Tom2305 Posted July 1, 2020 Posted July 1, 2020 (edited) Hi everyone, I am new here I have a 240Z and was looking to do an RB25 conversion, I have done some research but it’s still a bit confusing, does anyone have a list of all the parts I will be needing to convert the RB25 to rear wheel drive and into my 240z. Thanks Edited July 1, 2020 by Tom2305 Quote
GregTas Posted July 1, 2020 Posted July 1, 2020 Hi Tom, Well I've done one, but I would say it's quite a bit more than a list of parts to buy, more a list of things to do, sort out. I'm sure there must be a lot of stuff online that covers it. Engine mounts made my own. I sat a dummy engine and gearbox in place and once where I wanted it worked out the dimensions for them and made them up. I believe it is possible to buy something, but might not get engine exactly where you want it.. Sump: I chopped the bottom off RB sump and made and new one with sump at rear. You can use a patrol RB sump and do it with less work. Gearbox: RB. Need to remove the speed sensor to fit it in the tunnel. Tailshaft: I used skyline shaft. Shortened to one piece. Replaced diff flange with Subaru STI 6 speed diff flange (Not easy to get locally). This flange has the same bolt pattern as Skyline shaft. So it then just bolts up. Radiator: Both fittings on drivers side. Plenum: Used Skyline front throttle body, but had to chop front of and realign it for induction pipe to go out the front. Intercooler: Modified it so pipes go through the air vent holes. Gearbox mount: Mount be able to buy one, but some have said what you can buy is not great. So might be better making your own up. Wiring: Either get a Skyline loom and wire it in. Or better way custom ecu and do your own loom. Time: A lot of it required. Cost: Quite a cost even if doing all the work and fabrication your self. If you have to pay someone to do it and cost is a possible constraint, then probably not something to consider doing. Stick with good L series. How's that for a start. Greg gav240z, Zedhead and JDM-TOY 3 Quote
Tom2305 Posted July 1, 2020 Author Posted July 1, 2020 Thanks Greg, You definitely clarified a lot of things I wasn’t so sure about and by the way your engine looks great Quote
smugley Posted July 2, 2020 Posted July 2, 2020 If you're going to put this on the road you will also have the added cost of getting it Engineered to meet your state's rules . That might also include brake upgrades and passing emissions regulations . gav240z 1 Quote
Administrators gav240z Posted July 2, 2020 Administrators Posted July 2, 2020 I think Castlemaine Road shop offered engine mounts for RB conversions. You'll want a forward facing plenum also. To do away with the over valve cover jobby on the Rb25. Weigh up the cost of conversion vs a Les Collins built L-series. You could make some good power out of an L-series with $15-20k thrown at it. https://www.rodshop.com.au/datsun/240z-260z/em081-nissan-engine-mounts.html Quote
GregTas Posted July 2, 2020 Posted July 2, 2020 3 hours ago, smugley said: If you're going to put this on the road you will also have the added cost of getting it Engineered to meet your state's rules . That might also include brake upgrades and passing emissions regulations . Yes that's definitely worth understanding first because it could add quite a bit more to it and influence plans for the brake and suspension upgrades. Quote
JDM-TOY Posted July 2, 2020 Posted July 2, 2020 You will need the following: Cash, Cash, Cash, Time and More Time. And some hair colour for the whites that will come out half way through the build. Enjoy VID-20190506-WA0001.mp4 Zedhead 1 Quote
Cozza Posted July 2, 2020 Posted July 2, 2020 On 7/1/2020 at 10:26 PM, GregTas said: Hi Tom, Well I've done one, but I would say it's quite a bit more than a list of parts to buy, more a list of things to do, sort out. I'm sure there must be a lot of stuff online that covers it. Engine mounts made my own. I sat a dummy engine and gearbox in place and once where I wanted it worked out the dimensions for them and made them up. I believe it is possible to buy something, but might not get engine exactly where you want it.. Sump: I chopped the bottom off RB sump and made and new one with sump at rear. You can use a patrol RB sump and do it with less work. Gearbox: RB. Need to remove the speed sensor to fit it in the tunnel. Tailshaft: I used skyline shaft. Shortened to one piece. Replaced diff flange with Subaru STI 6 speed diff flange (Not easy to get locally). This flange has the same bolt pattern as Skyline shaft. So it then just bolts up. Radiator: Both fittings on drivers side. Plenum: Used Skyline front throttle body, but had to chop front of and realign it for induction pipe to go out the front. Intercooler: Modified it so pipes go through the air vent holes. Gearbox mount: Mount be able to buy one, but some have said what you can buy is not great. So might be better making your own up. Wiring: Either get a Skyline loom and wire it in. Or better way custom ecu and do your own loom. Time: A lot of it required. Cost: Quite a cost even if doing all the work and fabrication your self. If you have to pay someone to do it and cost is a possible constraint, then probably not something to consider doing. Stick with good L series. How's that for a start. Greg Great write up GregTas and yes a super today engine bay. wheres your battery? looks like there might be an oil catch can in the standard battery location Quote
GregTas Posted July 3, 2020 Posted July 3, 2020 Thanks Mick. Battery is in the boot in a battery box. Back left corner. I could have left it there, but thought better in back for weight distribution. Quote
