zeds4ever
  1. After two metal shrouds that fit over rear hinge rubbers of hatch cover. I believe that 240/260 & 2+2 are all the same. Regards: Alan.
  2. G'day Pauly, finally got all my copying done from your manual mate. the A3 magnified sheets are great they are so easy to follow. I've returned your manual back to Joseph today with an envelope with a few bucks in it to buy yourself a cple of beers. I owe you big time & once again many thanks for your help with this. Regards: Alan.
  3. G'day Pauly, picked up manual today mate it's awesome. The wiring diagrams are fantastic & very easy to discern & there is so much information, will photo copy all I require & return book back next week to Joseph. Thanks heaps for all your help mate going to see if I can get the same manual if I can . Regards: Alan.
  4. Good to hear Pete,I'm sure the fella's on the Forum will be pleased to know that. I find it hard to believe that you are still learning about motors tho. LOL. Regards: Alan.
  5. Thanks Alan & Peter, I will do what you suggest. I think the crank should be no problem tho as it was machined & balanced when the motor was rebuilt. Think it might be what was mentioned with regard to seal being dry which was as a result of the motor not being turned over for quite a while. Three years aproxmtly. Your help with this is much appreciated.By the way Pete even tho you have given away building motors it brightens my tired old eyes to see that you are still around to lend your immense knowledge about motors to other people such as myself, all the best with your future endeavour's what ever they may be. Kind regards: Alan.
  6. Thanks Fella's for your reply, so gathering from your responses I have to take the gear box out & check the seal more closely. The bottom line is that I will have to take the motor out Remove sump & crank shaft to refit Nissan seal. Is this correct or is there an easier method that will be just as effective. Once again many thanks for the advice. Regards: Alan.
  7. I'm sure I'm bloody jinxed with this car, turns out now that I'm getting tell tale signs of the rear oil seal on crank is leaking. Been using Castrol Magnatec oil & it has started since then. Whilst the motor was rebuilt a few years ago it has done no road miles & I have been starting it up & running about once a week. Is there an additive that I can put in oil to help overcome this or do I have to replace the damn seal. If so what is the best method to do this & what is the best seal to use. Car is fitted with Auto trnsmsn. Regards: Alan.
  8. G'day Pauly, PM sent re manual. Regards: Alan.
  9. Thanks heaps for that mate, just got to find my magnifying glass now ,ha ha . Compared it to the Nrth American 280Z diag & they are fairly similar. Hopefully I can get indctr lghts sorted now. Regards: Alan.
  10. I'm after wiring diagram for Ausie 260Z S30 76 model. I have diags for Nrth American, USA, & UK model cars but they don't have the information that I require. Having problems with indicator wiring section. Regards: Alan.
  11. Hi fella's, found this supplier on one of my forays on the net. He is located in Q'land his name is mike & he is happy to let Forum members to have units at trade price $55.00 they are normally $75.00 plus pstge, all that is reqrd is that your old unit is posted to him & he will re-build it. Remember that you have to state you are a AusZcar Forum member to obtain trade price. You can view some of his work on the following site. http://www.advancediaphragmoptions.com Postal address is Advance Diaphragm options PO Box 3099 Caboolture BC Qnslnd Australia 4510. Or if you wish you can phone him on (07) 5428 0808. Tell him Alan sent you. Regards: Alan.
  12. See your point , but if you blow a tire I think that would have more serious consequences wouldn't it. I'm to old to die yet & I don't want to go out with a bang. LOL. Regards: Alan.
  13. G'day mate, glad you have finally got everything sorted out with your motor . Told you how good the elctrnc igntn is. Makes a world of difference to the motor, but make sure you hook up the vacuum advance unit mate & she'll go even "betterer". When your'e at Carlo's place tomorrow why don't you see about a slipperyD for it. Looking forward to seeing (The car) on sunday ,oh n you to of course. By the way might see if Paul from Silverdale would like to come over & check it out I'm sure he'd luv to see it to if that's OK with you. Hope this was satisfactory for "The grammar police." LOL. Regards: Alan.
  14. Noticed recently that there is a electronic Magna distributor that can be used for 260Z in place of the 280z units can anyone enlighten me in this regard please. Regards; Alan.
  15. Can't get bigga than that. Regards: Alan.
  16. If you use a test lamp set up & go from a known active wire to any black wire & a full glow results you will find it is a earth wire, if it is a dull glow it is related to another unit source most probably. The black wire is the earth wire system mostly used with Datsuns. Regards: Alan.
  17. Just makes for easier reading methinks & th msge gets ax. Chek th word abreviation. EG: Time is th essence. Ha Ha . Regards: Alan.
  18. I have adjustable cambers on mine & when I rotate the camber unit it causes the lower strut brace to move to dfrnt pstns (understandably) this then changes the angle of the wheel itself in relation to the struts themselves. Stands to reason one would think or is it a optical illusion on my behalf. LOL. Regards: Alan.
  19. Yep,that was my thoughts to. Will do. Regards: Alan.
  20. A BIT LATE I KNOW BUT YOU COULD HAVE MADE A NOTE OF WHERE WIRES WERE SITUATED IN CNCTRS THEN REMOVED THEM FROM SAME. THIS WOULD HAVE ENABLED YOU TO SLIDE THEM THRU THE GROMMET & THEN RELOCATE THEM BACK IN THEIR RESPECTIVE POSITIONS . AS LONG AS YOUR HAPPY. REGARDS:ALAN.
  21. WHEN I FITTED A E12-80 280Z DSTRBTR & COIL INTO MY 76 S30 SOME TIME AGO. I REMOVED THE RESISTOR UNIT SITUATED DIRECTLY BELOW WHERE THE COIL IS LOCATED & JOINED THESE TWO WIRES TOGETHER, CNCTD THE BLK/W WIRE TO (+) SIDE OF COIL, THE OTHER BLACK WIRE I CNCTD TO "C" ON MODULE AT DSTRBTR, FROM THE "B" ON MODULE RAN A WIRE BACK TO THE(+) SIDE OF COIL . NOT SURE BUT I THINK THE BLACK WIRE THAT CNCTS TO CIRCUIT SIDE OF MODULE IS WHAT PROVIDES SIGNAL TO TACHO. HAVE YOU CHECKED YOUR TACHO OUT TO SEE THAT IT WORKS OK. YOU CAN DO THIS INDEPENDANTLY FROM WIRING SET UP, I POSTED HOW TO DO THIS SOME TIME BACK. REGARDS: ALAN.
  22. YOUR A GEM DAVID, THANX FOR TH QIK REPLY, WHAT ABOUT TH HAZARD UNIT IS THIS ALSO THE SAME DEAL. REGARDS: ALAN.
  23. ThANX H/S FOR THE ADVICE, THE MASTIC SOUNDS LIKE THE GO. HEY DC ITS NOT LIKE THE USUAL WHALE TAIL AS IT HAS A GRADUAL GRADIENT & NOT A UPSWEPT VERSION LIKE THE OLD ONES. IT'S MORE IN KEEPING WITH THE LINES OF THE CAR. WILL POST SOME PICS WHEN IT'S ALL FINISHED. WHICH IS VERY SOON I HOPE. REGARDS: ALAN.
  24. Fitting a whale tail to mine ,gives the car a more finished line rather than a chopped look. Just mpo. Regards: Alan.
