240z / 260z replacement engine bay & Floor rails, Now available S.A.
146 replies to this topic
#1 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 30 October 2012 - 10:55 PM
Hi all,
I Have some high strength steel im making some of my own chassis rails in the engine bay, (finish where the floor rail covers it near the TC rod Bracket, bottom of firewall)
from firewall to rad support, direct factory replacements from slightly heavier gauge steel, and still of high strength.
these units have all the holes say a 240z and earlier 260z 2 seater have, including holes for the splash tray, sway bar, tow hooks and engine cross member.
these will require the skills of a panelbeater or LURCH to install, but are made for the utmost purist, as they have been designed with originality in mind, not like some others available from USA.
I only have pics of my preliminary rails thus far, more pics will be up in the next week or so, will keep posted, but for now, see attached,
also note they include the tappered down area near the radiator as per stock rails, remember these are to try and be as close to std spec as possible,
also includes original JIG/tooling holes for measurment and positioning.
pricing is solely dependant on demand, if I make 5 lh and 5 rh then dont expect any more, unless tabco want to buy/distrubute them.....
These rails DO require the re-use of?
- existing TC/Castor rod brackets
- Floor rails unless you  need  these too.
- inner skirt & strut tower (inner wheel fender/guard)
I am/will be using these on my car/s, for race / events etc, and since wittnessing the stock rails support, is mandatory as far as i see,
these will be manufactured using CNC equipment and every rail WILL be the same.
any Q's
please ask, but dont bother me with a stack of questions if you do not intend to buy or are genuinley not interested.
apologies for those whom are inquisitive by nature,
only offering these, as I NEED them myself, only fair to see if I can help out others.
Now please also consider that this Higher strength steel is expensive, so youre not buying cheap off the shelf folded section with no strength.
Have material certs available if you are interested.
nat0
  • effinnaenexia likes this
#2 KatoKid
KatoKid
  • 1,721 posts
Posted 31 October 2012 - 08:11 AM
Very nice nat0.
Im keen to grab a set....... depending on cost.
David
#3 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 31 October 2012 - 06:14 PM
first real set/pair knocked up from G450 med-high tensile sheet,
they come up well pics coming soon.....
nat0
#4 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 05 November 2012 - 08:35 PM
more pics of fitment,
not something you want to install yourself, but by all means any competent panel beater or restorer can easilly install.
Pricing not yet fixed although from estimating mat'l cost along with laser cutting, Pressing, Welding /finishing and fastener installations etc
If I get 5 pairs (or 10 individuals) or so, bill in bulk for time spent on them,
price per rail will be $ POA each,
rails will include nuts and re-inforcing plates similar or same as the factory items.
These rails are bloody strong even with out the other half attached, unlike my stock rails I am able to bend/flex them with muscle only.
Under floor rails are also available
Have 1 pair available now 5/11/2012, ex Adelaide.
Postage cost wholly & solely at buyers expense, happy for group buy or similar.
Any questions please contact me either PM or email, can offer mobile contact details after contact is made.
get them now, as they may/will not always be available.
these things take a while to make,
appreciate any feedback or special requests.
cheers Nat0
nat0zparts@adam.com.au
#5 munters
munters
    Member
  • PipPip
  • 14 posts
Posted 06 November 2012 - 10:04 PM
Nice work
Do you consider of doing more Body parts?
Like
REINF HOOD ASSY
OEM Part NO.: 64150-N4501
Inner fender
Thganks
Marcel
#6 Zedback
Zedback
  • 283 posts
  • Tagline:Mike
Posted 07 November 2012 - 06:51 PM
Very nice.  Would be keen on a pair (L+R).
Any plans for a matching lower radiator support?
#7 Agno
Agno
  • 1,334 posts
Posted 07 November 2012 - 07:00 PM
Dang, right product at the wrong time for me! Posting so I remember this
#8 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 07 November 2012 - 08:12 PM
funny you mention,
I will be making one at some stage, depending how i go salvaging 1 out of 3 mediochre ones,
but I have already begun development of the lower rad support as it is a pretty common flaw, ie frontal impact of any sorts.......
It will be a 2 piece unit, similar to as the factory ones, currently working on ideas to replicate the basic tooling to give the pressed/rolled edges to the large slots on the 240z item.
260z lower rad sup't is significantly lower, in height offset, but it would not be too much extra work to get this extra offset.
Watch this space......
Hi Munters, no not anticipating to have to make this from scratch, although it is a very important item on the Z front end, best sourced from a donor car I feel,
If it is the RHS one your after, I may have a suitable 260z 2+2 item I coul un-pick, but seeing your location, it would be best to source one locally.
I could make something similar, but it would not look the same as it would be quite square and boxy looking, but you never know whats around the corner.
this piece you are after is also a relatively high strength material also, as its a bitch to panel beat, I do have some 0.9mm G450 sheet id doubt id be able to form these 3d shapes,
cheers for the request none the less.... maybe if you bought a pair of rails, then postage of a secends fender might not be too bad??
#9 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 07 November 2012 - 08:15 PM
oh yea i forgot to mention I got a video of the cutting of the blanks for these rails,
havent posted it up on youtube yet but Ill do it soon, link to be edited in below or in original post.
PS internal re-inforcement plates drafted up today, 1st offs coming this week!!!! ;)
nat0
#10 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 12 November 2012 - 05:59 PM
Hi Guys, looking to run these and have completed by end of this week,
Please, please please, let me know and ill send you the details if you are serious,
Finding parts like this will be few and far between, I do hope this gets out for all to read,
MODS, please re-post in FOR SALE section if at all possible??
Re-inforcement parts are done with all high tensile nuts etc,
Anyone have any last request or any interest, as I can not guarantee these will come up again,
unless a bulk/group buy order is brought together by you guys yourselves or otherwise hybridz or classicZcar ???
Get the word out or curse me forever,
cheers Nathan
remove dashes from below email address, (damn spam Bots!!!!)
natO-z-parts@-adam-.com-.-au-  ( 0= Zero in Nat0 incase it looks like an O for orange, should have thought of these when I created it.)
#11 Zedback
Zedback
  • 283 posts
  • Tagline:Mike
Posted 12 November 2012 - 07:35 PM
I'm in - email sent.
#12 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 15 November 2012 - 05:52 PM
first pair is Complete.
others are cut and inline for pressing this weekend.
All go, if you will need these in future, or want to stash them away for a rainy day, then I suggest you do so as, I will not guarantee their availabilty going forward.
cheers again guys,
Nat0
#13 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 24 November 2012 - 08:49 AM
ok 4 pairs of rails completed,
2 pairs still available.
Under floor rail supports either std or full length will also be available for the 240z shortly.
amongst other bits to come along.
get in contact if you require, not just now but maybe down the track.
nat0
#14 Napes94
Napes94
    Member
  • PipPip
  • 11 posts
Posted 14 January 2013 - 11:37 PM
Is it still possible to get a set of early 74 260z chassis rails in engine bay made up?
Is it also possible to get a complete front rad support made up also/ including front cross member?
Desperately in need of one. My car's front end is only where the rust is and this is my last option.
Please help?
regards Napes94
#15 Veloce
Veloce
  • 119 posts
Posted 16 January 2013 - 03:36 PM
How are the full length under floor rails coming along? I like the Bad Dog rails but as always, shipping from the states is a killer...
#16 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 16 January 2013 - 06:24 PM
almost there, working on them now, had a lil hicup with some older ones, almost there.......
the mockup rear connectors fit both my 240's well,
I just had a change of heart due to ease of installation and effectivenes, on some areas which were a PITA to actually manufacture.
hope to have pics and trial fit pics up by about australia day...
nat0
#17 Veloce
Veloce
  • 119 posts
Posted 17 January 2013 - 09:15 AM
Good stuff, i'll be after a set for sure. Will the ID of your rails allow welding over the existing rails or will the originals need to be removed?
#18 260DET
260DET
  • 2,308 posts
  • Tagline:Tribal Elder
Posted 17 January 2013 - 10:11 AM
I love enterprise, if they are a good product at the right price they will sell. S30's are going to be around for a long time, as they get scarcer and more expensive these sorts of items will be in increasing demand.
#19 gilltech
gilltech
  • Donating Members
  • 1,231 posts
Posted 17 January 2013 - 07:33 PM
Ditto I'd be keen for one of those should you get to it, my early 260 is the same as the 240 one. Mine's dented & out of shape so I'd rather replace it entirely rather than fix it. And I wouldn't be too fussy about the exact shape of the slots at the back, either, they're mostly covered by the radiator.
#20 Napes94
Napes94
    Member
  • PipPip
  • 11 posts
Posted 20 January 2013 - 02:39 AM
id be interested in a set of under floor chassis rails also for my early 260z. mine have a few rust holes and need to be completely removed.
Can you please PM me a response and cost?
regards Napes94
