  For sale:
  Brand new front & rear King springs  KDRS-09/KDFL-04 code numbers ,lower by 30mm. $220 pls pstge or pick up in Sydney area.
        Regards: Alan.
Have checked out "Kings" catalogue which states KDRS-09 fits rear of 70-79 260Z & also rear of 70-75 240Z however it shows the 240Z as being a standard height set up & a different code for the lower version.
KDFL-04 fits the 70-79 260Z only.
Will contact Kings mon  to seek confirmation that this is all correct. Will save a lot of conjecture methinks.
240's  and Im guessing early 260's use kdrl09 and kdfl08.
To save a lot of guessing have checked out catalogue for correct info, see original post. But will ring "Kings" mon to verify.
                                                          Regards: Alan.
Not sure gareth, my guess is that the 240Z are slightly less in diameter on the front springs & the strength factor different too with the 260Z being heavier. Will know on mon when I talk to "King" technical people. Trying to fathom how the rear lower (30mm) 260Z king spring is only standard for the 240Z .Yet when you use the 240Z top on a rear 260Z it lowers the car up to (50mm), but if you use the same top on the front unit of a 260Z it doesn't alter the hght. All will be revealed I hope.
        Regards: Alan.
The standard 260 2+2 strut tops were significantly thicker than the 240. The front strut tops were the same in the 240, 260 and 280. That's why a 240 rear strut top lowers a 260.
The 240 strut tops are identical front and rear.
            At least you got that right. Your previous post info was for 240Z  70/75 lowrd springs not 260Z.
        Regards: Alan
        Regards: Alan
I said 240!
                                    Yep the 240Z part was correct, but not the 260Z. Will get all the relevent info on mon & post so that there is no confusion.
  As I cant understand how in the catalogue it states that the KDRL-09 lowers the 260Z some 30MM yet it lists it as being a stndrd for the 240Z.
  Got me buggered.
                                                          Regards: Alan
