KatoKid
Everything posted by KatoKid
  1. Hi Jamo. Supasteer Australia. These guys had them the shelf, about $70 per side I think. 3/ 10 Sydney Road, Bayswater VIC 3153 Ph: (03) 9738-0345 David
  2. Beg to differ. Went and saw U2 last night in Melbourne........granted they have been around a while but they are still one of the coolest rock bands ever. Bono actually looks a bit dorky in the early clips compared to now.
  3. Jamo. Use Toyota Soarer rack ends they may be slightly too long but you can cut them down if required.
  4. One is not amused!
  5. Any one interested in seeing what we can get in a group buy?
  6. Bumper looks good in the pics, how did they fit though?
  7. Geeze Pete. I'm a serious shade of green (with envy), looks fantastic!
  8. All that was left was to fill in the hole in the rail and repair the other small hole just behind the radiator support panel. This one is a bit bizarre……no reason for it to rust a hole through the rail here as the inside of the rail was perfect. Can only put it down to the fact that it’s the side where the battery sits and the battery gases must sit inside the rail and do the damage? The RH side rail is perfect. Must admit, after the big job that was the sill replacements this was an easy and enjoyable little job! Wish the whole car was this easy.
  9. I had some 50 x 50 x 2.5 Duragal right angle that was perfect for a new reinforcement. Had to make it in two sections and then weld it together in situ to get it inside the chassis rail as well as plug welding where I had drilled out the original spot welds.
  10. Next job......I found some rust holes in the front of the LH chassis rail above where the sway bar mounts. Could see some spot welds so envisaged there was a bracket of some kind inside the rail to reinforce the mounting. I cut out the offending area and found what was left of a reinforcement inside. The reinforcement was pretty well gone so I drilled it out and cleaned up the surface rust on the bottom of the chassis rail. The top and both sides inside the rail looked surprisingly free of rust. Seems anywhere they have layers of steel in these cars it attracts the dreaded rust worm.
  11. Not an engineer Simon, I'm a motor mechanic by trade but haven't worked on the tools for over 20 years. Ive built a few cars a long time ago...... SBC, Toploader and 9 inch into an LJ. SBC, glide, 9 inch into a 2WD Hilux before mini trucks were cool (are they?). 460 BBF into an XD for a mate. And lastly a BBC, glide, 9 inch, 3/4 chassis, ladder bar, tubs etc...into a MkI Cortina. Dropped the car off to the panel shop on Saturday morning and they had it for a few hours as their 3 phase spotty is only air cooled and needed a rest after every few welds. Plug welded the remaining holes on the base of the A pillar and all that's left to do is trim they excess off the top and bottom of the sills once its back on the rotisserie. Was nice to see the car on wheels and moving again....even if it was on a trailer!
  12. Congrats Benny, looks like an excellent car to start with. Very solid.
  13. On to the RH sill. This wasn’t nearly as troublesome as the LH side, it was slightly too deep but with a bit of force it could be made to fit. The main issue was that the lower edge wasn’t formed properly. It was more of a larger radius bend than a nice 90 degree like it should be so I had to spend some time to make the bend more defined. In the photo Ive reworked the first 100mm and you can see how the rest is not as defined. As with the LH side it required lots of trial fits before final check of positioning with the templates and welding. I’m pretty happy with the way the templates worked out. As Loui suggested, ideally you should hang the doors and guards to confirm the position and gaps but this really is a PITA and using the templates I’m 100% sure the new sills are in exactly the same place as the old ones. The shell is going to a panel shop on Saturday to have the sills properly welded on with their 3 phase spot welder as I now have 3 layers running the full length of the sills and my borrowed single phase spot welder just won’t cut it.
  14. Sill was then tacked on with some plug welds and seam welds where required and the cuts in the boxes were welded up and smoothed.
  15. This meant I could position the top of the sill in the correct place on the car but that would leave the bottom lip of the sill where it needs to be welded to the lower edge of the inner sill hanging well below where it needed to be. I could with fair bit of force bend and clamp the sill in place in the middle of the sill but the compound shape of the front and rear “boxes” of the sills prevents you from being able to bend them so after much deliberation there was no other way than to make cuts in the front and rear of the sill boxes to allow the whole length of the panel to be slightly squeezed together so the distance from the top edge to the bottom edge matches the inner sill. Once I had made the cuts in the front and rear “boxes” of the sills it was pretty easy to bend the whole sill slightly along its full length. I bent it in two places……..along the line which forms the gap with the door and along the bottom where it returns to meet the inner sill. I had to take more material out of the cuts as they closed up as I squeezed the top and bottom edges together. Bit hard to explain….pictures may help.
  16. Now on to the fitting of the new sills and after doing this I know why panel beaters only use reproductions as a last resort. When I received the new sills I thought cool, shiny new metal, how good is this going to be. Well it ain't that good. Once you trial fit the sills you will realise that there is a fair bit of work to get them to fit and be properly positioned. They don't look it when you first compare them but mine were considerably different for both sides, as you would expect there is a fair bit of excess flashing that needs to be trimmed but the way they came out of the press was quite different. Either the tool is different or the process is different. I may have got less than perfect pieces and other people may find that the quality and fit is better but you won't know until you try. The left hand side was the worst in that it was just way too deep when measuring from the top to the bottom of the sill. As you can see in the photo, when I positioned the old sill over the new with the tops in the matching position the new sill was between 10 and 12mm deeper than the old sill at the bottom.
  17. Yeah, thanks Loui. I compared the new sills and old sills with reference marks at both front and rear where they crease and they were pretty well spot on.
  18. One thing I neglected to add....before you remove the old sills you will need to mark a reference point for where the original sill is positioned so the gaps for the front guard and doors align with the crease in the front of the sill. With this marked and the templates you know exactly where the new sills need to be positioned.
  19. Mmmm!! Sounds very interesting, just the sort of stuff I like. Will be watching this one. Good luck Simon.
  20. Buy OBX at your own peril see Hybridz thread for more http://forums.hybridz.org/index.php/topic/88099-obx-differential-inspection-and-installation/
  21. Came across this as an alternative for those with bump steer issues. Race car only really as it looks like you have to loose the rubber boots. They are factory BMW M Sport tie rods. Something to keep in mind.
  22. and me with my 2+2
  23. Excellent work nat0. Do most RB guys run the engine - trans stiffening? Only ask as you may be limiting your market for those people that may want a true rear sump position..... given the market would not be just limited to Z's.
  24. I'm with you Nato......need to sticky this sort of stuff. Here's photos of my 4/71 #728. Mounts built into the tunnel look the same but its a very different X member.
