So I needed to make a proper transportation Pre-rotisserie Jig. No more jackstands! Made from 50x50 Mild steel.
Found some schematics online and followed them. Naturally, the measurements were a little wrong, so I did need to adjust as i went. It bolts to the base with 4 brackets. Connects to the front & rear diff mounts, gearbox crossmember mount, and when the front clip it is, there's a provision there for the engine crossmember too. Pretty happy with how it turned out, was a little fiddly but its pretty square all around. (+-2mm). Took me around 12~ hours to make.
Its definitely nice to manoeuvre the car around the garage very easily!
Now i can get to finishing off the firewall patch and floors. I also dropped off all my running gear to Stewart Wilkins motorsport for a full restoration.
