Gtv240z
Everything posted by Gtv240z
  1. Hi , Just wondering if I can pick your brain? I had a S14 silvia gearbox fitted with an RB gearbox extension housing pieced together and mounted to my L series bell housing so that overall length of the gearbox was the same as the original and retained the original tailshaft. If i had gone with complete S14 gearbox on the L bellhousing I would need to shorten my tailshaft. My question is : I had to re do the rear gearbox mount to fit my hybrid gearbox which is approximately 35mm further back towards the diff, Would the Silvia gearbox mount to this or is the distance different again? Thanks, Craig
  2. how much for the rear control arms?
  3. Located Adelaide SA. This sale is diff only , no flanged output shafts. I probably have a spare set of shafts and would have to check the garage.
  4. http://www.ebay.com.au/itm/131794299554?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649 Sick of your useless Zed heater / AC blower motor?! Here is a pretty serious upgrade from a Honda Civic! If you are reading this you are likely well aware of swapping the original 240Z fan motor for a 1990s era Honda Civic fan motor . If not check this link out for the details: http://www.classiczcars.com/topic/19332-honda-civic-heater-blower-motor-upgrade-for-240zs-my-personal-take/ This fan motor basically bolts straight in and provides much better air flow for your heater and if you have the luxury of AC ( and i don't mean window winders!) this will be an essential component of an AC fit out or upgrade . I disassemble, clean , check brushes and armature etc , reassemble and test before sending to the buyer. Any questions let me know, Free postage Australia wide. $75
  5. Used Nissan OEM 3.90 R180 Differential Unit Very good, used condition Nissan R180 3.90 open Differential Assembly. . Thanks
  6. Fantastic! I was never really a fan of the aftermarket / modern style upgrade lenses. The Koito version is perfect! Thanks
  7. 240z for sale in Port Lincoln SA Asking: $27,800.00 http://www.gumtree.com.au/s-ad/port-lincoln-5606/cars-vans-utes/1971-datsun-240z-coupe/1109206720
  8. http://www.ebay.com.au/itm/1971-Datsun-240z-250GTO-manual-for-restoraton-/281986935659?hash=item41a7bb2b6b:g:BVQAAOSwgApW~QIO 250GTO / 240Z
  9. Gtv240z
    L24 Rods
    Wanted L24 Rods, let me know what you have, Need to be posted to or pick up in Adelaide Thanks
  10. Hi, price of the air cleaner assembly? Thanks
  11. FairladyZ 432 for sale on Gumtree ! Not sure if this has been posted yet.. but check it out! http://www.gumtree.com.au/s-ad/burwood/cars-vans-utes/1972-datsun-fairlady-z432-silver-manual-coupe/1102434012
  12. Have you still got it? and when you say Yes! they never reply as if they wanted you to say no so they could stop day dreaming about buying it.
  13. needs head gasket.. my toolbox could do with a pair of Xray glasses too. super handy for diagnosing internal engine failures with out even popping the bonnet
  14. I had exactly the same problem , Rear nice and low , Front too high! Thought i may have put them in the wrong ends of the car but apparently not. I am now going to cut a rung off and see how that goes I also recently aquired some eibachs for a late model Alfa , and I am about as convinced they are a good spring as I am happy with the Zeds uneven ride height. I wouldn't recommmend Eibach and not convinced progressive springs are any better than a tried and tested regularly wound spring
