zeds4ever
  1. ilbert : PM replied to. Regards : Alan .
  2. All prices are pstge cost included . Gauge lghts dimmer , works OK. $35.00 (sold) "Sard" fuel pressure gauge , works OK . $25.00 260Z Elctrc fuel pump low prsre unit , works OK . $25.00 260Z / 260Z 2+2 / 240Z?. Upper door hinges , firm pins . $55.00 pr. 260Z / 260Z 2+2 / 240Z?. Rear hatch hinges , firm pins $55.00 pr. (sold) Temp/Oil gauge & Volts/Fuel gauges , work OK. $55.00 ea. Both (sold)
  3. Sad to hear mate , especially after spending so many hrs on it . I reckon you will back up again in the the not to distant future when you find a more viable car . Regards : Alan .
  4. Need to get the retractable set up on my seat belts reset . After refurbishing the internals . Regards : Alan .
  5. PM sent Re: Grille.
  6. My Z parts man Carlos informed me that he has sets of 14" X 6" Jelly bean wheels for about $250 for four , also Hotwires for $300 same size . Contact him on Mob : 0418 284 776 Regards : Alan .
  7. G'day Anthony , you do realize that there are a Series1 early model & a Series2 later version that operate via a different ECU set up . Also the resistors for the fuel injectors are located in different areas , not sure if there are two different manifolds as well . Whats wrong with the harness you have if you have one. Regards : Alan .
  8. No prob's mate , misunderstood meaning of " as long as ECU connected is in good shape ". I 'm off to my parts man Carlos tomorrow , will see what he might have there for you . Regards : Alan .
  9. Are you seeking an ECU as well ? . Regards :Alan.
  10. G'day Pete , I find it hard to believe that someone would go to so much trouble to stuff up a wiring harness as much as the previous owner has . It's been a bloody nightmare sorting it out & many thanks to NZedder for the wiring diag he sent me it helped me no end to sort the mess out & you of course . Regards : Alan.
  11. Only just met you Craig , so I'm yet to find out how far your powers extend . Should imagine pretty widespread!!. Regards : Alan .
  12. OK mate , let me know when our new toys arrive & I'll bring them down then . Regards : Alan .
  13. No prob's Gavin , can work cost difference out with plastic welder . If your happy with that can drop them off for you one day . Regards : Alan .
  14. Fortunately all the fallen trees & debri had been removed prior to our arrival ,so evidently Craig has a bit of pull up that way with the locals .LOL. I'm sure there will be other days in the not to distant future with warmer weather to boot when another run will be in the offing. Till then stay safe . Regards : Alan.
  15. G'day Tony , mate I would venture to say early next year as I want it to be 100% right . Regards : Alan .
  16. Had the pleasure of accompanying Tony to Tarana in his great 73/240Z , this drive had been arranged by the "SYDNEY " Zcar club . What a great experience to be in this car & enjoy the moment even tho I was only a passenger . My thanks to Craig Tebett for the invite & especially Tony for his kindness in taking me . It has given me the incentive to finally finish my pride & joy . Regards : Alan. Here are a cple of pic's :
  17. Finally found the solution , turns out that one of the two ground wires I found cut short should travel up to the section near where the main ground wire is situated & connects to the white wire that is installed in the indicator stem . The other black wire I mentioned in a previous posting turned out to be the other half to the A/T kick down switch . Thanks for your input fella's much appreciated. Regards : Alan
  18. Have the following parts for sale : Can post at your cost or arrange pick up Sydney area . 280ZX Series1 rear brake unit excluding calipers with new internal rubber kit , brand new milled hanging brkt , brand new 280ZX rotors , plus front 280ZX calipers. Also backing plates.$200 Complete. . Matching Pr Hitachi 1.3/4" Carbie's , would need a new kit , butterfly spindles are xclnt , water channels are clean with no blockages . $75.00 Pr. (sold) Various gauges in reasonable condition for age . $20.00 Ea. (2)Deffoger & defogger lght sold. ? 260Z / 260 2+2 Hood hinge in good condition . $50.00 (sold) 260Z / 260 2+2 Tail lights L&R in good condition with no cracks . $80.00 Pr (sold) Ford XB? Throttle body in good condition. $40.00 (sold) attachment=147612:IMG_1487-001.JPG] Regards : Alan .
  19. Thanks Tony for the opportunity mate , looking forward to the day . Regards : Alan.
  20. Have Srs1 280ZX rear brake set up with new rubber kit to install . Includes milled attachment brkt from Les Collins + backing plates & brand new 280ZX rotors . You will need calipers to complete the set up. Also have 280ZX front calipers complete but will need a new internal rubber kit . PM me if interested . Regards : Alan .
  21. Four spline , large!!. .
  22. That's good Jake , as it turns out the units I have are the four pin type. Regards : Alan .
  23. PM sent.
  24. Hi Peter , yes the passing switch becomes a ground set up when you press the button at the top of the indicator switch . If I didn't receive a positive reply it was my intention to connect the pass wire to the high beam wire on the dimmer switch unit. Thanks for your reply mate I shall wait to hear back from you before I do this however. Regards : Alan .
  25. Noticed 240Z71 has a grille for sale amongst his stuff. See for sale section. Regards : Alan.
