697 -
11
Everything posted by Gtv240z
It's just like mine... except with $3.485M of improvements!
Hi Z, Thanks for the reply , I don't really need the stub axles, how much do you want for the pair of housing with and with out ? Cheers, Craig
check this out for genuine original look H4 headlight.. http://www.viczcar.com/forum/topic/10373-new-oem-h4-headlights/?hl=%2Bkoito+%2Btoyota
Hi , I'll take the rear strut housings if you can post to Adelaide? Let me know and PM also sent, Thanks
For Sale here a new fuel filler protective rubber flap for the Datsun 240Z and early 260Z This flat sheet of rubber attaches around the fuel cap and unfolds while fueling to prevent scratches on the quarter panel paint and catch fuel drips before they drip on the paintwork. Replace your worn , cracked , brittle or non-existent filler flap. These are made of nitrile rubber and fuel resistant and cut to OEM specs. This sale is for 1x fuel flap . Please see photos for installation which is as simple as unscrewing 3 philips head screws. Any questions please ask. Free postage Australia wide Can be bought through Ebay for $25 or cash sale here for $20.. http://www.ebay.com.au/itm/Petrol-Fuel-Tank-Lid-Flap-Protector-240Z-260Z-1970-74-/131881249315?ssPageName=ADME:L:LCA:AU:1123
so glad i read this. I had a bottle of Penrite synthetic oil on the shelf that i thought was suitable but decided to buy Fuchs as it was recommended, I nearly put the wrong oil in my gearbox , contrary to the online LubeGuide This reminds me of the DOT3 , DOT4 arguement... don't ever put DOT4 in a master cylinder reservoir that has DOT 3 specified.
wish i could buy them! building a new engine and cant afford both sadly...
i have a s1 buried in a back garage , SA22C RX7 series 1 is 4x110, series 3 is 4x114 same as datsun , offset is a bit different though, not sure on s2, think they are also 4x110.
Hi , I am after a 240z air cleaner assembly, please let me know if you have one you want to part with. poor condition will be considered so don't be shy! Thanks Craig
Up for sale here a gear stick / shifter for the Silvia Sr 5 speed and Skyline RB20 5 speed. This gearstick has been modified as can be seen in the pictures. The original rubber bonded stick has been removed and I have reshaped the shifter to copy my original 240Z gearstick. I had a Rb20 5 speed in my zed and the original straight shifter , which came up through the transmission tunnel correctly would hit the front section of the centre console . The gears could not be selected correctly in the original straight shaft configuration with this gearbox. The SR20 5 speed is slightly longer so the straight shifter would probably work fine in this instance. If you have a Zed with an early RB gearbox this might be ideal for you. Alternatively if you have another vehicle with the Nissan 5 speed retrofitted this shifter might also be of use to you. Another alternative if you just want a cheap shifter to cut and modify yourself for your own problem solving then this may also be the product for you. Any questions please ask Please note : the chrome shifter in the pictures is not for sale or included in this auction. it is for display only. The gearknob is also not for sale in this auction but these Momo style knobs can be bought on Ebay for as little as $8.99. The rubber boot , collar and circlip are included. Free freight Australia wide. Thanks,
L Series Bellhousing Machined For Sr / Silvia 5 Speed
Gtv240z replied to Gtv240z's topic in Parts and Tools for Sale
SOLD -
L28 Crankshaft, Rods, Pistons With Rings
hi , i can take some photos on the weekend for you -
L28 Crankshaft, Rods, Pistons with Rings came from an excellent running engine with genuine 169,000km on the clock no sure what its worth , let me know if anyone is interested Thanks,
For Sale Front Right Strut Housing From 1973 240Z
Gtv240z posted a topic in Parts and Tools for Sale
For Sale Front Right Strut Housing from 1973 240Z no spring or top hat $75 + postage if required -
Thanks for the info! This modified mount and shifter will most likely be up for sale this week if anyone is interested. I tried my best to make it factory looking
I'm might have a shifter I want to get rid of, i'll let you know, or hassle me mid week onwards if i forget modified to suit 240Z
