zzzzed Posted April 7, 2015 Posted April 7, 2015 Something has come up so I have to let go of my track car. Here is the write up. Engine: RB25 Pistons:forged JE 10.5 comp ratio Rods:spool/ARP 2000 rod bolts Injection: 2000CC Bosch injectors/E85 with Turbosmart FPR1200 regulator Twin wilbora pumps with carter black lift pump/2ltr surge tank/custom swirl pot on bottom of stock tank Head:Valves recut 3 ways Heavier valve springs Cams 256/256 8.5 lift Pon cams Oil system: 7.5 Ltr custom baffled sump. N1 oil pump with billet gears/crank collar spool. 3 qrt accusump with non return valve at oil filter. Oil cooler with remote filter. Rear spool head drain. Savage pump on oil catch can. Turbo GTX35R ball bearing/.86 Rear housing. ECU: Haltech platinum with Haltech Dash/ have Topstage Composites dash to be installed in carbon fiber to go with the car. Microtech X6 ignighter pack with Bosch coil packs. Trans:custom clutch single plate 3200 pound direct clutch services Stock RB25 transmission. Diff: custom Long nose LSD centre from S13 Silvia. Custom mounted diff. Wolf Creek Racing half shafts Suspension: Arizona zed car race adjustable struts. WRX STI power steering rack 2.5 turns lock to lock. Adjustable A arms Adjustable caster rods Teckno toy rear adjustable Rear lower control arms. Brakes: front 6 piston willwood calipers/315mm rotors Rear 4 piston willwood rotors/295 mm Willwood brake bias controller Master cylinder 15/16" 280zx Booster R33 skyline duel diaphragmed type. Roll Cage: 6 point Seat: Race Tech / 5 point harness Aero: front splitter Topstage V2 Rear splitter and spoiler Topstage in carbon Fiber. Flares dry carbon $30,000 May swap for road regoed 2 seater of the same value Quote
zzzzed Posted April 7, 2015 Author Posted April 7, 2015 What!! Why??? Trying to start a bussiness Quote
Lbert96 Posted April 8, 2015 Posted April 8, 2015 what is the least you would take for the car ? Quote
Administrators gav240z Posted April 8, 2015 Administrators Posted April 8, 2015 what is the least you would take for the car ? What is the most you'd pay for it? @Knackers - good luck with the new business it must be a hard decision and a very brave 1 at that. I hope it works out and you get a chance to build or buy another similar car in future. Quote
zzzzed Posted April 8, 2015 Author Posted April 8, 2015 what is the least you would take for the car ? What gav said. The car is sold pending payment Thanx gav. The business is a scary venture that is for sure But all I can do is take it one step at a time. As for building another car. My blue 2 seater will be getting all the love now it will be built as a road / track / show car. And just general fun machine. If my business takes off I my build another car dedicated for the track. Maybe something a a bit easier to build and find parts for like a r32. But that won't be untill after my 2 seater is close to how I want it. Quote
260DET Posted April 9, 2015 Posted April 9, 2015 Sounds like it's going to Sidiney, good luck with the business venture. Quote
zzzzed Posted April 9, 2015 Author Posted April 9, 2015 Sounds like it's going to Sidiney, good luck with the business venture. Back to brizzy I think Quote
lightmaster240z Posted April 9, 2015 Posted April 9, 2015 good luck with both the sale and the new adventure Quote
260DET Posted April 10, 2015 Posted April 10, 2015 Good luck with everything Hope it does come back to Q and the buyer tracks it. Quote
zzzzed Posted April 10, 2015 Author Posted April 10, 2015 Well the buyer has fallen of the earth so it is up for sale again Quote
cracker Posted April 11, 2015 Posted April 11, 2015 What sort of road reg'd 2 seater would you be after? (I'm guessing not another zed?) Quote
zzzzed Posted April 11, 2015 Author Posted April 11, 2015 What sort of road reg'd 2 seater would you be after? (I'm guessing not another zed?) 240z,260z, fairlady roadster, gtr skyline any thing that is going to hold its value The main reason is that a road registered car may be easier to sell. So what ever the swap may be it would go straight back on the meerkat. However cash is much preferred Quote
260DET Posted June 19, 2015 Posted June 19, 2015 Bit of a bump, still for sale? Seems to be very good value to me. Quote
zzzzed Posted June 19, 2015 Author Posted June 19, 2015 Not for sale anymore. I am keeping it and heading in a different direction. Quote
rajon1972 Posted July 17, 2015 Posted July 17, 2015 Hey mate, are you still considering selling this car? Quote
dat2kman Posted July 17, 2015 Posted July 17, 2015 Hey mate, are you still considering selling this car? Do you want a decent track car, that can also be put on club rego, for tarmac use? Also able to be used at a greater range of events! Quote
zzzzed Posted July 17, 2015 Author Posted July 17, 2015 Do you want a decent track car, that can also be put on club rego, for tarmac use? Also able to be used at a greater range of events! Ouch. I am actually doing all of what you mentioned above to mine right now. Yes it's going back to L series. Quote
