BobsYourUncle
Everything posted by BobsYourUncle
  1. I'm not going to make it tomorrow, I've got to smoke the Christmas hams... Have fun!
  2. But the bore is different? Yeah, the rb20 revs hard to make power (some might consider that fun though?). No replacement for displacement...
  3. I'm a maybe at this stage, won't know until closer to the day. Might drag the wife along and make a day of it...
  4. Those seat covers look really good, especially the photos of them fitted in that ebay store.
  5. Retarded timing caused me similar problems...
  6. This isn't a for sale ad, but I think this is the best place to post it - I was at supercheap this morning, and noticed they have their engine crane on sale at $199, which is $50 or $60 less than the usual "sale" price, and $190 off the full price. Thought I'd give everyone a heads-up. I know they're not everyone's favourite tool brand, but it's a good special.
  7. You might not need to take the wheel off if you turn full lock (one way or another, depending on which headlight), and are flexible...
  8. Calipers and rotors are sold. Everything else is now FREE!! (pickup only, I'm not posting if I'm not getting any money)
  9. They are very similar aren't they... http://www.shannons.com.au/club/enthusiasts/chucky/garage/1976-holden-monaro-gts
  10. There should be plenty of them around, but I think your main issue will be finding someone who'll ship to the US - it's not something I've done before, but I imagine it's more complicated that shipping within Australia?
  11. 112? I don't dislike it, but it's a bit lighter/yellow-er than what I'm after. 918 Orange is my favourite factory colour, and for a while was what I wanted, but I've since switched to green.
  12. So things are moving along now... My carb synchrometer arrived, so it shouldn't be long now until the carbs are set up well enough to drive, the brakes should be all sorted (just need to bleed and double check for leaks), and I'm dropping the fuel tank off for cleaning/rust removal and sealing tomorrow. I'm still tracking down some little bits and pieces that I'm missing, but other than that I'm getting pretty close to getting it painted - and that means the ago old question of "what colour?". I've pretty much decided, but would like to get some opinions, as it may be a bit "out there". I want to paint it Ford Dash green (see pic), which I think will look really good with the matte black Rota RBs and a dark window tint. I've seen this combination (Dash green and matte black wheels) in the flesh on an FG falcon, and it looks really good, but I've got just a little bit of doubt about whether it's too "loud" for a 240z. What does everyone think?
  13. Ok, I cleaned the garage on the weekend, and I need this stuff gone. Everything $20 each ONO (except the auto gearbox, which is still free) - 240z front rotors, a bit of surface corrosion (as you'd expect), but they've still got plenty of meat (~12mm thick) - 240z front calipers, need a clean/kit/pads - 260z factory sealed headlights (from '74 2+2), working when removed (may have thrown these out, will have to check) - Brand new N1339 brake shoes, suit later model 260z (check yours first, my '74 2+2 needed different ones) - Standard 240z brake master cylinder (I think these have a flow restrictor of some sort in them, this has been removed in this one) - 260z 2+2 automatic gearbox (has torque converter, but no flex plate)
  14. For a while now I've been umm-ing and arr-ing about doing an RB swap on this car. I even have the engine mounts and 200ZR sump. But today I got the L28 with triples to a point where they'll happily run and rev, and oh my the sound! I could listen to that all day... It was a combination of problems (or stuff-ups on my part ) - timing was way off, and the throttle wheels were hitting the carb bodies preventing the butterflies from closing all the way at idle. They're still far from perfect - I need to set the timing properly, synchronise the carbs and spend time tuning/fiddling with jets, but at least it's running properly now. And that sound... edit: video! - Engine was cold, so didn't want to rev too hard (and the "hehe"at the end is pretty embarrassing )
  15. I think it's just a matter of waiting for the right buyer. I think this is a pretty good buy at $22k...
  16. Front wheel drive? That makes it a competitor with hot hatches, not the 86/BRZ. The AWD version could be good though, if it's not too heavy...
  17. Ok, so the pump jet lever thing wasn't attached right on one of the carbs, hence no start. Good call... Fixed that up, and away she goes... Quite rough though. Initially, spitting fire through one of the carbs, which was because of a lean idle mixture. Currently running 4 turns out from closed on the idle screws, and it's better, but still popping and hunting. I'm thinking it's still a bit on the lean side... Unfortunately I have poor lighting in my garage, so I don't get much daylight after work at the moment to work on it. And I can't find my Des Hammill book...
  18. These are the two books I'm aware off: http://www.amazon.com/Rebuild-Your-Nissan-Datsun-Engine/dp/1931128030 http://www.amazon.com/Modify-Your-Nissan-Datsun-Engine/dp/1931128049
  19. I think I'm making progress now, however slowly... I had a fuel pouring out the middle carb, turned out the float wasn't straight and was catching on the wall of the bowl. Fixed that, and everything looks good, but it's still not running (with any idle mixture screw setting). I'm thinking fuel levels might be a bit low? I looked in each carb, and they were all the same, about 5mm or so below the holes in the inner walls for the jets. Does that sound ok, or should it be closer? I was thinking it should be more like 1-2mm from the holes? I ran out of time tonight, but hopefully I'll get a chance to try increasing the fuel levels tomorrow night.
  20. I'll take the last one if no one else has claimed it - pm me payment details.
  21. This is the only one I could find - http://www.gumtree.com.au/s-ad/castlereagh/cars/datsun-nissan-280z-fairlady-2-seater-1979-rally-car/1004174205 It's been posted on here before though...
  22. So AE86? From your list, I think that's all that matches brand new ~30 years ago and not a rotary...
  23. Give these guys a call - the guy that runs it is member "Lgee" on here - http://wheeltechwheels.com.au/ I got mine from option1garage here in Queensland. Finally, 18Racing in the USA have pretty good pricing and shipping costs (last I checked) - http://stores.ebay.com.au/WheelBay or 18racing.com
  24. I can weigh in here - this setup was mod plated in QLD in a 240z (that I now own), not Victoria. I'm not sure, but they might be more lenient up here - it still had stock brakes front and rear when it was mod plated...
