This is a basic tutorial for the removal of the door skin on your Zed.
The only reason you would want to do this is to fix rust in the frame of the door,
Or to perform rust proofing to the inside of the skin or frame.
You might also do this to perform panel beating work.
Tools:
Mig welder
Angle grinder (with wire brush & cutoff disc).
Door skin removal tool.
Clamps
Wooden dolly
Hammer
Before you begin:
Get yourself an old flat blade (wide as possible) screwdriver that you don’t mind ‘butchering’.
With Oxy or propane torch heat the end of the screwdriver till its ‘cherry red’.
Place 10-15mm of the end of the screwdriver in the vice & bend it around as far as you can.
Then hammer the end of the screwdriver around until it’s at 180deg (see pic).
While it's still red hot, drop the end of the screwdriver into some used motor oil - this will have the effect of re-tempering/hardening the end.
This is now your special door skin removing tool!
Step 1:
Strip the door down, remove the window frame followed by the glass, runners & locking mechanisms.
Use the workshop manual as a guide to help you disassemble the door.
Put the door internals out of the way where they won’t be disturbed.
Step 2:
You should now be left with a bare door.
Taking your angle grinder with a wire attached, wire brush the seam around the outside edge of the door where the door is folded over.
At this stage you can buff any other rusty patches on the door
Change to a 1mm cutting disc & cut the two welds at both ends of the door at the top.
This ‘should’ now render the tops of the door free once you’ve finished unpicking the folded seam.
