KatoKid
Everything posted by KatoKid
  1. Hi Gav. Im going to place a pretty substantial order with MSA in the next couple of months so I can either drop out or stay in .....whatever benefits the group.
  2. Great job Gordo, couldnt agree with you more on the exhaust!
  3. Thanks Mike......trying to avoid pushing them further out to avoid rubbing on the guard. I'm keen to stay with 240 struts/hubs as I know my wheels will fit compared to 260 struts with the lower spring perch height. If the 260 hub wheel mounting flange is in the same position as the 240 then Ive no issues with juggling hat heights to make the brakes work.
  4. Thanks all.....and that's precisely the confusing message Ive read in all the other posts, no disrespect to anyone intended as I can see why its confusing. Think I'm leaning towards Mike and Dimitri (sorry Pete) but ultimately I'm going to have to get some 260 hubs and measure up to be 100% sure! Dimitri, I'm thinking I'm going to have to go with Gerhard's Z32 conversion for various reason which I will explain when I get more info. Are you sure his conversion uses Mustang (DBA106) discs as according to the DBA catalogue they are a hub and disc combined?
  5. Ive done the obligatory search so stow the flamethrowers.... I'm struggling with brake conversions and no one seems to know the difference between the 240 and 260 hubs in regards to the position of the wheel mounting flange..... This thread deals with discs and hat heights: http://www.viczcar.com/forum/index.php?topic=168.5;wap2 and states in regards to discs: Stock 240z is 271mm 12.7mm thick (solid) 52mm hat and 81mm centre 260z is 271mm, 12.7mm 43.5mm hat and 81mm centre Does this mean that the 260 wheel mounting flange is 8.5mm further outboard than a 240? Or is the 260 wheel mounting flange in the same place as the 240 and just the disc height is different? Reason I ask is that Ive got 16 x 8 zero offset wheels and I dont want to push them any further outboard by using 260 hubs...if they are differnt to 240's that is! Thanks. David
  6. Just after a cheap crappy used disc to mock up my caliper conversion. Thanks. David
  7. Thanks Matt and others. Ive looked through the DBA catalogue and there are a few discs that I could use but I think I'm going to stick with the original R33 GTS-T disc which is 296x30mm with a height of 53.75mm. Ive mocked up the front end as I wanted to be able to check for lower control arm clearance which I wouldn't have even thought of without Matt's post. The standard Z disc has a height of 51mm so I put a 3mm spacer between the disc and hub to replicate the height of the R33 GTS-T disc, doing this also bought the disc inboard 3mm to give me more clearance between the caliper and the wheel spokes on the outside but also didn't bring it in far enough to interfere with the LCA. Ive still got about 7-8mm clearance from the LCA. I used a block of wood and some shims to roughly position the caliper where it needs to sit using the standard Z disc and it all looks good, dogbone should be pretty straight forward and Ive got 7-8mm clearance between the outside of the caliper and the wheel spokes so all round a good compromise for positioning......but I really need to confirm with a proper R33 GTS-T disc. Will place an add in wanted for a crappy second hand disc here and on SAU......don't want to buy the real deal until I'm 100% sure they will do the job!
  8. Thanks Matt, saw your thread and was going to ask you. R32 GTS-T had 2 different sizes depending on early or late? Have you got a link to yahoo auction? Offset RCA is going to push the wheel out so will try and stay away from that! Thanks Shane, think Im going to do it myself from scratch. Know someone who should be able to machine for reasonable money. Cheers
  9. Thanks for the offer Lurch but Z32 must be different. GTS-T caliper mounts has 100mm centres vs 90mm for the 240 struts....back to square one. Dimitri, thanks for your PM, will look for something more conventional than your set up...for now anyway!
  10. So Ive done the obligatory searching and not come up with anything solid here.... Ive got R33 GTS-T calipers, looking for dogbones and which discs to use? Needs to be for a 240 not a 260 because I want the extra offset you get from using the thinner 240 hubs. Anyone got this set up? I believe R32 GTR calipers are the same or very similar so anyone using this setup could help. SW and datsport cant help. Thanks. David
  11. I'm still in Gav
  12. Scarily similar to mine! Well done
  13. I picked up my pressed vinyl kit from Dave on Sunday and can attest to how good this looks in the flesh
  14. Well done Cuong. Certainly rare one.
  15. Panel shop has been working on other customer cars so mine hasn't progressed at all...gave them a bit of a rev up and think we understand each other a bit better now! Suspension time.....and time to tackle the job that give so many people a lot of grief.....myself included: Final score was one all. I won one and a spindle won the other. There was no way my puller would budge one side even with copious amounts of oxy heat applied so ended having to bash the hell out of it, once it got moving it was a case of heat and bash, heat and bash....repeat numerous times. The other side by comparison was relatively easy, moved about 20mm with no heat and then locked up which then required heat and would then move another 20mm....and repeat a few times but came out unscathed and reuseable.
  16. Wow....even George would have to say this is way past saving.
  17. Does Turbo Yoda approve of this auto trickery?
  18. Its pretty easy repair....have a look at my build thread, covers it pretty well there.
  19. This is pretty common as there is a doubler insider the frame rail to support the stabilizer bar mounts and it retains moisture with the obvious result.
  20. Its a personal thing Gav but for me gaps can be the difference between a good looking car and a great looking car.....its not meant to be concourse but for the investment I have in this I want it as good as it can be.
  21. Awesome Roberto....love the tough look...needs more lows though!
