Vindicare Posted August 19, 2010 Posted August 19, 2010 Hey guys, Just need some advice from the guys who've upgraded to the 1" master. For a bit of peace of mind, I'd like to find some bigger reservoirs as the ones that come with the part new and kinda small. I've spoken to a couple of brake shops and they don't seem very eager to assist me. So if anyone knows where to get some bigger ones(or one?) that would be swell. Cheers Aaron Quote
C.A.R. Posted August 19, 2010 Posted August 19, 2010 Believe me, larger reservoirs aren't needed But if you insist, just go wrecker hunting & see if you can find some off another model Nissan that are larger & will fit. Quote
FLEXZED Posted August 19, 2010 Posted August 19, 2010 i bought a new 1" master from repco a while ago for $220 If that helps you Loui Quote
PeterAllen Posted August 19, 2010 Posted August 19, 2010 Believe me, larger reservoirs aren't needed ... It is probably true that a large reservoir isn't needed but it is required. If you upgrade the brake calipers you must have a reservoir of sufficient capacity to activate all pistons with all brake material worn away. You need to measure the thickness of the pad material and then calculate the volume all pistons would displace in moving that distance. That volume must be at least matched by the capacity of the master cylinder reservoir. Quote
MaygZ Posted August 20, 2010 Posted August 20, 2010 Peter, I think you are right, but only if you are planning on fitting and forgetting. Surely you would check your fluid levels on a regular basis (eg before and after each track event and during regular servicing)? I used to check the discs and calipers after and before each event, but I used different pads for track and road. As the level goes down, can't you just top it up? Is the volume of the brakes you're running any or much bigger than those on a patrol? Quote
PeterAllen Posted August 20, 2010 Posted August 20, 2010 My apologies if I didn't make it clear. This has nothing to do with commonsense, it is an engineering regulations requirement designed for drivers fitting the lowest common denominator of mechanical understanding and appreciation (e.g. every female member of my family!). My car will be required to have a reservoir of at least 264.2cc capacity. Quote
MaygZ Posted August 20, 2010 Posted August 20, 2010 lowest common denominator of mechanical understanding and appreciation (e.g. every female member of my family!). I understand completely. Enough said. Quote
d3c0y Posted August 23, 2010 Posted August 23, 2010 Is the patrol 1" m/c bolt on and is there any point to using that over the 15/16ths 280ZX one? Quote
C.A.R. Posted August 23, 2010 Posted August 23, 2010 Is the patrol 1" m/c bolt on and is there any point to using that over the 15/16ths 280ZX one? Yes it is a direct bolt on. If you upgrade the fronts to 4-pot callipers & rear disc brakes, you'd be better off with the 1" as the pedal is too low with the 15/16" one. This is of coarse from my own personal experience - other might have a different view... Quote
Gillo Posted August 23, 2010 Posted August 23, 2010 Great timing on this topic for me, as I am trying to find a replacement for my original M/C and not having much luck with the usual spares suppliers (most look at you and reply "a 240 what?"). The patrol M/C might be the best solution, can anyone tell me the model I need to quote? Is it the MQ? Thanks. Quote
C.A.R. Posted August 23, 2010 Posted August 23, 2010 PBR part no. is ' JB1419 ' DO NOT FIT THIS M/C IF YOU HAVE STOCK BRAKES!!! Quote
Gillo Posted August 23, 2010 Posted August 23, 2010 Should have mentioned, this is part of upgrading to hilux calipers as well. Was happy to keep the stock M/C, but as it was getting difficult to source here thought I might as well do the other end as well. Thanks for the warning all the same Quote
nizm0zed Posted August 23, 2010 Posted August 23, 2010 i bought a new 1" master from repco a while ago for $220 For what its worth, after a call from a fellow zed owner i just looked these up. Available through ATAP (Australian Truck and Auto Parts) as a PROTEX brand, they retail for $159 at Any autobarn store + freight if applicable. Application listing is for a 2/77-6/79 60 series patrol. Quote
Riceburner Posted August 23, 2010 Posted August 23, 2010 This may have been answered before so feel free to shoot me down.. Do the brake lines attach to the bottom of this 1" master? I run hilux fronts and r31 rear with 15/16 no problems so far, is this ok/safe or should I upgrade? :-\ Quote
sco_aus Posted August 24, 2010 Posted August 24, 2010 Hey Alan, I'll take one mate, could you order me one in, or do I have to come into the store? Quote
luvdemzeds Posted August 24, 2010 Posted August 24, 2010 Picked up a one inch master cylinder from Auto One for $138 just last week. Hope this helps. Quote
nizm0zed Posted August 24, 2010 Posted August 24, 2010 ahh, i thought you allready had one scott? I can order one in, but i will need a deposit. I dont know when my next ATAP order will be, so either add freight and it'll be within a day or so, or if there is no rush, no freight and it'll probably be a fortnight? Quote
sco_aus Posted August 24, 2010 Posted August 24, 2010 Yeh and then I was a dickhead and sold it thinking I wouldn't use it.. I'll call you at work to sort out the deposit Quote
