Gtv240z
Everything posted by Gtv240z
  1. 4 speed to 5 speed conversion a success! Much easier than swapping a gearbox out and in!
  2. sorry Agno , but the crack was on the bit you didn't want cracked anyway
  3. Hi guys , Just BUMPing this one as i am doing a turn up on the lathe of these this week so if anyone is interested , $5 off the above prices which will be standard price from now on Thanks
  4. Thanks KK, spoke to your mate and now sold! Cheers!
  5. All good guys I have 4 to sell, I am in Adelaide but happy to post Australia wide for $10 extra
  6. Datsun 240z 260z 1600 180b etc Genuine Nissan Thermostat Housing Top & Bottom Covers These are a genuine Nissan item and have a very nice metallic finish not found on other aftermarket roughly cast housings. please also note it is a 2 bolt which was original to 240z 260z 1600 and 180b i think . later model 280zx etc vintage was a 3 bolt unit . Top Housing $30 Bottom Housing $60 gaskets included $10 for postage australia wide i also have the thermostats for $30 , regular temp and lower temp version
  7. have looked every where this morning but sadly no fasteners $65 for this air cleaner as is in the photos
  8. Yes I think I have those bolts but will need to double check,
  9. My original plan was to make a factory style air cleaner for triples, historic rego rules here in SA just became much more relaxed, which was half my motorvation, and I put a heat shield on the other day which won't work so decided bugger it not interested in that any more, revolve the budget and buy some other bits for the zed. There a ding in the back cover which isn't much and the intake has a tear in it which is it downfall but could be welded up. Don't know what it's worth, Might go best offer by end of the weekend can have it, I and can post with E-go or pickup business hours or weekend.
  10. yeah mate , i'll take it to work today and take some photos for you
  11. Just sold one and just check second one is cracked so probably wont bother selling that one
  12. I have 2x 240z air cleaner assemblies I want to parts with $100 each + freight I'll get some pics posted tomorrow tomorrow
  13. I have just bought all the bits to make them and looks the same as the MotorSport Auto / OEM look , These will also include the male connector on the zed's wiring loom so both plugs are fresh white instead of fresh white into faded / dirty socket. or you can just slide the brand new brass terminal into the old faded plastic housing for the authentic, vintage look. annoyingly everything had to be bought in large quantities.. so if anyone needs one let me know . I'll put a pic up or post in the classified section once the wire comes in , i am also getting a couple of different amperages
  14. Control knobs here : Look at this on eBay http://www.ebay.com.au/itm/332277318192
  15. Still an expensive exercise but this appears the be the cheapest nos OEM 4 speed knob I could find. http://www.thenismoshop.com/Nissan-Factory-OEM-Wooden-Shift-Knob-4-Speed-C2865-H9300--Nissan-Datsun-240Z_p_1640.html I have got a used one coming from the US, hopefully it's a good one!
  16. Do you still have original style mechanical fan? the viscous clutch is probably stuffed. if your not leaking coolant and with the cap of can see good coolant circulation your stat should be open and waterpump probably working well. these clutches are pretty prone to failure
  17. I want to keep my original parts intact so i can reverse the changes if i decide later on that's what i want to do .
  18. I'm doing a brake caliper upgrade too but only need to trim the slightest bit off for new calipers to fit with the guard . I want to keep my original parts intact so i can reverse the changes if i decide later on that's what i want to do .
  19. just wondering if any one can sell me a pair of front brake backing plates for my 240z ? I am not sure but would assume 260z backing plates are the same?? If someone could confirm that would be fantastic! Attached is a pic of the plates i am talking about Let me know if you can help me out, ones that require a bit of panel beating or repair will be fine, good ones also very happily accepted Thanks Craig
  20. does anyone know if you can buy the throttle bellcrank bushes new?
  21. you can still get the knobs new but are a bit expensive at $24 US plus freight , be ok if you are ordering some other stuff too. i also email this supplier and ask for a freight cost as the computer generated one is overpriced , the supplier always replies with a cheaper price for the freight i bought 1 last year and pretty sure it didnt come with the screw . a walk through a local self serve wreckers you'd probably find most japanese cars have the same screws for something like that or as mentioned above , jaycar, etc https://zcardepot.com/interior/heater-control-knob-oem-240z-70-73.html?search=240z+heater&page=1
  22. did you find a OEM looking replacement for the fusible link? i am doing an engine bay makeover and want/need to replace the fusible link
  23. are there any of these oscillator boards still available?
  24. there's this one i noticed , says its 260z but it looks identical to the one in my 240z ... https://www.gumtree.com.au/s-ad/westmead/other-parts-accessories/datsun-260z-under-dash-air-conditioning-unit/1115743034
  25. interesting , what are the desirable block numbers for the 4s?
