Sirpent Posted May 31, 2011 Share Posted May 31, 2011 Nice going Scoota, The repro panels are one thing but actually getting stuck into it and achieving a result is totally another, hat off to you. Read somewhere in a mag I have laying around that a company recently spent $250K getting all the XY panels reproduced, you can now build a shell from scratch, pity someone couldn't do the same with the S20, wonder if Nissan still has the dies sitting around ? :-\ Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 1, 2011 Author Share Posted June 1, 2011 Hey John these should give you a giggle, and Lurch thought i took dales car back a fair bit on the Driver's Side. This camel's back is getting broken. I've really learned so much since joining this club, so cheers fellas. Quote Link to comment Share on other sites More sharing options...
Sirpent Posted June 1, 2011 Share Posted June 1, 2011 Hey John these should give you a giggle, and Lurch thought i took dales car back a fair bit on the Driver's Side. This camel's back is getting broken. I've really learned so much since joining this club, so cheers fellas. OK, so how much of this car will actually be original after you finish? LMAO But on a serious note, structurally this car had the rigidity of Swiss cheese by the looks of it, did the owner realise just how far gone it was and that it was being held together at the pan by a coffee can, tire outlet placard and street sign? Should last 3 of its lifetimes now Scoota, well done. Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted June 1, 2011 Share Posted June 1, 2011 Fark... Quote Link to comment Share on other sites More sharing options...
Riceburner Posted June 1, 2011 Share Posted June 1, 2011 I like how the electrical sign says 'do not climb over' Fair warning to the occupants. Great job mate, it'll be like a brand new shell! Quote Link to comment Share on other sites More sharing options...
peter mc Posted June 1, 2011 Share Posted June 1, 2011 nice work scoota good to see ,are you painting it as well . look like a fun project Quote Link to comment Share on other sites More sharing options...
FuzzyDropbear Posted June 2, 2011 Share Posted June 2, 2011 Wow, good work mate, I'll give you a call this arvo, if you're around tonight I might drop by on way home to have a look Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 2, 2011 Author Share Posted June 2, 2011 did the owner realise just how far gone it was and that it was being held together at the pan by a coffee can, tire outlet placard and street sign? The owner was aware of the floorpan rust but not the cowl rust. Wow, good work mate, I'll give you a call this arvo, if you're around tonight I might drop by on way home to have a look Yea would be good to see you Rob, i'll be here. nice work scoota good to see ,are you painting it as well . look like a fun project I'll be applying a coat of POR 15, seam sealer, chassis sealant and body deadener to all the bits i replace but funny enough the body is in a lot better condition cosmetically. I think the most fun or satisfying part is the comparision pictures. Quote Link to comment Share on other sites More sharing options...
benny Posted June 2, 2011 Share Posted June 2, 2011 looks like it almost needs to be blasted!! Are you going to clean up the other stuff or leave it?? Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 2, 2011 Author Share Posted June 2, 2011 looks like it almost needs to be blasted!! Are you going to clean up the other stuff or leave it?? Drivers side still has to receive torque box, rail and floorpan. Owner is coming over on the weekend to work on the inner gaurds. Quote Link to comment Share on other sites More sharing options...
RB30X Posted June 2, 2011 Share Posted June 2, 2011 You realise its gunna be hard to let this go back once youre done Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 3, 2011 Author Share Posted June 3, 2011 It will be hard but i'm already starting to piece together my own one Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 14, 2011 Author Share Posted June 14, 2011 The cowl is now back on and there was also repairs on both sides of the inner apron and fitting of two new apron extensions. One of the bigger jobs however was the battery tray area. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 22, 2011 Author Share Posted June 22, 2011 With some repairs to the bumper mounts and a few other pieces it was time to move onto the Driver's Side Rail and Torque Box removal and replacement. At this stage i'm ready to refit the mechanicals and front panels. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 22, 2011 Author Share Posted June 22, 2011 Here's the repair to the rear of the front frame rail. This whole front clip was nearly junk but now . . . . Quote Link to comment Share on other sites More sharing options...
gilltech Posted June 22, 2011 Share Posted June 22, 2011 You're doing a great job of it; am following your progress with interest, as this car has far more rust than the original pictures let on. I was lucky with my '67 FB being almost rust-free, but the '67 CV I owned previously required as much work as you're doing so I can very much appreciate what you've taken on. You may already be on to this, but FWIW a good idea with the '67s is to add a torquebox to the passenger (RH) side as well, as only the CVs had both sides until sometime in '68 when pair torqueboxes were installed to all 3 body styles to stiffen things up. That's what I did with my FB anyway. Actually the '68 cars' torqueboxes also have an angle gusset in the corner with the framerail; in hindsight I probably should have fabricated some for my car; certainly the whole front clip is not what I'd call heavy-duty so needs all the help it can get. Good job; keep us posted, most interesting thread. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 22, 2011 Author Share Posted June 22, 2011 I started a facebook page with a bunch more pics. http://www.facebook.com/pages/1967-Fastback-Mustang-repairrebuild-Christang/231505116875730 If you have access check it out. This has by far been the most difficult project i have ever taken on but i have discovered so many little tricks which far out weigh any pain. I think i'm at about 150 Hours and i want to finish it before 200 Hours. Quote Link to comment Share on other sites More sharing options...
NZeder Posted June 22, 2011 Share Posted June 22, 2011 great work scoot - nice project/job Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 23, 2011 Author Share Posted June 23, 2011 I know i've said it before but one of the things that keeps me motivated is the feedback i get from others, so cheers guys . Can't wait to finish this one as i'm off to Poland mid August and it has to be completed by then. More Pics Quote Link to comment Share on other sites More sharing options...
mossy Posted June 23, 2011 Share Posted June 23, 2011 150hrs, wow thats a lot of work, really good stuff though scoota I'm impressed. If i ever get around to finishing my other 240z I know I've got you and Lurch to choose from Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 27, 2011 Author Share Posted June 27, 2011 If i ever get around to finishing my other 240z I know I've got you and Lurch to choose from I probably would prefer if you said Lurch or Scoota (to save me locking horns with the Bear ) but yea here we are and the Driver's side floorpan is fitted and i even got to use my special Aircraft Technology "cleco" panel holders which do work very well. Another day or two welding and i'll piece her back together, it's been fun sharing it with you guys and girl. Quote Link to comment Share on other sites More sharing options...
benny Posted June 27, 2011 Share Posted June 27, 2011 much better then old signs!! Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 27, 2011 Author Share Posted June 27, 2011 much better then old signs!! Ahh yes the comparison shot. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 30, 2011 Author Share Posted June 30, 2011 Oh well time to reassemble this Ford!~! Quote Link to comment Share on other sites More sharing options...
Bigfella Posted June 30, 2011 Share Posted June 30, 2011 Ahh yes the comparison shot. This may be a stupid question. Do you weld all the way along the seems or just leave them as welds every couple of inches Thanks Matt Quote Link to comment Share on other sites More sharing options...
