Well there hasn't been an update for a while cause I've been so busy. The V8's was an awesome weekend. Would you believe I only got one photo of it on the track.
Im moving from Townsville down to Gladstone to start a new job. I've been at my current one for eleven and a half years so it's a big move but one that I hope will pay off. I've been driving the zed to work as a daily for a while as I know it will get a lot less attention for a while after the move. That's not to say I haven’t been planning things. Since my clutch started slipping I have been considering my options. Because the car is so light, I don’t need a hard core replacement clutch as this will ruin drivability and give me a tougher pedal. The LS7 clutches are working a treat behind some big hp dunnydores so that’s good enough for me and a good price too. Replacing this for me will involve removing the engine and gearbox together so that should be fun. I have been collecting parts to do a few things while the engine is out and separated from the gearbox. Apart from a new clutch, I’ll have a new slave cylinder/throw out bearing and new spigot bearing to go in. I think my spigot is dying and the extra drag on the input shaft is keeping it turning during gear changes. A new bearing here should see my changes improve. A new braided line from the master to the slave should improve pedal feel too.
My rear main has always had a leak so I’ve got a new crank seal to go on. Hopefully that’s all it is. I’ve got a new timing chain to go on as well as an under driven balancer. I also bought a used LS1 oil pump off ebay for $1 + $10 postage. I’ve used this spare to carry out a few mods commonly done to the LS1 oil pump. Porting the inlet and exits of the pump and shimming the relief valve. Easy to do, and the extra flow may save me in on track event. All this collecting parts has me thinking about a bigger cam now. Just a small cam……. I’m pretty sure I’m going all Bogan again now. I don’t need any extra power. This thing pulls like a steam train as is, but its not enough any more. Do I install a cam while I’ve got the engine out? I’ve got that spare set of cylinder heads too. I’m thinking of given them a tickle to smooth out the ports and valve guides and port match the flange surface. Then get them shaved a bit to ‘up’ the compression. I’ve got the better valve springs to go on yet, as well as the LS6 injectors, and the custom fuel rail. I’ll probably order some ARP head bolts and flywheel bolts etc to keep it all together. Man I’ve got so much to do. I cant wait to move down there and get into a house with a shed so the fun can begin. I also have to a bit more to strengthen the chassis too. Until then….
