Everything posted by .
  1. What part of Brisbane are you in? I have all sorts of spares including rails if it turns out to be that.
  2. The EFI relay will only click once when you turn the ignition on. If you are getting fuel pressure I don't think the relay is your issue. Try attaching two wires to a 9v battery then disconnect the plugs from each injector one at a time. Place the wires from the 9v on the terminals of each injector in turn. If the injector clicks when the wires touch it is at least trying to work. If they don't click they are stuffed.
  3. The outer part is stainless but there is an inner bracket holding the outer together. The bracket is just steel but the good news is it is just a right angle so making a replacement should be straight forward.
  4. ....
  5. blah blah blah
  6. Collide? Are you wanting to talk insurance again?
  7. .
    l28 turbo
    +1 for the SR20DET they go real hard in a S30.....not sure about the torque for an S130 though.
  8. .
    l28 turbo
    I suggest buying a compression tester and using it on your current engine, then post the figures here and someone will be able to indicate whether your engine compression is suitable for more boost. If it is a truely stock L28 straight from a 280zx then it possibly has dished pistons and low compresssion. But most previous owners swap out the dished pistons and replace them with flat tops so there are no garuntees. Obviously we can't predict the reliability of the rest of the engine as that depends on numerous components and previous mods. Another thing to consider is the need for another ECU and associated sensors etc as the standard ECU will not cope. Do you already have an after market ECU?
  9. .
    l28 turbo
    It could be worth it if he can prove a recent quality rebuild. Other than that tell him he's dreaming.
  10. .
    l28 turbo
    The fact that it is turbo doesn't really increase the price much. The engine is probably worth $500, plus the price of the turbo, manifolds, and ECU. Unless they can proove it is all in A1 condition I'd say $1000-$1500
  11. to anyone who recently damaged their car, this story should make you feel a little better: http://www.caradvice.com.au/149855/supercar-crash-destroys-8-ferraris-in-japan/
  12. .
    280ZX Digital Dash
    no luck on that one
  13. .
    280ZX Digital Dash
    Tomorow (Wednesday), Friday or either day this weekend would be fine.
  14. .
    280ZX Digital Dash
    The plugs don't match at all. The dash only has one side of each plug (female I think). So you would either need to source the other sides of the plugs (maybe from the USA). Or you could remove the existing plugs and solder on something more familiar (eg a standard off the shelf plug or a standard 280zx plug) I wonder whether these digital dashes were a fore runner to the "Star wars" dashes as seen in the Z31? If so maybe they share some wiring / plugs? I had bought it with the idea to make the swap but in the end I decided it wasn't worth risking a working dash.
  15. .
    280ZX Digital Dash
    Oh I guess you want me to provide more detail. I have one. No the plugs don't match. You could probably jimmy something up. You can have mine for $20.
  16. .
    280ZX Digital Dash
    Yes, No, Yes
  17. I don't see the problem. It is an easy modification to get it to work. Just swap the piece where this connects for the equivalent S130 item.......... I think the item is called a chassis. I'll take your old one if you don't want it anymore
  18. not yet, waiting for his reply.
  19. Meh
  20. Man underestimates tazer. Man tazers himself. Testicles shrivel. Woman laughs. Cat licks itself (implied, because it can).
  21. Many have sold their zeds in the past and almost all have regretted it. Avoid it at all costs. If you sold it and regretted it later you would be very hard pressed to find another zed in such condition.
  22. "hilux/4runner clipers" isn't that what Jeremy Clarkson created when he bolted an outboard on the back of a hilux?
  23. Those aren't normal flares they are SOLAR FLARES.....He knocks out power stations, radio towers and Mobile phone towers whenever he drives by.....not because of solar radiation but because his wheels and tyres can't fit past
  24. Understood but I still don't anticipate a difference in the cable? Not that it matters I don't think I have a spare cable anyway.
  25. .
    L6 fuel rail
    I am after an aftermarket hose tail type fuel rail for an L6 engine. I'd like one on the cheaper end of the scale otherwise I'll just run with the rail I have. Let me know if you have one you are willing to sell. Thanks Greg
