Well, I have been putting this off for far too long now.
Minor leak in what I assume is heater core now no longer minor, need to remove and replace.  Ideally without takibg dash out. Does anyone have experience doing this in a 240?
Curious as to whether i can:
~slide it our driver side without removing while box; or
~ slide whole unit out passenger side or via centre console?
Suggestions appreciated.
Huw
You don't need to take the dash out. Remove the blower unit, disconnect or chop the hoses from RH side - time for new ones anyway; remove heater face plate to disconnect wiring/cables etc, & anything that gets in the way, & slide heater box out on LH side as per Monkey's advice above.
Good to hear - someone had told me plate would come off and could remove with heater unit in situ - but looked like an expletive laden exercise....passenger side makes much more sense.
Hoses and tap are new so I will be gentle on them!
Well - finally got round to it - slid out easily...not looking forward to putting it back in but at least once it is fixed I can do the interior properly! (was too poor as a uni student (when it was first restored)).
Cheers for the help.
Huw
  • 8 months later...
Hi All,
I recently have pulled out the heater core on my 240 as the control valve was leaking and i wanted to check the state of the heater core, sure enough evidence of a minor leak.  The last time i got a heater core refurbished it was around $150 anyone know the rough cost it should be in the Perth region?
Nat Rad have loosely quoted me $250.
Also considering getting new heater core hoses, found a few on ebay in America going to end up been $75 delivered.  The hoses don't look too bad, anyone know how long they usually last?  I would say they have been replaced in the past as the heater core has been done previously.
Hi All,
Unless you want to do it all again, replace the hoses even if they look ok. Who knows when they were last done?
My 72 240z has a minor leak from the heater tap, so I'm going to have to tackle this also. Not sure if RHD and LHD have different hose set ups? Might be worth checking, I assume they are the same between LH and RH drive cars.
In terms of pricing, if you have the part no's that will help. $75 isn't too bad (if includes delivery) but it will take at least 2 weeks shipping from the US unless you ask for express.
I am using 240z heater hoses and heater tap purchased from Z car depot on eBay from USA and work fine on RHD cars. And for the elbow hose i just used a 45 degree bend that i cut off from another hose that i payed $5 for from supercheap auto. I also used high quality clamps and no leaks!
when you buy stuff from z car depot,  go to their website directly and email the guy, I think his name is ryan or something? he will give you a better discount on postage/items cause bypass ebay.
Thanks for the info, funny i actually did buy a new heater control valve off ZCarDepot but Australia Post sent it back to USA claiming an incorrect address, although address was correct.  Ryan and myself still don't know where the hell it is.  Once i sort out the heater valve with Ryan then i might just buy the hoses and firewall gromits off him, i'll go direct instead of Ebay next time.
The hoses are the same between RHD and LHD just a couple of minor changes depending on the year of the car.
  • 5 months later...
Just got a quote to get my heater core done; $260 for a custom core. I was hoping I could get away with a repair but it has to have the core replaced... there's no longer a listing for them and we tried to find a similar sized core but no luck. Anyone else had any luck with heater core replacement for a series 1 240Z?
I'm in the same boat up here in QLD. Recore is cheaper than buying a new one from MSA by nearly half.
Agreed! The guy I went and saw here in Melbourne contacted someone in QLD for the custom core... I think I'm going to go ahead with it as there aren't many other options available. Will let you know the details once I get it back if you like.
260 is a good price !!  Go with that.  I paid 390 for mine to be done
Picked up the new heater core today; very happy with the service and the price - $260 incl. Not sure if anyone needs a new core, they have received two cores by mistake. They'll need your end tanks to complete the heater core.
Contact: Melbourne Wide Auto Radiators
(03) 9459-5924
23 Orr St, West Heidelberg, Vic.
  • 2 months later...
The part number for the 240Z (up to July '73) heater core is 27115-E4400
- according to the "S30 - 240Z-260Z Parts Catalogue Microfiche" CD that I have.
