Hi guys,
I was lubing up my linkages and I think I spilt a little..
I was using one of those multi-use small bottle oils (generall used to lube door hinges).
I fired her up and took her for a spin. My linkages are no longer sticky wooo!
But there is now an awful lot of white smoke rising from the engine bay and exhaust...
Did I do something terribly wrong?? Is my Z going to blow up!?!?!??
Clearly you didn't follow the tutorial on how to lube your linkages...................  ::)
I'd guess you have some oil on your exhaust. Maybe have a look under the bonnet? ???
I think I do have some oil on the exhaust...
What should I do??? It's not a considerable amount...
Should I just smoke it up on the drive to work tomorrow morning??
Just so you know a lot of guys carry fire extinguishers in their zeds.
A fire extinguisher is VERY cheap insurance, has saved me once  ;)
Its just the spilt oil that will burn off after a while. Or just use some hot water and rinse it off..
A man who never made a mistake, never made anything :).
;D
            As long as the white smoke is not coming out of the exhaust pipe . LOL.
                                            Regards: Alan
Very true, so long as mistakes aren't repeated  :)
;D
                                            Regards: Alan
I think it did come out of the exhaust for a little but then disappeared the following day.
So far so good!
