Aaron Neubauer
Everything posted by Aaron Neubauer
  1. I bit of perseverance (and a new CAS haha) has paid off! I have a functioning L20ET distributor that my Megasquirt MS1 can read. I fiddled with a few mods to the board taken from a few sites that have V3.0 board info. Ultimately I could have left the mods at removal of C12, C30, D1 and D2 but I left one of the diodes in as backflow protection. I didn’t need a pull up resistor but I left the one I had installed from the S12c pad. The Fuelmiser crank angle sensor Sparebox first sent was faulty through bench testing. Sparebox quickly replaced it which was great. I slapped the dizzy back together with the DYIAutoTune 12-1 trigger wheel which means I can run COP later if I choose. The next step for me is to swap in the turbo oil pump drive with the engine in the car. It’s the one item of work I have been putting off for obvious reasons haha!
  2. Not a worry Gav! I’ve tested the CAS in isolation and it’s not working properly. The megasquirt board functions properly when tested on the JimStim. It would not be the first time a new CAS doesn’t work. Over the decades of having VL turbos and distributor based SR20s, I’ve found literal 50% of all new CAS for optical nissan distributors seem to be faulty.
  3. Its always frustrating when things don’t go to plan. All the parts arrived to rebuild the distributor much faster than what I was advised and I had the dizzy housing PBM blasted and scrubbed to a raw appearance. I really like to look of the housing. I’m still hesitant to commmit to swapping the oil pump drive shaft to the turbo shaft until I know for certain that this dizzy works. So the dizzy was put back together and mock wired to the Megasquirt for an RPM signal simulation. No dice. Didn’t work. Nothing. I suspect the new crank angle sensor is not a functioning unit but will require more investigation. So looks like another few weeks without tuning the ignition for the car unless I put the old Pertronix L24 distributor back in. All I want to see is if I can crack 200rwhp on SU carbs....
  4. Its been a while since my last post about this car. The brakes have been rebuilt. You can see those videos on the channel. In summary for the brakes: • Rear drum cylinders and MC were sent to South Coast Brake Resleevers • The MC was stuffed but the resleevers had a NOS MC lying around so I got that which I’m chuffed about! • Rear drum cylinders were resleeved to a high quality cause they were shagged • I rebuilt the front calipers myself So the brakes are on and bleed but I have not go little red off the blocks just yet. I really want to use the optical dizzy that Gav gifted me. I had one big cost hang up that ultimately determine if I used the optical dizzy or used a CAS from One Six Industries and wastes spark and that was the turbo oil pump drive. Nissan dealerships and Nissan Australia parts had not had one in stock for over 20 years. Getting one from somewhere the US was pushing upwards of $200USD. I was getting sad. Lucky enough I came across a new product post from Kameari who had decided to make there own when the genuine item price increased. The Kameari unit cost ¥11,000 which was heaps cheaper than any other pump drive. I put my order in and it turned up pretty quickly. So project optical distributor has commenced in full! See the video here:
  5. PM also sent if there is anything left after Riceburner’s raid!
  6. The turbo distributors run an optical CAS system that Nissan used through the RB engines. It can be configured to run sequential injection and coil over plug. Sorry to hijack. Funny story is I’ve just got a turbo distributor but I’m after a drive shaft!
  7. Hi guys, I know these are as rare as hens teeth but I thought I’d try the forums first. Must be in good condtion.
  8. Sorry to clarify rotate the leads around one spot on the dizzy ie 60 degrees change and then retard in the brackets. From memory this was 15-20 degrees static advance with one tooth out. Similar to what Linton has suggest.
  9. Back to rebuilding the brake system this week. I decided to stick with drums on the rear. Having made that decision both the rear brake cylinders and brake MC will be sleeved to last longer than I will. So the rear brake cylinders and MC came out easy enough. The left side brake cylinder is properly frozen, not even the adjuster nut came out with ‘hammer time’ persuasion. I thought that I’d need to get new rear cylinders but after a chat with chap (after the youtube video was made) who will be handling the sleeving, the sleeving workshop can get anything apart. So rear brakes and MC have been posted away. I’m looking forward to the results!
  10. I had a dizzy one (or more) tooth out on my engine. I was able to verify timing by moving the leads around one location on the cap and retard the dizzy as far as it would go. That got me near the mark and the engine behaved properly.
  11. So, I came across some RB30 optical dizzies in my spares and I thought “I wonder if this will fit the 240?”. I’ve seen at least one photo of an RB30 distributor on an L series before and I think it’s doable. While the locked standard distributor works well enough, and optical cam angle sensor can allow me to use COP ignition. I have a 12-1 chopper disc that replaces the 360+6 standard disc made by DIYAutoTune. Depending on the ECU, this chopper disc can be used for 4 cylinder COP applications as well. I’m not sure if I should be shamed, I onced owned and modified a two tone gold VL Calais Turbo which was a beast when it ran and I found the optical distributor to be very realisable. Anyways, see the video below for the initial checks before I get too carried away with the idea...
  12. What started as a bleed of the brakes has evolved into a brake system rebuild. As long as I can remember the right drum brake cylinder bleed nipple has been sheared off at the base. It’s one of those things that I’ve know about but never actioned fobbing off to do it next time. No excuses now. Time to fix it. The end game brake goal for this car is a set of Sumitomo MK63 font calipers to retain the standard master cylinder. Not sure if vented or solid rotor. I guess this will be dependant on what’s available. I’m not in a rush to get a pair and considering it is likely to come from Japan I’ll wait until a good deal surfaces. I’ve have a spare pair of Sumitomo S16 cailpers and rebuild kits plus brake pads to cover off on the fronts. The rear drum brake cylinders look new so I’ll get some rebuild kits for those. The master cylinder I will remove and send away to be stainless steel sleeve which should make it good for life. I am bummed that tuning is on hold but it is important to have road worthy car.
  13. I put it down to if I can cheaply make it (or something like it...), why buy it? And I *might* be a little too frugal. If the DIY det can proves unsuccessful I’ll probably end up getting one of these: http://theknockbox.com.au/
  14. Following on from the strange ignition behaviour I thought it worth making up a cheap digital det can / engine stethoscope to aid in determining if something more serious was happening. I drew inspiration for an old Autospeed.com article I read probably around 2001. http://www.autospeed.com/cms/article.html?&A=0353 The basis was the Jaycar ‘bionic ear’ Short Circuits kit aimed at junior electronics. This kit had all I needed only requiring a few little bits and pieces to customise. The kit was assembled as per instructions and recommendations in the Short Circuits 2 guide. I simply lengthen the single core screened microphone cable and fixed it to a battery clamp. I tested it on my TD5 Defender daily and I could hear plenty of extra noises in that motor that’s for sure! As the kit uses a electret microphone it picked up all the noise. I think I will find it hard to isolate specific sounds, detonation being a primary one. For a first round its not bad though and I think I will gradually improve it over time such as switch to a piezo transducer and perhaps an alternate amplifier board. As soon as I can get some Penrite Super DOT 4 brake fluid to replace my stock and bleed the brakes, which is proving difficult in my ‘regional’ area, it’ll be road tuning time!
  15. Off the back of pre-tuning experience I thought I’d combine the LM2 WBO2 into the Megasquirt so I could log all my data in Tunerstudio. Why have two screens to look at while tuning right? It was a pretty simply process simply wiring the analog output 1 from the LM2 to the DB37 harness. I did have to calibrate the Megasquirt to match the LM2 AFR outputs which I pulled form the LM2 using Logworks. The prefilled Innovate Motorsport WBO2 sensors in Tunerstudio did not match the LM2. I think it was 7.32 @ 0v and 22.39 @ 5v. So ready for some tuning. But first I want to make a digital det-can beforehand just to check the strange ignition behaviour of the motor. Stay tuned.
  16. That dash looks mint! Loving your work.
  17. Thanks guys. There could be hundred reasons why the car is behaving the way it is. Sometimes with the right (or wrong) culmination of parameters an anomaly occurs. I’m not overly fussed as long as come dyno time the engine makes more power not less. I have considered a distributorless wasted spark COP ignition before embarking on this project. I wonder if there is value in a comparison series between distributor and COP?
  18. So the little niggling issues continue. While travelling to a local informal coffee and cars show I discovered a problem with the ignition timing. It felt like an ignition ‘wall’ at around 3,400 RPM. My first thoughts were it was something other than the ignition advance. I’ve had 36 degrees in this motor when it ran the tripled 45DCOE152s years ago. I just assumed the engine could take the same again. I was going to check the signal form from the Pertronix in the event that signal noise was causing interference. I wasn’t real sure how to condition an I/O type signal. In the end it was the ignition advance. When the table ramped up to 31 degrees at 3,400 RPM, the engine couldn’t take it. Trialing lower advance in the same areas of the table allow the engine to rev properly. I’m glad it was an easy fix and I am surprised that with running the SUs with SB needles that the engine characteristics changed. A new chapter has been added to my ‘book of Datsun’. Anyway the ignition table has been revised to lower advance levels and hopefully this will be a suitable base for some road tuning. If anyone has come across changes in ignition behaviour with different setup ups, I’d love to hear it.
  19. Absolutely the 123Ignition is a much less involved ignition that what I’m doing. I did look at this and the only reason I went with the Megasquirt was that I had the Megasquirt kit already (i’m I’m ‘frugal’). They look like a good bit of kit. I did correspond with 123 and I believe they confirmed it would operate with CDI ignitions like the MSD 6AL. The moment of truth arrived for the first startup with the Megasquirt configured for ignition only and the SB needles in the SU carbs. The distributor needed to be aligned with the trigger angle parameter in the ECU which was easy to to. I did hit a road bump with a leak from a MAP vac hose that was larger than the onboard MAP sensor barb. That was fixed with a smaller vac hose 3mm in diameter from Super Cheap Auto. I had to buy the stand out blue coloured silicon stuff made by SAAS because the roll of non descipt black was empty. With the problem fixed the car runs but I want to revisit the ignition table before driving and adjust the SU mixture nuts after. The idle vacuum is a little different to what I thought it would be and revving the engine without load cause some hesitation around the 3k RPM mark which makes me think I have the advance ramping up too fast in the table.
  20. I was able to play home tuner using Tunerstudio to set put the parameters and rough in an ignition table for the MS1. There wasn’t a lot to set up with an ignition only configuration, the ECU is pretty under utilised as far as it’s overall capacity. Even though the hardware does not exist for the injector circuits, I zeroed the injector table data. To bench test the MS1, I used the Megastim board and a syringe with vacuum tube for the MAP. A 60ml syringe wasn’t big enough to generate enough vacuum to get to the closed throttle parts of the map but it was helpful still. I had help from Godzilla Raceworks who saw one of my Instagram posts and offered up an example tuning file from an MS2 used on a similar engine. I’m very appreciative for their assistance. https://www.godzillaraceworks.com/ There are a few items I need to address before attempting to start the car with the MS1 and new SU needles. The vacuum line for the MAP needs a home on the intake manifold and the signal wires from the Pertronix unit need a little tweaking to introduce voltage because the Pertronix unit doesn’t generate its only power, its only a switch essentially.
  21. Jeez! Those existing repairs look rough as!
  22. I snagged some time over the Christmas break to fault find the Megasquirt MS1 install. I 100% expected the problem to be something simple. Sometimes I hate it when I’m right… I hypothesised two possible problems. One being the ECU itself and the other the wiring loom. The ECU powered up and connected to the Tunerstudio when plugged into the Megastim board. Happy days that the ECU was not toast! This left the wiring harness. Voltage was getting to pin on the harness. That left that the harness was incorrectly made, that the voltage was going to the wrong pin. A quick review of my notes, physical verification and sure enough power was going to the wrong pin. A quick swap of the pin and the ECU powered up when connected to the wiring harness. I’m glad it was something minor and simple. Next stop, ECU tuning!
  23. Finally got around to mucking with the megasquirt wiring harness. There isn’t a lot to wire up with the MS1 in ignition only configuration. It took nearly a week doing little bits here and there coming up to Christmas. It didn’t go to plan but the advantage of this being a project car is I can just shut up the garage until next year! Merry Christmas all and have a happy new year!
  24. I’m keen to see photos of the combustion chambers! Pretty please?!
