d3c0y
Everything posted by d3c0y
  1. Yup that's what mine is, except i run a 0.75 5th. I'm pretty sure that you get the upgraded 71C parts regardless of what sort of box you order for.
  2. The Kameari gear set for the 71B is actually the same gear set as the 71C, you are just picking the ratios. My box has 71B housings and a 71C gear set. It's all the same really, just beefier. If you say the kameari isnt close enough then the stock is going to be even further off. What diff are you running too? 4.3 ratio pulls them nice and close and keeps the top speed down to a race friendly speed.
  3. I had a blow torch, loctite freeze spray, breaker bars the works. I ended up having to fill it through the breather on the top. Shortly after the L34 killed it dead, sent down to Les for scrap and housings.
  4. Yeah i didnt have any joy with my VG30DETT although it did do 500rwhp
  5. Why are you ditching the VG?
  6. Make sure you open the filler before you drain the oil, as sometimes they freeze in. I couldn't get mine out at all.
  7. I think the braces are aimed at stopping that specific area from flexing as much, which will probably prevent the problem. It's probably along the same lines as upgrading the chassis rails. You don't have to do it, but its better if you do. They do look super easy to make and if i was in the US $28 would seem reasonable for not having to go to any effort to make them in my opinion. The postage definitely makes it less of a bargain.
  8. d3c0y
    240Z parts wanted
    They aren't ever going to come, face up to it Mat...
  9. Something like this: http://www.zccjdm.com/catalog.php/azcarbum/dt93862/pd2118872/SWAY_BAR_BRACE_PLATES__FRONT__
  10. Are we just getting trolled?
  11. It looks wrong even for export models as Gav said the fonts aren't right, pretty much the same as the North American one. This is what the JDM one looks like, even though this specific one isnt for a zed:
  12. Might as well put a 250GTO kit in there too if you are putting that Z-BAIT monstrosity in there.
  13. What's a Z-BAIT? Isn't that what happens when you find a pic of a really good looking zed on the internet? I google came up sans answer.
  14. Yeah thanks guys, the inside of the tank has already been done along with it being baffled, extended in the middle with a central bowl and rear mounted pickup. Just need to make the outside look pretty and my mate said i couldn't spray it with regular paint. This will be nice and easy now
  15. Hey Guys, I have a new (read second hand) fuel tank that is silver and i want to repaint it gloss black. Do i need to paint the tank with some sort of special fuel tank paint or can i just sand back and spray it with my super favorite paint Kill Rust Gloss Black???
  16. Star bar mounting is "interesting" along with the chromed centre console.
  17. 1973 Failrady 240ZG race car (http://www.nissan-global.com/EN/HERITAGE/fairlady_240z_059.html) That is actually called a 240ZR
  18. To complete the picture Techno Toy Tuning (T3) offer a weld in style camber top for even cheaper if you are ok with cutting the top off your strut towers and welding some plates in, but for most people that is a lot more expense and bother than the two options above.
  19. And to beat HS-30H to it, you have to decide if you are doing AUDM, JDM or USDM models which are all different again. Since you have 280Zs in there i guess you are doing US market cars?
  20. I would say either of these for set and forget plus the ability to go more down the track: http://www.ground-control-store.com/products/description.php/II=151/CA=191 http://www.k-mac.com/pages/newprods/datsun/datsun.htm Kmac have castor adjustment built in so you can do that right away when you are setting your camber. Castor is a good thing for handling even on a road zed. They are a little more though.
  21. FWIW it's out of a '73 with an R180. Let me know if you want it for sure before i go getting postage quotes.
  22. I know that 240z shafts auto to manual are the same FWIW and i do have an R180 240z tailshaft if it helps.
  23. Is this for track or street - what's your end goal here? Do you want castor adjustment too?
  24. There are better solutions out there, what is your budget though?
