2,236 -
137
Everything posted by KatoKid
I love a good knob! Can you adjust sensitivity of said knob?
Thanks Agno, sometimes I wonder why I'm doing this as I feel I spend more time planning and researching than I do actually working on the car! When I do finish a component and its come out well and I'm happy that's when the payback comes.
Gareth, M3's come standard with a pretty substantial engine oil cooler and there is a thermostat built into the oil filter housing where the cooler lines originate. The M3 oil filter housings and coolers are a popular add on for anyone modifying a lower spec M50/S50 series engine as they are a bolt on. The original M3 cooler is the same width as the radiator which it sits under but its only about 70mm high so its wide but narrow and again I couldn't use it as the front of the Z is just too small. In front of the radiator was the only option for me. There are three holes arranged in a triangular pattern on the front of the radiator support cross-member which lined up well with the Earls cooler I had chosen so like the PS cooler I used some 3mm plate to fabricate brackets and made the same rubber insulators as the PS cooler. Still need to add a lower bracket and the -10 hoses. Track days.....yeah probably!
The cooler is the largest I could practically fit in the available space....Harmonic Balancer sits very close at the top of the inlet and outlet hoses which required the cooler to be offset slightly for clearance. Lines are braided teflon -6 from the pump to rack and then to the the cooler with a -8 hose tail and rubber hose back to the reservoir.
BMW power-steering systems are renowned for overheating if the cars are tracked, most punters install a proper power-steering cooler in place of the typical loop of pipe (like most cars) that normally serves as the cooler. Under-driven pulleys are also an option but don't really fix the issue. Either way I couldn't use the original BMW loop of pipe due to a lack of space so a proper (albeit small) cooler was going to be needed. The original BMW loop cooler sits in front of the rack on the cross member and this logically is the best place for a proper cooler. I fabricated a bracket from 3mm plate that is welded to the lower front edge of the cross member and the cooler sits on top of that using rubber isolators top and bottom of the mounts. In the photos the bracket is just tacked for now and I need to get some nice stainless domed Allen head bolts and nylocks to finish it off.
Couldn't believe how quickly it all adds up for the above...fuel lines, power steering lines and cooler, engine oil lines and cooler. At least the clutch line was cheap. Two sections made up by Better Brakes in Bayswater......one from the master cylinder under the dash then behind the heater box to a firewall fitting which uses the original hole where the choke cables went through. Second part goes from the firewall down to the slave cylinder.
Tai, send a PM to Mick Bellinger zed240au.
A box of stuff arrived from Summit which included my Russell EFI adapters http://www.russellperformance.com/mc/adapt_fit/fuel-efi.shtml . After reading a few comments about the ones without the screw on end caps coming off I thought this the safer way. One problem I didn't anticipate when trying to fit them to the BA/BF Falcon fuel module was the lack of space between where the tube comes up out of the module and does a 90 degree turn and the collar which the adapter end cap screws down on to. The "head" of the screw on end caps is 5mm thick which is plenty so I took 2mm thickness off this and it gave enough room to fit the end cap over the tube. Had to do this on two of the tubes, middle one was OK so all good now.
Given the amount of brake, fuel and oil lines I need to run I lashed out and bought an Eastwood flaring tool. A very nice piece of kit and brilliant to use. Because I have rotated the control valve on the top of the WRX steering rack 180 degrees I had to make new hardlines to the cylinder. I wish bending was as easy as flaring!
Don't need to Gareth, there is enough room if you run them in the right place. Ive mocked up a couple of versions of the rear muffler as I just cant bring myself to like the stacked twin pipes ala 432 style. After speaking with Mick from Devonport I'm going to go with a muffler the same size as the Reinhard rear muffler with twin 2 1/4 inlet and the pipes merging inside to a single 3" outlet with a down-turned tip.
So I need to get some clearance for my dual exhaust where it goes under the diff crossmember..... 1. Take two perfectly good crossmembers. 2. Attack with cut off saw. 3. Weld in 5mm plate and brace on back side. 4. Hey presto plenty of exhaust room.
KatoKid replied to XRQTR's topic in Parts and Tools for Sale
RB good 2J better but weight and cost of gearbag etc goes against it. Still cheap engine if its in good nick -
Is cool. This weekend any good for you?
Yeah mate...how many $$$
Thanks Scoota, will see how Mossy goes as hes lots closer
Thanks guys. Rob who Scoota?
Yep, that's exactly what I'm intending to do Craig.
Bump. Still looking for crossmember Thanks
I'm up for one of these!
Ended up getting it from Enzed. 3/8 only comes in coils but its pretty easy to straighten out. 5/16 and 3/16 they had in straight lengths which is nice. Mine looks like its copper but its copper plated steel Bundy.
Dan. You are a dedicated Zaholic. Everyone has choices and choosing to live in downtown Melbourne, much like downtown Manhattan has its drawbacks (great video by the way). I work in the CBD and everyone in our office asks why I live so far "out of town"? I choose to because it works for me. Cant help you with any suggestions but I hope you can find something that works for you. David
So, took my fuel tank to Melwide Radiators as there was plenty of rust and scale inside after sitting with no fuel in it for nearly 20 years also had a decent dent in the bottom and I needed the original fuel sender and pipes covered over. They quoted $400 to cut the tank in half, media blast inside and out, tin the whole of the inside so it wont rust again, weld it all back together weld in the plate for the fuel module and cover over the original sender and pipe holes. They cut the tank on the top side of the original flange where the factory joins the two halves so the welds aren't seen from underneath the car. In the first photo below you can see the welds, not the greatest looking but he pressure tests and guarantees no leaks. He did a good job on the lead filling and covering of the original sender and pipes. Reasonably happy with the outcome given the hours they put in, only thing I would do differently is pick it up as soon as its finished because in the week I left it sitting there the acid they use to tin the inside had put surface rust on all of the media blasted outside! Managed to get it inside my blasting cabinet and give it a clean up then gave it a coat of etch primer straight away. Couple of little dings that will get a wipe of bog before it gets properly painted.
and me!
I'm going to second that! Ryan, fantastic job and great attention to detail. Well done.
