d3c0y
Everything posted by d3c0y
  1. But you are just proving my point. You either: a) spent more money than they did to get the same amount of power and less torque or b) if you go $ for $ the L28 will make more of both. It's not like an L28 even looks any different. Tell people it's an L24 and 95% of people will believe you, unless they check the engine number on the block or the casting.
  2. Don't you use an iPad? You don't have keys!
  3. About a solid 0 out of 10. I'd rather have fun driving it and i've never had anyone go, oh you put an L28 in it what a shame... Looks like you didnt listen to Ja Rule or Fast and the Furious...
  4. A few of us QLDers were joking about having all our zeds on the road at once to drive down. Lol Even if they are together do i want to sit in my zed for 11hours and put that many kms on my engine... hrrmmm
  5. L24s are just slow L28s. Everything equal, any money you spend on an L24 will make more power if spent on an L28.
  6. Why isn't there an option to store it and build a stroker?
  7. Depends how many different colours and pearls they need to mix into it.
  8. You can do a revs check that is nation wide covers what you asked. http://www.revscheck.com.au/?gclid=CjkKEQjwh7ucBRD9yY_fyZe398gBEiQAAoy4JEvMbHy1YhA6LR9_0luHi1sQz6BIVl33WoPcPpuPPKbw_wcB You just take it in and register it like any other car in QLD.
  9. It's not that abstract, they were cheaper to buy new, like a GT86 is now to a 370Z. Not as highly regarded as the zed when new - just like NZeder has stated, lower performance, less desirable. It's the same as a 1600 not being worth the same as a zed. 1600 and Celica would be comparing apples with apples, especially if you are talking the 2 door variants.
  10. Unscrew the tops, pull the pistons out and give them a really good scrub if they are all black inside. Spraying in a bit of carb cleaner wont do shit. You may need to pull them off and give them a bit of a soak and a pull apart. Your mixtures sound like they are in the normal range, maybe the chokes getting stuck is a lead, even though you dont use them.
  11. Yeah i was sorry. Funny thing is the car has been relisted AGAIN for the third time and is just over $12k and no reserve this time...
  12. Have you ever pulled them apart and given them a good clean? That would be a good place to start if you haven't. How far are your mixtures from the base setting? Two and half turns out or whatever it is? (You will need to look that up because its ages since i had SUs on my car.) If you are miles off that and both carbs are very different in setting, it will at least confirm something weird is going on in the carbs
  13. Just keep winding the timing into it until it goes ping!... Then back it off a bit.
  14. The distributor base plate can be adjusted itself. If you pull it out and flip it over you will see you make big adjustments that way and then fine tune with the top adjustment you are familiar with. Actually now i think about it when did you last change your fuel filter? What colour are you plugs when you pull them out after a drive? It sounds like a fuel issue to me, probably starving. If you take it for a long drive does the problem go away. Is it the fact the car sits around for ages while you tune it, but when you drive it the next day its going out for a quick lap?
  15. You are supposed to have two springs on the heat shield too, one on each side. One spring doesnt have enough power to hold it all shut properly and yeah as Doug said, take your carbs apart and clean them. How gummed up and full of carbon are they around the butterflies?
  16. That is some low ignition advance to be running if you are running high octane fuel in it. I've never had any problems with SUs behaving like that. Maybe your fuel pump is on the way out?
  17. She was my girlfriend when she bought it and we all lived together and Doug and I did all the work on the car.
  18. I had done a deal on that car with the owner, literally waiting bank details for deposit to buy it sight unseen and then back flipped on me. It's on gumtree for $19k and i was originally "buying" it for $10k
  19. Got to be specific here: WRX STi Version 6 Type RA which is pre 2001, but post 1996 i think It's a 4.44 ratio with a 4 plate mechanical clutch. There will be a big K on the top of the diff. I'll have pics of mine on my facebook page shortly.
  20. Jeeze if i had known you wanted stock ones i would have given you mine! I thought you would have been after adjustable ones.
  21. A truck load of stuff from the engine bay, Pretty much everything was cad plated in there.
  22. d3c0y
    260z engine
    VR38DETT buddy... there is more than one nissan V6 in QLD you arent allowed anything over a 12A so i think you have rotary P issues wayyyy before that.
  23. Ahh i thought you had 15s
  24. Thanks for the responses guys. How much do you want for it? I can pick it up this weekend i'm just at Miami. OK so my question is, since the 260Z has the same rear suspension why are they different? It looks like there are two types from what i can tell, 240z - 260Z S1 and then MY76 onward. Do any of the factory bars mount like the bellow pic and is it any better than the stock style mount? Is it just easier for the aftermarket to make it like that and can you get aftermarket bars to fit the factory mount? I guess there is no point setting everything up for the stock bar if i will have to change to an aftermarket one anyway.
  25. The mounting could be different can you take a photo of it please?
