Scoota G
Everything posted by Scoota G
  1. Check this thread as the fellow had a 260Z available too. http://www.ebay.com.au/itm/DATSUN-NISSAN-6CYL-L24-L26-240Z-260Z-TRIPLE-40-DCOE-WEBER-CARBY-PACKAGE-/221820279369?&_trksid=p2056016.m2516.l5255
  2. Yer went to edit and computer did a mono! Go figure.
  3. One on the way for a site donation. Good man Tomas
  4. I sent you a PM Iceberg as i have one here.
  5. Looks like that Rhino Liner gear hey!
  6. Ok stay tuned. I have now gone back to the R31 Bracket shortened about 13mm on the stalk and 4mm on the Allen Key bolt. I weld supports on the sides of the bracket bearing in mind that the R31 Handbrake cable clip need to slot in there. I hone out the holes in the brackets with a die grinder to accept the Zed cable. (Welding is to support brackets for honing) I put a more aggressive bend in the R31 handbrake cable clip. I remove the spring from the Zed handbrake cable for full range movement. Then i squeeze the Zed Brackets to suit the pin and fit a thinner (very thin) washer and throw a split pin at it. By now ya'll sayin "dang there's a lot of i's in these instructions" Yes there is, i know there is no I in team but there is an I in Street Weapon Restorations So if you are chasing a kit that is a good price and requires no mods to fit then hit me up. I believe this to be the best combination for this conversion to date.
  7. Run em out the front for twin turbo setup of course. Saaaah tetetetetete.
  8. Hey Dimitri i am actually working on a new system for this too. I'll be in touch.
  9. I read the title and thought you were selling a bunch of them LOL!
  10. I fitted an almost bolt on kit for a 240Z to an Sr20DET powered 200B. I'll find it and tag you if i can. Mark
  11. Update again, based on reclocking the Caliper Brackets on Sam's Zed i have a new design. In the next week i will be offering kits that will resolve issues with having the calipers pointing to the front of the vehicle. Stay tuned!
  12. Dale has one i stuck under his house, Gareth passed it to me. I would suggest reco but.
  13. I have one i'll check condition.
  14. Dale has one i just removed from his parts car. I'll see what he wants for it. Mark
  15. I had an issue recently where the pedal itself was bending. Have you adjusted it inside the cab at the pedal box?
  16. GRS30 is available.
  17. Howdy Mate and welcome. Adam has a vented bonnet for sale on ebay at the moment and is also in Brisbane. http://www.ebay.com.au/itm/Datsun-260z-240z-Vented-Bonnet-With-Vents-/161743515564?&_trksid=p2056016.l4276
  18. I used to run similar weber on all my 1800 engines back in the day. Uber reliable and economy as described was excellent. On a stock l series should be no issue.
  19. If Dimitri doesn't have one i have 2 spare.
  20. Diff mount.
  21. Hey Mark that looks like a transmission mount!
  22. The power gain is pretty flash too and i love the set and forget aspect!
  23. I doubt if they make them for the 280ZX Distributor Mick.
