Zedsabbath
Everything posted by Zedsabbath
  1. Yes don't use Pack & Send what ever you do, not for windscreens anyway...mine arrived today in three pieces, $170 freight down the drain... labeling had "Glass" "Fragile" in clear view but TNT still found a way to smash it The search goes on for another one...any zed owner here in Sydney know of a Novus franchise that has them ?
  2. Cheaper than Pack & Send I think Pete
  3. Do you want to sell the windscreen ? looks like it'll fit my 240 Pete
  4. I'd be more concerned about the loose ones, under operating temperature the piston pin bores expand and that will make the loose ones even looser...If you can get movement out of the tight ones by hand, I'd leave them The movement from left to right doesn't mean all that much, it's the rotational movement of the pin in the piston you should check, it should be fairly free without being so tight that you need a hammer to move the rod It sounds like the engine wasn't fully run in
  5. Is that your windscreen on ebay Dave ? got a chip and all Pete PS your's still available ?
  6. Will that windscreen fit a 240, what condition is it in Dave ?
  7. One power antenna, $30 two days to go http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220661459742&ssPageName=STRK:MEWAX:IT#ht_500wt_1182
  8. Welcome Zac, I'm a newbie here as well and trying my best to assist other members both veteran and new...it's the least I can do given the help I've received so far Keep that "lack of resistance" illness going Zac, bring home the baconz any time you wish Pete
  9. Sure will zaxzeds, I'm busy making moulds for rubber parts at the moment but will contact you sometime for a chat, I'm not all that far from Penrith Pete
  10. " number 1 looked blacker than the rest. What would that mean?" It means it's not firing adequately....change it or change all of them for new ones and keep an eye on that number one cylinder in case that happens again If your plugs keep fouling, you might have a ring problem or worn valve seals Pete
  11. Also look for a bad wiring connection in the ignition system
  12. An oiled up plug can have that effect, also it's not unknown for plugs to be faulty from new...lift the plug leads off one at a time and listen for a change in revs, other than that, when you remove the plugs look to see if one or more are blacker than the rest
  13. http://cgi.ebay.com/ebaymotors/Datsun-240Z-260Z-280Z-Electric-Antenna-Assembly-_W0QQcmdZViewItemQQhashZitem2eaf83fa1eQQitemZ200513157662QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1754wt_941 Antenna in the US...make an offer, this dealer is OK in my books, dealt with him before Pete
  14. Hi Z, yep I've started the passengers side mould and will concentrate on it to get it finished pronto Pete
  15. There's a vacuum in my head for attempting them in the first place Salty but there's no turning back now...I've tried 5 ways of pouring and pressure feeding is best so far The bubbles I mentioned about before were really air locks that prevented the liquid from flowing fully throughout the whole mould cavity, I've overcome that problem Trouble is there's limited time once the agents are mixed together, gotta get it into the mould as quickly as I can Thanks mate - Pete
  16. Check the tappet clearances Mark, not just your valves moving up and down, correct clearances are important for smooth running Check the level of coolant in the radiator, a cracked head or block can cause misfiring from water finding it's way into cylinders Replace the spark plug leads Pete
  17. Welcome Mark, quiet night here tonight, they're all down the pub, a beer in hand and watching footing I think
  18. Success at last !
  19. G'day AussieZed, will you be selling more parts ? I need the lower half of the bonnet catch...and a windscreen, subject to condition
  20. Swap your Zed for this ? hehe
  21. I'll save you the trouble Scoot.... The first pic shows the cavity where the hinge fits in....the second pic shows how the boot fits (I've used one of the defective reject boots , just out of the mould the other day, notice there's no bolt holes yet)....the third pic shows the boot reinforcer.... the forth pic shows the hinge The boots keep water out Pete
  22. Up date on progress of hinge boots.... Modification to first mould is finished, works fine and I've actually made 3 boots so far but all have defects of one sort or another, that's not unusual for first 2 or 3, the only remaining problematic issue is the pouring technique...manually pouring is causing unacceptable air bubbles so I'm going to try pressure injection using a simple throwaway plastic syringe...no rude comments now I placed the least defective boot in the car and it fits perfectly, so I'm happy about that The second mould has been started Pete
  23. "hatch boot reinforcers (if you've got them).......................... gold, these are not the door adjusting shims, they keep boot flange in place" Don't think I explained that properly....it's possible that a lot of boot reinforcers got tossed or just simply left off the car but if we start from the body, the parts for the boots and hinges in their order are..... the body the boot the reinforcer the door adjusting shim the hinge The Reinforcer is a thin metal part shaped at right angles and covers the whole outer flange of the boot to to keep the rubber flange in shape and prevent moisture entering the cavity in the body for the hinge ...it also acts as a solid base for the adjusting shim and or hinge to squeeze against once the bolts are tightened Pete
  24. Just looking at my unrestored bits and pieces here... door catches ..................................................................... silver hatch stoppers (with the nylon blocks in them)................... silver hatch stopper wedges........................................................ silver hatch hinges ..................................................................... silver hatch catch (both parts)..................................................... silver dip stick ............................................................................ looks to be silver but gold can look neat carby linkages, quadrants and brackets .............................. gold fuel cap and mating base ................................................... gold bonnet catch (both parts) .................................................. gold hatch boot reinforcers (if you've got them).......................... gold, these are not the door adjusting shims, they keep boot flange in place trouble light....................................................................... gold That's it for the moment Pete
  25. That may be a regulator...but internal (or semi internal) regulators usually have the spring loaded slip ring brushes attached to it and you just unscrew the old one from the outside of the alternator then screw the new one on...no wires or plugs You might also need to get the diodes checked, they don't last and when they go kapoot the red light comes on
