2,236 -
137
Everything posted by KatoKid
The roof skin is coming off next to fix this properly, I could have sworn the roof was good before blasting....... Once the roof frame and skin is repaired the whole car goes back to the blasters for all the newly exposed bits to be blasted and then it will be etched, preped and shot with final colour in these areas before the quarters and roof goes back on. Costly, yes.....but piece of mind in the long run!
Not finished yet but well on the way, nearly metal finished with new dog legs added and all the lips rebuilt.
Next....rear quarters: Blasting revealed that there was significant rust in the lips of both rear guards. There is a big chunky bead of seam sealer that the factory filled between the inner and outer guards all the way around the lip and this just collects moisture and has the obvious effect. I talked with Glen about options and he was adamant that removing the rear quarters was the only way to tackle the repairs properly...rebuilding both the inner and outer guard lips. They have a matching numbers E38 Charger in the shop with the same issue and Glen showed me what they had done and I after seeing this I was convinced that this was the best route so ff they came...... Before's:
Mmmmmm....last post in February, cant believe its been that long! Anyway, after being patient with the panel shop a few weeks ago I cracked it and read the riot act and pushed then to get into my car....they have a lot of cars in the shop and its only a two man show....Glen the beater and Allan the painter but that is testament to the quality of work they do. No Commondores or Falcoons in here its all Rod's or resto's. Paid a visit today and was pleasantly surprised with the amount and quality of work done. First up..... The only accident damage I could see when I bought the car was a minor bingle in the RHF headlight bucket area, it had been repaired before but pretty badly and there was plenty of rust in the triangular reinforcements where the top radiator support panel meets the apron caused by foam being glued to the top of the support to direct more air through the radiator (it had air con fitted). Thanks to Matt (Big Fella) I was able to secure a donor radiator support which I had unpicked and delivered all the bits to the panel shop where they blasted and straightened everything before putting back together and etch priming. Pic's speak a thousand words but needless to say I'm pretty impressed with Glen's work and attention to detail........ Before shots:
Lovin your work Mossy....keep at it. Orange/black my fav!!!
Mating old bodies onto new cars... interesting concept
KatoKid replied to GTR240's topic in General Discussions
You Kiwi's are a deluded bunch! -
Thoughts for a daily - 1969 1000 (A14 turbo)
KatoKid replied to luvemfast's topic in Off Topic Discussions
Lots to like about this Simon......but.... Go and drive it, good cars that are well sorted and put together will drive well and you will either love it or walk a away. As a daily, I would be cautious. Its got a lot of mods (albeit nothing too serious) so more to go wrong. If you can live with the impracticality it will make the mundane drive to and from work a treat and worth every cent! -
Im pretty sure its the US of A....check out the oil well in the top right corner, plus cant see any steering wheels on the right side! I reckon its the port of Newark right next to Newark airport and this fits with the bridge in the background.
Awwww...Matt, what are you doing! Seriously though, I do understand the demands of young families vs what us men need to do in our caves. Maybe for another time....and a less demanding project. Cheers David
Got mine from warren at All Z in Sydney. Typical Taiwanese pressings ...they didn't fit very well but with some coercing the came up well.
Back after a few years.. finally started the project!
KatoKid replied to Dan260Z's topic in Introductions and Forum Etiquette
Good luck Daniel....mandatory pics required!!! -
ARP do provide a torque spec and lube but strongly recommend the stretch method. From what Ive read on some BMW forums these engines really need good rod bolts for insurance (7,500 factory red line). The bloke that bought my 3.0L single Vanos engine fitted ARP bolts and the torque specs didn't induce any stretch at all, he consequently used the stretch method and had to apply a fair bit more torque over and above the original spec to get the desired stretch. Bottom line is that I don't want to grenade an engine and if it means spending a few bucks on a tool then I reckon its worth it. I don't have a calibrated arm like Pete and Wayne! I did find a stretch gauge on VPW for 89 bucks.... so that's pretty reasonable and I can sell it afterwards anyway.
http://www.summitracing.com/parts/ARP-100-9942/?rtype=10 Dial indicator gauge used to measure the length (stretch) of a rod bolt to its ideal elasticity vs just torquing which isn't ideal due to friction playing a part in the process.
Anyone in Melbourne I can borrow one of these babies from? Just need to replace the rod bolts on the M3 engine but dont really want to spend $100 for a one off and never use it again! Thanks
Thats not a tooth, thats an Alien! Just waiting for Ripley to come along and blast that sucker with her pump action laser.
I get where Paul is coming from but also agree with Gareth...bottom line is that I don't see any intentional burning. People have an opinion or offer advice based on their own experience and therefore believe its true.....others may choose to disagree or challenge and its from that process that we all learn. If you post you do so at your own peril, if someone disagrees or has a different perspective you may feel aggrieved so be prepared! Having said that this forum is way ahead of others when it comes to sense of community and respect for others.... so before you bang out a response to a thread have a thought for the other person and how they may view your response. treat others as you would like to be treated.....its only common courtesy. David.
Weve missed you Rev! Looking forward to having you and your balanced perspective back home.
What he said^^^^71 S1? Hows the LHF rail, looks like its had a hit from the way the firewall and apron are creased?
Happy Birthday mate. May the rust mites cease to bite!
KatoKid replied to gav240z's topic in Cars For Sale
Lots "available" like he has plenty of parts...noted another car in the background. Power steering "available"? -
Parts Clearout Day.. EOI on a future date and time.
KatoKid replied to Zedman240®'s topic in Parts and Tools for Sale
Im in! -
Ive got zorst you can have for nix!
That really sucks Gav. I'm with you.....I like my cars original. Don't get me wrong I love modified cars the more the better sometimes but I also value unmolested examples of classics or modern day classics. I also understand about the tainted feeling that comes with what happened with your car so I have to agree with Gordo, if you don't theink you can deal with it and be 100% happy with a repaired stolen car then just take the money and move on. hope it works out for you. David
