d3c0y
Everything posted by d3c0y
  1. Already got my order in Stolen from Hybridz: johnc, on 20 Oct 2007 - 09:12 AM, said: I get this quesiton daily. Assuming you've spent money and time building adjustability into your suspension AND are willing actually adjust then these recommendations make sense. Otherwise, take the car to Pep Boys, tell the tech to "Make it all green", and hope your tires last a long time. Track/Autocross For 225 to 245 width radial DOT tires try these alignment settings: Front Camber: 3 to 3.25 neg Caster: 6 to 7 positive (even on both sides) Toe: 1/8" to 3/16" out Ride height: 5 1/2" to 6" measured at the front of the rocker outboard of the pinch weld seam. Rear Camber: 2.5 to 3 neg Toe: 1/16" to 1/8" in Ride height: 5 3/4" to 6 1/4" measured at the front of the rocker outboard of the pinch weld seam. For tire widths over 245 try these alignment settings: Front Camber: 2.75 to 3 neg Caster: 6 to 7 positive (even on both sides) Toe: 1/16" to 1/8"" out Ride height: 6" to 6 1/2" measured at the front of the rocker outboard of the pinch weld seam. Rear Camber: 2.25 to 2.5 neg Toe: 1/16" to 1/8" in Ride height: 6 1/4" to 6 3/4" measured at the front of the rocker outboard of the pinch weld seam. Street For 225 to 245 width radial DOT tires try these alignment settings: Front Camber: 1.25 to 1.5 neg Caster: 4 to 5 positive (even on both sides) Toe: 1/16" out or 0 Ride height: 6" to 6 1/2" measured at the front of the rocker outboard of the pinch weld seam. Rear Camber: 1.25 to 1.5 neg Toe: 1/16" to 1/8" in Ride height: 6 1/2" to 7" measured at the front of the rocker outboard of the pinch weld seam. For tire widths over 245 try these alignment settings: Front Camber: 1.25 to 1.5 neg Caster: 4 to 5 positive (even on both sides) Toe: 1/16" out or 0 Ride height: 6 1/2" to 7" measured at the front of the rocker outboard of the pinch weld seam. Rear Camber: 1.25 to 1.5 neg Toe: 1/16" to 1/8" in Ride height: 7" to 7 1/2" measured at the front of the rocker outboard of the pinch weld seam. Caveat Emptor: These are starting points for you and your car. Be ready and willing to change them based on your preferences and local conditions. These alignment settings might be a bit tricky in the rain and even trickier in snow or ice. Your tires will wear a bit faster then the stock alignment settings. If that's a concern of yours, stay with the stock numbers and don't ask me dumb quesiton like, "Well... how much faster will they wear?" or "How many miles will the tires last with the Track alignment setting?" If you're asking those questions you shouldn't be reading this thread. Go buy a Honda...
  2. Do you know or are you guessing?
  3. d3c0y
    Wade camshaft
    I'm by no means an expert, but it will make power a little higher up (rev harder), more peak power and idle a bit rougher. The 74 will be more torquey at lower rpm. It's definitely not a huge cam though, a 76 high lift is like 310 duration 550 lift to give you some reference.
  4. Buy this car: http://www.viczcar.com/forum/index.php/topic,13357.0.html Put an RB25DE in there until you are off your P's. That should set you back another $1000 at the most. If you can't afford that car you can't afford a 240z, sorry that's the harsh truth. As suggested if you cant afford $10k then buy a 280zx and get a 240z down the track thread done.
  5. Stalks are steel.
  6. Or just buy them from Aus and not worry that they are specifically Z-L parts depending on what exactly you need?
  7. A lot of people just weld tabs to the strut tower. You just run a conventional bar with rod ends then.
  8. I have the front bumper from the QLD supplier and it's great.
  9. Someone buy this car already??!!!! How can it be worth the same as a coupe with worn out L-Series! If i didnt have too many projects at the moment i would buy this thing every day of the week!
  10. d3c0y
    L6 DOHC
    I wonder what the chain timing setup is off? I think the way PMC did my RB26 head looks easier, converting the L bottom end to a timing belt and dry sump. That way you don't have to make custom rocker covers either. The chain setup is cool though.
  11. Do what i did, put it up on stands and pull the suspension out. No one is going to steal my Z!
  12. When are you going to do an RB36 stroker kit??
  13. You guys are all talking about the wrong product! I'm not talking about their CV axle kits which are widely known to be shiver! Wolf Creek are now the seller of Beta Motorsports side axles now that Beta Motorsport is no more. They are much better quality than the CVs (i know as i have had a set of the cvs) and are a proven product. The whole development process is over on hybridz. No, but they are about 30 years old and from a performance car. I picked up my 4.3 LSD for $250 which had done just over 100,000kms Range of ratios and centres from the factory - 3.5, 3.9, 4.1, 4.3 Easier to find 4 plate clutch pack in the mechanical centre opposed to 2 in the R200s It weighs 5kg less and an R200 I'm not saying that there is anything wrong with using an R200 and for anyone making really big torque numbers I would go an R200. I'm running a subi setup behind the L34 making 400nm of torque and i think it will survive fine from what i have read. It kinda comes down to this guy's setup more than anything, how much torque, weight and intended use. R200 short nose out of R33 GTS-Ts and Z32 N/As are also a good option.
  14. Like us putting common cooking model Fairlady Z badges on our cars really. We need to set up a badge & grill exchange program with Japan!
  15. Typical, some type of super rare motor sport version of the badge and not the common one haha. I haven't seen the one like yours before, only knew of this one:
  16. Are you going to put the tiller on the other side?
  17. I'm guessing the light ones are probably 240z possibly a series 1 and later ones are 260z. Do they look the same?
  18. Just get a Subaru STi LSD and some Wolf Creek side axels. Bolt in boom! Cheaper and newer than a crappy old R200.
  19. Where's ya JAF badge?
  20. I don't think the engine thing is a big deal at all to be honest. You don't have to pay for an engine that you potentially don't want. Odds on that unless it's an L28 in decent condition it will get swapped out anyway.
  21. Nice, just one last question - when will mine be arriving in the post? I ordered it weeks ago!
  22. Most JDM spec cars even from the start of production came with the mesh grill as it was the base model grill on the 2.0L Z-L and obviously 432s came with the mesh grill too. Fairlady 240Zs had the slat grille as an up-spec'd part on them and are the hot grill to have in Japan.
  23. Yeah hard to believe that's the old red create looking good!
  24. I asked for some pricing but was told I have to call up.
