As the title states, I'm after an e88 head. If you have an engine with the e88 head and don't want to separate them, I may consider taking the whole lot. I would also be interested in an F54 or N42 block.
Cheers,
Shaun
Which E88 head? The early carby head or later skyline EFI one?
I should have mentioned this up front. The EFI head would be great. I'd be willing to take either early carby of late EFI.
The E88 and E88 EFI heads are quite different beasts. Small ports and valves with large chamber versus big ports and valves with small chamber. The E88 is comparatively plentiful, the EFI, not so.
Mike260LW don't forget about me ;P
Posted (edited)
Hi Mike,
Just a quick one as I have both the early E88 from a L26 open chamber and a E88 EFI closed chamber and the ports from what I can tell are the same apart from the injector cut outs?
Both have 36mm intake ports, I do know that there are a few different E88 heads though.
Justin
Edited by 600Z
I'm aware of 3 versions.
1. Early 240z E88 head (similar chamber to E31)
2. Mid 260z E88 open chamber head.
3. Late MR30 Skyline E88 EFI head with same chamber shape as P90 / 05L heads and cut out's for F.I.
Hi Gav,
Yes there the three I'm aware of as well though I thought the port sizes are the same across them but could be wrong.
Justin
Hi Mike,
Justin
Agree. I stand corrected. I thought the valves and ports were different on the 260z E88 and MR 30 E88 but just went and measured both and they the same. It's all in the combustion chamber c.c. If you were chasing compression and chamber shape it would probably be simpler to weld up and reprofile a P 90 head if your not restricted by rules.
Hi Mike,
All good I was thinking bugger should I be looking for another one with bigger ports lol
Yes from what I read the P90 heads flow pretty well from factory.
Posted (edited)
The Skyline EFI heads had both open chamber and closed chamber heads.
You had to be lucky to come across one!
The EFI heads will have the hardened valve seats which are compatible with unleaded fuels.
I'm not sure if the 260Z, E88 heads had valve seats that are suitable for unleaded fuel.
Edited by road rider
