam is not center drilled and needs an oiler bar set up. $100 plus postage.
  21. Mine were zinc passivated painted over with yellow primer colour like the rest of the car, then flat black. Where the scissor action overlapped it was just yellow primer.
  22. Under plastic sheet atm. Not mint finish but good enough for me. Hardest part was getting the Spray Chrome which I got off eBay.
  23. I decided to repair mine in place due to the difficulty in getting them on and off. I used spray chrome for the plastic edges properly masked up to spray can it.
  24. Sorry. Colour match off petrol filler lid (inside).
