Showing content with the highest reputation on 05/23/2022 in all areas
  1. Decided the "kangaroo damage" to the LH guard was not in my skill set to repair properly and the as new aftermarket one had an indicator cut out which would have to be deleted anyway, so took the original off the car and dropped it at C.A.R. to be repaired properly after which I can look at getting the car's paint stripped and repainted.
    2 points
  2. Also replaced my fuel tank vent hose - what a saga removing the RH & rear inside trim but at least now there is no fuel leak from the hose (near the tank end) when I try to fill up the tank. This enabled me to see what fuel usage was with the triple webers/L28 - was only a 70km drive to and up through the Dandenong Ranges (The Basin-Sassafras-Belgrave-Monbulk-Olinda-Montrose) but came in at around 12litres/100km. Too short a drive to probably be that definitive but it also helped me decide I need the original shock absorbers refurbed/replaced as the condition of non urban roads in Victoria is terrible.
    1 point
  3. 280zx for auction : https://www.lloydsonline.com.au/LotDetails.aspx?smode=0&aid=32522&lid=3578132&pgn=2&pgs=100 https://www.lloydsonline.com.au/LotDetails.aspx?smode=0&aid=32522&lid=3584751&pgn=2&pgs=100
    1 point
  4. C.A.R.
    Micheal's Bent Bus
    With the panel gaps checked & the front clip adjusted slightly, the clip with welded into position. We then stripped the shell of the remaining parts and installed it onto the rotisserie: Blasting is scheduled for the 24th, so stay tuned...
    1 point
  5. C.A.R.
    Micheal's Bent Bus
    Dodgy sods...
    0 points
