882 -
1
G'day mate , sorry for the late response but the part that is broken is the unit that helps to assist with the vacuum advance unit it's common with all zeds. SxlSushi imprted some almnm brkr plate alternatives from the States but claimed they were xpnsve however if you buy the originals from Japan they are twice the cost & you will eventually get the same problem. You can get re-built dissie's from the States but getting them shipped over is XPNSVE , bloody postage mob. I'm still mucking round with making a plate up that should work hopefully, just finding time to do it properly is the problem. Regards: Alan.
It would appear that my indctr canister flasher unit which is situated under dash has died is there an alternative unit I can use in its place, also intend to change hazard unit while i'm at it so same qstn. Regards: Alan.
Finally getting round to securing rear spoiler , I have access to internals of spoiler where I intend to use flat almnm bars on the inside with nuts n bolts as part of fitment to boot lid . However I also want to use a flexible silicone that is wtrproof & also reasonably strong to assist with securing also.. Do not want to use any slcne that dries hard like Silkaflex as I have found that this occurs with this product. Also will I need to grind paint off where I use slcne. Suggestions please fella's. Regards: Alan.
;)Just to fill in the missing gaps, spoke to Techo from RTA who informed that Spacers & anything that is not provided by Mnftcr people are not permissible. He stated that as long as the wheel/tires do not touch the struts etc that this is OK. I gained the clrnce I required by hammering the spring retaining unit back in slightly & then ground it a little bit so that I gained the required clrnce , it was very minimal so that there is no safety factors to be concerned with. Might also add that camber adjusters do change the distance of the wheel to the strut,when the camber is adjusted to give you neg postn on wheel it increases clrnce from strut. Regards: Alan.
Thanx for the feed back gentlemen, much appreciated. By the way I read the article in a car magazine some time back regarding the time factor. Regards: Alan.
:(Now that I have decided to remove the Spoke wheels I'm contemplating on using the tires off them on the rims that will replace them.Problem is I had these tires fitted back in 2006 & these have not been on the road as yet. Have read articles that state that if a tire is over six years age it should not be used on a vehicle.Your thoughts please fella's. Regards: Alan.
That's funny , earlier on you were stating that you should always check wheels for correct fitting ,etc . Isn't this a contradiction to that statement. Oh well. LOL. Only kidding mate. I've come up with another idea & this is to relocate the three securing units for the strut caps further back in the Strut housing & then re-set the camber on them , only need about 6mm to get the clearance I need. How do you think this will go fella's. I've also mnged to locate a set of Cheviot mag wheels only 6" tho, & at my age size doesn't matter Ha Ha also there are five of them & at 100 bucks are shite cheap.But as Paul say's I am wrapped in the spoke wheels & would like to persevere with them. Regards: Alan.
G'day Michael, if it's the same as the 260Z might be able to help. You can have it for pstge cost if I can find the bloody thing. Regards: Alan.
Did Datsun ever mnfctre wheel spacers as a OEM set up.. I'm under NSW regs & having trouble fitting 7" spoke wheel rims to clear front springs for RWC. Wondering if I fit camber adjustment units would this be OK or are they not OEM also. Got me stuffed at the moment. Regards: Alan.
When you you disconnected the two wires that were connected to the resistor situated immediately underneath the coil, did you join these together .As this could be your problem failing that check out the procedure I used for my set up which works A1. Regards: Alan.
That's correct Steve they are genuine leather,I originally had them in a 2+2 some years back. They look great mate. Hows the motor coming along. Regards: Alan.
I'm after enough to cover the center section of the car only. Not happy with felt cover which I have at the moment. Regards: Alan.
When I installed my Elctrnc dissy in my motor I dscnctd the two wires that were cnctd to the resistor unit that was situated underneath the coil & joined them together. I then cnctd a wire from the "+" Trmnl on the dissy to the Module on the dissy marked "B". from the other trmnl on the module marked "C" I cnctd a wire which I then terminated on the "-" side of the coil. Might point out that I also fitted a stronger coil.The Tacho was the original three wire unit that was fitted in car. A 76/ 260Z S30, everything works fine. Hope this helps if you haven't already resolved the problem. By the way sometime back I posted a method for testing a Tacho out of the vehicle. Regards: Alan.
These figures would be suffice to cover the max length used in most vehicles.It stands to reason that the longer the wire more volts are reqd to force the reqrd Amps thru. Regards: Alan.
Just to add a little more info, according to a wiring chart I looked up (AWG) #6 wire gauge carries 37Amps / #8 24Amps /#10 15AMPS. * AWG: American wiring gauge. Regards: Alan.
:-\ As the purpose of the fuse is to ensure that the wire being used does not overheat & burn out would it not seem reasonable to check the amount of amps the wire being used can carry given that there is only 13Volts to push the amps thru this wire. Then try three quarters of this figure for the fuse itself. You may be able to apply OHMs law theory if you can find out a bit more about the fuel pump itself. Regards : Alan.
G'day mate, sorry but I gave you a bum steer, it should have been "RockAuto" Geeks wont post to Ausie land whereas these people do. Regards: Alan.
G'day Steve,mate I've had the same problem but located where it existed in mine. Turns out that where the wires are cncted inside the shroud that encases the steering clmn the black earth wire had come adrift. RE joined same & lghts work fine now. I am going to install relays as recmnded by PGZ. Best way to check if you have same problem is to open the lghts cnctn at the front then use a test lght across each feed to earth situation on car, if you get a glow from each wire you have the same problem. If you are after any further info regarding this give me a ring. How's your motor coming along & is the tension wrench suitable for your needs. Regards: Alan.
Try checking the earth wire, had problems with my headlights & found that the black earth wire cnctn in the steering column shroud had parted company. Could be something of a similar nature. Regards: Alan.
Try "Geek Parts" USA. A lot cheaper than over here even with their postage costs. They have the magnet unit that fits under stator also. Regards: Alan.
Hazard switch I have. PM. me. Regards: Alan.
If you haven't obtained a water pump pulley yet, PM me. Regards: Alan.
Thanks for the info mate, will try & source them over here. They look heaps better than foam rubber. Regards: Alan.
G'day Ben, can you still get the standard "Carbonover flares" to suit a 76/S30 & if so cost for full set.Pick up. Regards: Alan.
