C.A.R.
Everything posted by C.A.R.
  1. Guess what James...
  2. I wouldn't bother replacing that reverse idler gear unless it has some massive chips running along the length of the teeth. Finding a replacement in better condition will be a challenge. If you want to tidy it up, I'd just run over the burred edges with a diamond file. Popping out of 5th is the result of the steel bulk ring being worn & not having enough preload to 'lock' the coupling sleeve onto the gear, which makes it pop out of 5th. The Porsche style bulk rings are NLA, so you'll have to find a good second hand replacement.
  3. C.A.R.
    Pistons
    Fixed. DattoCam. http://www.viczcar.com/forum/topic/14845-240-260z-pistons/
  4. I owner is a bit of a colorful character. He used to sell 2nd hand cars in Europe & has had more than a few run-ins with organized crime syndicates (mafia) in the EU...
  5. Be prepared to fork out many thousands of $ for rust repairs & a minimum 8k for a decent respray.
  6. No. Late 71B (280ZX & Bluebird) run a LH thread main-shaft nut - they don't come loose. The jumping out of 5th/Rev indicates that the coupling sleeve or the dog ring is badly worn. Time for a rebuild
  7. For someone who is into physics...
  8. I had a look at a gearbox in at Les's today that had the cases off. After a bit of a conflab with Les, we determined that some when you've selected 1st, the selector finger has then moved out of the 1st/2nd rails (who knows how or why) & you've unwittingly selected the 5th/Rev rail. Hence you've selected 2 gear at once which makes the car stall. Something is going on with the selector finger & how it runs in the selector rails. But what I've just typed is all anecdotal anyway... You are still going to pull the box, take it to your mates dad, who still won't find anything, put it back together & give it back to you even though the problem hasn't been found. You'll then be even MORE annoyed that you've spent MORE time & money in not finding the problem, when you should have just taken it to Les to repair in the first place!!!
  9. Definition of insanity: doing the same thing over and over again and expecting a different result.
  10. Who are you taking it to? Pull the box & take it down to Les to sort it out properly.
  11. Happy birthday you long haird hippy!
  12. Go see Richie at Allcraft Automotives in Moorabbin: 9532 2919 He's a RW inspector & is a Datsun guy - he'll be fair & reasonable.
  13. I performed a body restoration on a Beta Zagato Spider a couple of years ago - I now know why they failed... *shudders*
  14. Ohhhh! Jay has finally put them up! The dark grey GT2 has nearly 580hp, while the white GT3 is factory @ 475hp. Makes for an interesting comparison...
  15. C.A.R.
    Mikuni Rebuild Kits
    Call Lou Mondello in Moorabbin.
  16. I've just been informed both have been sold pending pickup.
  17. Just buy a new one, ya tightarse.
  18. Unless you've moved house at during that time, they will still be there... Look harder.
  19. I saw these on another forum I'm on - do not contact me:
