d3c0y
Everything posted by d3c0y
  1. I'm in no rush, none of my suspension is even in the car.
  2. You need to interface the crank signal with your ECU. You can use the stock 280ZX distributor but there are better ways to do it. Obviously the ECU cant control anything to do with your ignition if you are just using a normal distributor. PMC's setup most likely uses a modified distributor for crank signal to ECU then some sort of coil on plug setup and an ignitor depending on what ECU you are going for. Maybe you should just fit the factory efi first so you can see how it all works if you are going to do it yourself. No offence but it seems you have a pretty limited knowledge when it comes to engines so you are going to be pushing it to get an off the shelf ITB kit to work. When you start going custom, everything is eleventy times harder. If you can't afford an off the shelf kit, just get a set of 40mm triple carbs. Way more simple to set up and around the same power for what you are talking about.
  3. Doesn't look like you have searched that much at all if all you think you need is an ECU a set of throttles and injectors.
  4. Oh noez i hate that one.
  5. I think it's pretty good too, the design is out there and yet super retro. It is what people have been asking for in some circles and i bet all the P510 forums are rejoicing. The engine seems secondary these days as the FT86's power plant isnt exactly setting the road on fire and to be honest this could be a good thing. Under-powered cars could be what reignites the modified car culture of the 90/early 2000s that some of us lament. If you want these cars to go fast, you have to bolt on a turbo kit to get an acceptable level of performance. If you compare it even to an S30, most of us swap in bigger L28s, put on triple carbs and exhaust systems to get acceptable levels of performance. It really is a throw back in more ways than one if you ask me!
  6. Still need one of these items. Turns out that Nismo's was a 260Z one!
  7. Blow through is for when you are running a carb setup bro.
  8. Hey Matt, that would be awesome. Are you flying to Bris or the GC?
  9. Any ideas on what this would cost to ship to QLD?
  10. Hey Allan, nizm0zed sorted me out and for teh record 260Z is very different to 240Z with this part.
  11. No it's auto but sorry i just realized yours was a 4 door auto. I'm out.
  12. How about a VY S Ute with a Maloo kit and leather SS interior?
  13. Just get an L28 for it, it will be better than any of that mucking around.
  14. Full camel toe shot.
  15. Putting a lower comp head on it will only make the car slower.
  16. Schweet.
  17. So you can choose between Homologation papers or Cams rules, just which ever is the more beneficial right?
  18. Is that car still for sale? Also how does he get away with running 10" rims in 2B? I thought it was a 100mm extra track in total, which would be the total over both sides, or have i read the rules wrong? Do you know what times it runs at Lake Side?
  19. What about the full undertray in the FIA docs above. Or do the cams rules overrule fia homologation?
  20. Can anyone read french :/ ? Fifth image
  21. After a quick search I came up with these and hopefully this is a good start.
  22. 240Z Trip Meter Reset Knob My knob had it's internal splines broken off. It can no longer wind the cable that resets my trip meter and this make me sad not that i can drive it to make the trip meter move. Does any one have a spare in good nick?
  23. They're all cheating so it doesn't matter So Z-Gs, where does 2B stand on them? Cause technically it's a specific model not aftermarket parts just added to the car.
  24. Lol yeah i know that haha, just thought it might be an interesting read. Looks like Targa 5E Modified Sport is a goer too, but no flares seems to be the big thing. I wonder if have flares fitted but run legal wheels where the flares clearly dont do anything whether they will not let me run? This is more a Targa question as in 2B it will be legal to have pointless flares lol. Thanks for all the input too guys.
