Showing content with the highest reputation on 03/21/2023 in all areas
  1. And shell is now in 2K Epoxy! how exciting...
    4 points
  2. Hahaha as soon as i saw the photos I was like "HE WAS RIGHT!" sorry totally assuming your gender.....
    1 point
  3. Nice! It looks so much better right?
    1 point
  4. Progress pics of the blasting
    1 point
  5. It's not a show car and once the engine is in you wont be able to see the rattle can colour difference Logic would say to full back half this car but its going to be a drag and drive car with the odd cruise thrown in so close to stock/sleeper look is important. Biggest tyre that can be fitted is 235/60/15 which is 26 inches tall and it only just fits in the standard guards, a taller tyre would need the guards lengthened and a mini tub isnt worth it as there isnt much to gain without doing a full rail reaplacement. The lips on the guards are really susbstantial and just couldnt be rolled so resorted to slicing and hammering, came up really well with no external marks and with a clean up and seam seal and rattle can paint will be good. Position of the rear axle will be critical as there is only 10-15mm clearance at front and rear of guard opening and likewise the same for inner and outer guard. We are going to use the standard 4 link/panhard suspension but all of this is now junk. 9 inch has been sourced and will use cromo rod ended bars on the standard pickup points but will build some adjustatbility into it them and also the diff brackets to hopefully get sufficient separation so it 60's reasonably.
    1 point
