Gtv240z
Everything posted by Gtv240z
  1. Which type? Have a pic?
  2. If the rear mounting studs or output shafts are required let me know, I'd have some in another diff Rough price guide for freight to Sydney or Melbourne $25-$30
  3. Nothing wrong with auto! It just the 3.54 that sucks!.... You could... you know ;-)
  4. Rear strut housings from 240z, 51mm $95 Rear lcas, pair (no spindle pin bolts included) $65 Good condition Can post or pick up Adelaide
  5. R180 3.9 Diff , open centre , original 240z 110mm crownwheel good condition , can post with e-go , contact me for a quote or pick up Adelaide $300
  6. here they are ex usa.. https://www.zeddsaver.com/collections/datsun-z-car-id-plates or in AUS , much cheaper but don't look exactly the same... https://www.ebay.com.au/itm/Datsun-240Z-L24-or-L28-chassis-plate-ID-tag-blank/273901031437?hash=item3fc5c6100d:g:t94AAMXQ~6VQ9GvB&frcectupt=true
  7. Please view this ad: 1971 Datsun 240Z SPORTS Manual Coupe, https://www.gumtree.com.au/s-ad/o-halloran-hill/cars-vans-utes/1971-datsun-240z-sports-manual-coupe/1228626997?utm_source=com.google.android.apps.docs&utm_medium=social&utm_campaign=socialbuttons&utm_content=app_android Price: $18,000 Negotiable Download the application from the Google Play Store. https://tinyurl.com/n4b7djy
  8. Sure does!
  9. It was popular and sold quickly
  10. Is head office / 3d scanning facility in Adelaide where the factory used to be?
  11. I have a mirror, no bracket, but also need an adjuster knob for the mirror on the car...
  12. Why do you need 2 fuel pumps?
  13. I can supply new ones, 3 weeks ex Japan $110 delivered to you
  14. What's the difference between turbo and non turbo?
  15. Gtv240z
    Worm Drive Gear
    Later versions were plastic but were the same, id have a couple of those
  16. I also have a pair of standard rear LCAs I can sell if someone needs them
  17. For sale, rear lca delrin control arm adjustable eccentric bushes. I bought these quite a few years ago, and never used them, I can't confirm if they have never been used as I bought them from Gumtree I think but confident they will fit as new. Any issues happy to warranty $110 posted Australia wide Look the same as these and comes with a home made spanner for adjustment. https://www.rhdjapan.com/search/category/handling_upper-mounts-and-camber-adapters/brands/kameari/
  18. Correct! And where fitted with this half ass attempt for compliance by adding indicators to the bumper.. They should be on top of the bumper, but most were moved to under the bumper as it looks a bit better.
  19. Call your local Nissan dealer, spare parts, about $20-25 for a pack of 10
  20. Genuine Nissan still available from USA about $125 delivered
  21. Translated poorly via a phone ap: Sliding cam sprocket gear ・ ・ Please start the minp. ・ First assembled at this position, then parv tie ・ It is normal when the center line is aligned. 1 · Position of associate 0 0 I will do my best 1 item TEL 8-998-2323FX04891702 Kameari Industrial Co., Ltd. Released by: Sakitama Prefecture Yashio City Yoricho 3-1-16 2. Advance Baltai ・ Amber cam advances 1 memory in the direction of rotation of the engine 'I'm in a state. 1 memory advances 2 degrees in cam angle and 4 degrees in crank angle. 3. Delay Paltai 11 to 19 (N · m) 1.7 to t. 9 (k th) [Screw bolt tightening torque] ・ Be sure to tighten correctly with a torque wrench. Please. 4. Tighten the slide bolt 1 memory is delayed by 2 degrees in cam angle and 4 degrees in crank angle. Being in ・ The cam pile is delayed by 1 memory in the reverse rotation direction of the engine
