2,236 -
137
Everything posted by KatoKid
DreamZproject's 260z ever ongoing project
KatoKid replied to DreamZproject's topic in Members Project(s) Journal
Rotisserie is good but the tie bar from front to back needs to be more substantial to stop flexing. Use some 50x50 and put casters on the bar like mine.... -
I'm slowly working away on all the little things before I disassemble the shell and send it to off for final paint.....getting closer.... just the exhaust as the last major piece. The BMW shifter has an inner and outer seal. The inner seals on the base of the shifter fulcrum and the outer seals on the gear lever and to the body by means of a recessed flange in the boot. No bolts or screws....the boot just pulls through the tunnel and seals very tightly on the recessed groove. Fortunately the original hole in the Z tunnel is exactly the right width for the correct diameter of the round hole that the boot requires so I just had to add a bit at the front and the rear.
Upstairs for thinking, downstairs for dancing....good job.
KatoKid replied to CroS13's topic in Members Project(s) Journal
Good work Rudolf...keep at it. -
Yay!
Someone buy the injection set up....that's a great deal
Lots of Z's seemed to have popped up or have been bumped this week and mo takers? Whats going on.
Great result and excellent production! Pete, its sounds like its surges around 6,000 rpm just as it comes into it the meaty part of the power curve. Is this just the point where the inlet resonance is just starting to work as the dyno holds it back? Would you feel driving the car or is it only apparent on the dyno?
Loved the last one...looking forward to this one. Well done.
Don't want to come across like a smart arse........but unless someone has invested a lot of time and effort already the chances of finding one without rust and holes are pretty slim, maybe in Arizona but not likely here.
Is it a completely bare shell? If it is you should be able to do this in your own. The front end is really light and you can lift one handed, the rear is much heavier. If its not a bare shell then forget it and get help. I used stacked 20 litre drums, at each corner and went up one drum at each end at a time. You can lift the shell and use your feet to slide the drums underneath. I had the car sitting on two drums at all 4 corners and then had another stack of 3 drums sitting ready to go....lift whichever end your attempting.....kick the 2 drum stack out of the way and then slide the 3 drum stack in.....repeat on the other side and lower down...take a breather and then do the other end. Once I had the shell sitting on 3 drum stacks at each end it was pretty easy to shim with bits of timber to the correct height and then slide the rotisserie stands on.
Mmmmmmm........
Craig, the M3 comes factory with an oil cooler and the filter housing has a thermostat built into it so I don't need to add anything. Mike, valid point but since many cars have engine oil coolers from the factory these days I would doubt it would be an issue. Accusump would also be the same on the first discharge.
Hi Craig. Cooler doesn't have a drain. I'm guessing the lines and cooler combined could hold up to a litre of oil and while you could drain it each time by removing it, it would be a massive pain and its just not required. Bear in mind that the oil passages, lifters etc in the engine wont drain completely and will also hold a reasonable amount of oil when you do an oil change. Good oil doesn't "wear out" either, primary reason for changing is to drain out the combustion byproducts and other contaminants so the best solution is to buy good oil and change regularly (5,000km max) and there will be little contamination and thus no need to worry about residual oil in the cooler and passageways.
Thanks George. ....and its the little things that take the most time, making brackets is incredibly time consuming and bending and running hard lines even more so. I couldn't tell you how many times I removed and refitted those fuel and brake lines!
Getting the cooler lines through the radiator support was a bit of a mission. Had to keep the lines from rubbing on the inner guard, rad support and have the right angle for them to join the cooler so I made a bracket which bolts to the lower radiator attachment hole and used an overly expensive "billet" double hose clamp (which worked perfectly). I'm sure that as soon as the word billet is in a part description the price automatically triples!
Time to run the engine oil cooler lines.... The factory oil cooler lines use a unique O ring set up which cant easily be modified, plus the factory cooler and lines wont fit anyway so Ive used an adapter made by VAC Motorsport that allows -10 AN lines to be plumbed from the factory oil filter housing.
Plumbing at the back of the car is nearly finished....new brake lines on both sides and new T piece from the front line. I'm using a Russell inline fuel filter where the braided line from the tank meets the hard line going forward. The filter is small and light weight but I didn't want to leave it just hanging off the hardline so I made a bracket to support it. The clamp will be insulated with some 3mm nitrile rubber to protect the filter. Second hard line is the return from the pressure reg and will connect with braided line to the tank.
KatoKid replied to acf321's topic in Members Project(s) Journal
Thanks Adam. Seems to be a fair bit of contention on the section - not section front. Cheers -
Good news Adam. Why the change to sectioning the struts? Can you let us know how much he takes out of each? David -
That is the real deal!!! colour me green
Hi Tim. I used Summit for the coolers and the Russell EFI adapter fittings. For the rest I went to Motorsport Connections as I wanted somewhere local where I could exchange items (which I had to in the end) if they didn't fit as I wanted. Motorsport Connections certainly aren't the cheapest compared to eBay sellers but they had everything in stock and provided invaluable advice on how best to make some of the connections. They are Sydney based but they set up in Melbourne two years ago and Mark Hiinchelwood the owner was actually running the Melbourne store while their normal guy was on holidays. I was very impressed with his knowledge and all fittings are Speedflow not cheap Chinese stuff. I'm happy with the choice and would recommend them for their excellent service. If I had bought off eBay I would have ended up with fittings I couldn't use and would have had to onsell at a lower cost, so how much would you really save in the end. If you did this sort of work all the time and knew exactly what you needed then eBay would be good but for a novice I reckon this is a good way to go. David
Geeze Craig, you gave me a heart attack. Ive been OS for work for a couple of weeks and only just got, first thing I did was head for the shed to check...and yes its all good. Plenty of clearance and thanks for the suggestion as I wouldn't have thought to check otherwise.
Watching with great interest and anticipation Adam. Surely you can smell it now!
