Grace75 Posted July 29, 2021 Posted July 29, 2021 Hi, I have a '75 260z 2+2 and I am looking into a points to Fast XR700 electronic ignition conversion, hopefully someone out there can answer a few questions I have. 1> Which model do I purchase, I have narrowed it down to either 700-0231 or 700-0292. 2> Do I need to purchase another coil, currently I have a Bosch GT40R coil connected to the original ballast resistor. 3> Can someone post an image on how they have wired up the system. Regards Kerry Quote
C.A.R. Posted July 29, 2021 Posted July 29, 2021 Fast Ignition = Poor quality, US owned, Chinese made junk. Call Performance Ignition in Melbourne and order a brand new Scorcher Dizzy and coil. https://performanceignition.com.au/p/scorcher Connect two wires up, Time it and forget about it. About $800. gav240z 1 Quote
Agno Posted July 30, 2021 Posted July 30, 2021 I have a rebuilt and recurved 280ZX electronic distributor which was also done by Performance Ignition in Nunawading, from memory it was about $300 odd for the rebuild. I used to have an MSD aftermarket system and the rebuilt dizzy is simpler and works just as well as any aftermarket system. It actually works better than the MSD ever did! Quote
Administrators gav240z Posted July 30, 2021 Administrators Posted July 30, 2021 22 minutes ago, Agno said: I have a rebuilt and recurved 280ZX electronic distributor which was also done by Performance Ignition in Nunawading, from memory it was about $300 odd for the rebuild. I was gonna take my distributor there to recurve it, do you know how much timing they put into yours total? Mine seems to be too aggressive and pings if I open WOT all the way. Quote
krizza Posted July 30, 2021 Posted July 30, 2021 (edited) To answer your question, I have the 700-0231 fitted to my 75 2+2 and it works great. Much better than the Pertronix rubbish it replaced But if you can find a 280zx dizzy that would be a better option imo Edited July 30, 2021 by krizza Quote
Agno Posted July 31, 2021 Posted July 31, 2021 On 7/30/2021 at 3:35 PM, gav240z said: I was gonna take my distributor there to recurve it, do you know how much timing they put into yours total? Mine seems to be too aggressive and pings if I open WOT all the way. I don’t know the figure off the top of my head sorry. It was a good thing I took it in because apparently it was locked up and wouldn’t advance! gav240z 1 Quote
Ponyo240z Posted July 31, 2021 Posted July 31, 2021 On 7/29/2021 at 1:41 PM, Grace75 said: Hi, I have a '75 260z 2+2 and I am looking into a points to Fast XR700 electronic ignition conversion, hopefully someone out there can answer a few questions I have. 1> Which model do I purchase, I have narrowed it down to either 700-0231 or 700-0292. 2> Do I need to purchase another coil, currently I have a Bosch GT40R coil connected to the original ballast resistor. 3> Can someone post an image on how they have wired up the system. Regards Kerry I've fit 2 of these to Minis and never had a problem. Cheap and easy to fit. I do agree with CAF about performance ignition in Melb and if I was doing a full rebuild would spend the extra coin Quote
Grace75 Posted August 1, 2021 Author Posted August 1, 2021 My first choice is for a 280z distributor but the xr700 looks like a easier solution. The scorcher/coil combo is a better option but pricier, then again you get what you pay for. Thx everyone. Quote
peter t Posted September 5, 2021 Posted September 5, 2021 Have used the Fast (Crane) ignition for years and never had a problem. You just have have to get the one to suit the resistor and coil you have. Quote
Grace75 Posted September 5, 2021 Author Posted September 5, 2021 Hi Peter In the end I bought the XR700 (fas700-0231) from Outlaw Speed Shop. Thx Quote
peter t Posted September 6, 2021 Posted September 6, 2021 21 hours ago, Grace75 said: Hi Peter In the end I bought the XR700 (fas700-0231) from Outlaw Speed Shop. Thx Nice Green like mine. Quote
