(Locky) Posted April 24, 2009 Posted April 24, 2009 hi I've been a long time admirer of the 240z's. they have been the "old" car that I've always wanted to do up. I'm about to get off my P's and need another car, so it might be the right time for the Z i checked out one last night, needs a bit of work, but I'm fairly keen on it. plan is for now to give it a backyard spray and get it running. Then just get it regoed and have something to get to work in. Long term probably sort the brakes and suspension out and maybe even a SR So far Ive been into mostly silvia's on my 3rd one atm and drifting, but my latest s14 has turned into too much of a track car for a daily before ive even driven it I know how to swing a spanner and have done everything but the welding on my s14. but i know nothing much about Z specifics so pretty much ill be annoying with dumb questions first annoying question, is there anyway to quickly diferentiate a L24 and L28 by looking at it anyway, heres my old/current cars, and hopefully there be a Z to add there soon Quote
reverendzed Posted April 24, 2009 Posted April 24, 2009 Hey locky...welcome to the forums. It would be a good idea to fill in where you are from this will help the other guys who mar be able to help you with info that you may require....once you Zed there's no going back! Rev. Quote
chris240 Posted April 24, 2009 Posted April 24, 2009 welcome.. look for stamp on side of block...(drivers side if I remember correctly ) Quote
xa1973 Posted April 24, 2009 Posted April 24, 2009 Hello Mate and welcome What model and year is the burgundy jobbie Cheers Quote
(Locky) Posted April 24, 2009 Author Posted April 24, 2009 thanks so pretty much the engine number is the only/easiest way to tell, will be like L28XXXXXXX or something like that the red/burgandy/white one was a '90 180sx, had a CA turbo in it. was pretty much a track car because i couldnt drive turbo under p plates. the shiraz/purple one is a '97 series 2 s14/200sx and that my current car. was intended to be daily/track but i havent even driven it and pretty much every suspension componant has been replaced, full bolt in cage ect.... gets defect every 2nd time its been driven Quote
xa1973 Posted April 24, 2009 Posted April 24, 2009 the shiraz/purple one is a '97 series 2 s14/200sx ect.... gets defect every 2nd time its been driven Thanks Mate Hmmmm...I like the shape, off hand ball park $$$, what are they worth.... it would seem constable dribble and officer plod havn't got anything better to do with their time..... Cheers Quote
luke_mcmahon85 Posted April 25, 2009 Posted April 25, 2009 with regard to the l24 vs l28, it's best way is to lock at block stamping - n42 and f54 is an l28. You can look at head stamping, but the head may not be the original (they're interchangable between l24, l26, l28). Quote
S30Mike Posted April 25, 2009 Posted April 25, 2009 Hey Locky! good to see you signed up here. If your going to the JDMST Eomm next thursday come and say hi and i would be happy to show you a few things! Quote
(Locky) Posted April 25, 2009 Author Posted April 25, 2009 the s2 s14 usually go for low teens for a stock one mine was rough and pretty much stock, so i picked it up for less than 10, (not the best example of one, but ive changed alot of the stuff on it already) yeah thought id sign up and learn a lil before i go ahead with a car purchase, and i wont be gong to the Eomm because ive got no licence, only 1 month to go Quote
Moderators Zedman240® Posted April 28, 2009 Moderators Posted April 28, 2009 Well done! As by law pics HAVE to be posted.... Quote
fufu Posted April 28, 2009 Posted April 28, 2009 LOL I'm just stirring stuff in your jdmst ride thread. Glad to see you've got the zed bug. Now it's time to surrender you blood, sweat and tears into this zed. Quote
Administrators gav240z Posted April 28, 2009 Administrators Posted April 28, 2009 Pics!!!! We are Z Voyeurs after all. Quote
(Locky) Posted April 28, 2009 Author Posted April 28, 2009 needs a bit of work, but most of the parts are included with the car, (just needs F&R bumpers and a few lil bits and pieces for the engine) 240 with a L28 (still need to doubl check the engine to confirm) it will be good to tinker with, ive done alot on my s14 but the engine is something im still a lil wary of, so a carbie is something good to get my head around learn by reading, researching then doing is basically what ive been doing and am going to keep giving it a go Quote
C.A.R. Posted April 28, 2009 Posted April 28, 2009 Congrats. Where & how did you come across it? Quote
lightmaster240z Posted April 28, 2009 Posted April 28, 2009 welcome and thanl you for the new Zpron ;D Quote
Moderators Zedman240® Posted April 28, 2009 Moderators Posted April 28, 2009 You're off to a good start with that! Good engine and carbies to start with. Have you checked the chassis for rust thoroughly? You'll find how trouble free they run when its all setup right. I see the rod you're missing; the one from the firewall to the carbs. I may have a spare one kicking about. I'll check over the next few days and let you know. Quote
(Locky) Posted April 28, 2009 Author Posted April 28, 2009 yeah when i checked it out the only rust i saw was about the size of a 50c piece in the boot floor looks like its had a patch up on the drivers side door sil and doesnt really have rust in the usual spots from what ive read it was parked in a corner with stuff all around it, but before i pick it up, its going to get jacked up to check the undercarrage ect just found a number saying they were selling a Z on a forum, was local so i checked it out yes if you have that rod that would be extremly helpful pritty much i need the rod between the accelerator point on the firewall and that linkage on the carb. Filter box Front and rear bumper please let me know if youve got these Quote
Moderators Zedman240® Posted April 29, 2009 Moderators Posted April 29, 2009 The rod I think is no problem but airbox/bumpers are on my car so I cant give them away sorry! I'm still trying to locate a front bar as well for my 2+2. Quote
(Locky) Posted April 29, 2009 Author Posted April 29, 2009 no probs if you do have it, let me know how much you want for it and is someone has some of those parts laying around the shed, let me know please Quote
RBZ 260 Posted April 29, 2009 Posted April 29, 2009 for engine designation its same as sr20 on the side of the block just reads l24, l26, l28. with the engine number behind it. other than that quickest will be to learn the codes stamped on the side of the block that corresponds to the capacity of the engine like someone mentioned above. i got a s2 s14 as well u will like the 240z it will be different to the S14 bit more scary and more fun but not that comfortable or nice for long distance as the S14. than again u got a drift car so be pretty close Quote
zedevan Posted April 29, 2009 Posted April 29, 2009 Cognrats, whats your plans for it? Buy carbon bumpers...you know you want to Quote
