d3c0y
Everything posted by d3c0y
  1. I agree with that statement. But these ones i dont: L's can go up to 9,000rpm roughly before you're in ridiculous territory. - Maybe a built L24, but any 9000rpm in an L is serious money. Please tell me what i need to build one of these motors To get the same sort of power from a L24 to a L28, you are looking at roughly double (please correct me here if i am wrong)ie. 5k on a L28 will cost you 10k on a L24 for similar power... - Why the parts for either motor are either the same or nearly identical? If the motors can attain the same volumetric efficiency (both Ls why couldnt they?) why would such similar capacities have such a massive difference? CR on PULP (98) i BELEIVE is around 10:1 before pinging??? -Mine runs 11:1 on pump 98 with E85 around 13:1 but for 5k this would be money spent on a lesser HP gain - Can you link me to this E85 L motor you are referring to? and it about the biggest HP boost you will get for you money before you go turbo - What about cam and triples? I'm not trying to be a dick, but there is no need to post stuff you don't seem to know about. Last week you didnt know how and ITB system worked and now you're posting about building L motors for more power?
  2. In standard form a 260 or 280 with the same stoke is a pig of a motor that doesn't like to rev (fact)- He wants to spend money on it so it wont be a standard motor. Despite the fact that a stock L28 is faster than an L24 in the same car (fact) If you spend lots of $ you can make a 280 stoke motor fun. (fact) - You dont need to though and L28 can be a fun motor for cheap, cam and carbs(fact) If you put in a 240 crank and rods you can make a 280 block become a 2575cc motor that will rev easy and be fun motor cheap.(fact) - If you arent spending lots of money it, it will rev to 7500rpm like the rest, be limited by cast pistons and make no torque so it will be slow (fact) So what parts are so wrong. - the ones above Can you confirm how much $ you have spent to make your 280 stoker fun so we can confirm if that part is fact. - As i said with cam and carbs you can have an L28 that revs and is fun and makes more power for less money than an equivalent L24 (fact) AND i have actually built the engine. My L28 build is hardly relevant here. I assure my dog L28 is pretty fun to drive though, although you would probably find it boring since it's got an even bigger stroke than an L28. Do you have a stock motor or built a modified L?
  3. Like some of us said on page 1 of this thread?
  4. Dear Magnet, An L28 with triple 45s, headers, exhaust and a decent cam will make 120rwkw. It will also rev to 7k every day of the week which is the limit of cast pistons. Forged pistons at this power level are a waste and will eat up heaps of your budget. L motors get all their power from head work, better to spend your money there. The L28 makes more power more easily, that's why everyone puts them in. This is so wrong that it makes baby Jeebus cry. Why do you and DreamZ insist on posting stuff that just isn't right? This is two threads now...
  5. What sort of money do you want for the TA22 and what's been done to it? Shoot me a PM Patch they aren't 300kg heavier and you arent putting all of that weight over the front wheels. I had a 2+2 and the steering felt the same as a 2 seater. There is so much bull shit in this thread now...
  6. Something in the steering or suspension must have been warn out. What was the offset of the wheels you were running?
  7. What is the ETA on this thing in and running?
  8. Heavy steering in a Z is 99% of the time due to people putting the wrong offset wheels on them. My zed with 16x8s and 225/50/16s didnt have heavy steering.
  9. You forgot heavier,uglier interior and worth less money too
  10. Have you checked the points gap at all? When did you last change the points?
  11. 3800 i'm guess is the commodore V6? Your shopping list doesn't have any allowance for machining or welding the injector bungs on, a surge tank, efi fuel hose, fuel pressure regulator or air filters.
  12. I'll agree in the fact that it would be salvageable and you could turn it into a tough looking car if you bought it. There are a lot of styling queues that would be changed very quickly if it was mine.
  13. Oh wow i didnt get that far.
  14. d3c0y
    Engine identification
    Isn't this where we all say it's worth what you can get for it?
  15. New contender! http://www.ebay.com/itm/Datsun-Z-Series-Z-1973-datsun-240-z-custom-widebody-z-4-speed-/271330079540?forcerrptr=true&hash=item3f2c887334&item=271330079540&pt=US_Cars_Trucks
  16. d3c0y
    Everyone wants to buy P90s! If you put an N42 on it will have more compression in theory and go better. It's kinda weird to have a P30 with dished pistons too. Maybe someone was using it as a turbo motor? If you are building a motor with a P90 you have to take the low compression into account and generally want a piston that will take up a bit of extra area depending on how far you want to take it. At the end of the day you need to work it all out and see how much the heads have been planed and what your combustion CCs are and what pistons you are running so you can actually work out what it's going to be. A lot of these parts have been modified over their 30 year plus life span. If it's fresh it will get your car running, you just need to figure out what you want short term.
  17. what about the rest of the money?
  18. Gav said with a twin cam head, i'm thinking it would be pretty spirited.
  19. d3c0y
    How tired is the L28? It really depends on what you are after i guess. For me it would be the L28 because it will just make more power.
  20. d3c0y
    If it's a P30 with dish pistons and a P90 head it's going to be slow unless the P90 has had a heap of meat taken off it. It will have ultralow compression. Why dont you put it on an engine stand, tip it up side down and pull the sump off. Then you can see the crank, pull out a piston and check it all out for sure?
  21. Yup the inner ones next to the diff.
  22. Yeah that would work and just put a twin cam head on it same same.
  23. No that is legal as you go off the block not the head!
  24. Anyone got any new rear inner control arm bushes they don't want?
  25. You can't. Carb twin cam RB is illegal.
