will give full flo results in the new year. test on inlet port showed 230cfm at28' 550lift with stock valve and ex port 155cfm on the outer ports .it will be a grate head. these figures were with standard Gide's new ones are much nicer as they are 8mm shorter and tappered
arrr this head will be the last datsun 6 head as they take me close to 40hours in the ports alone and then i have to set the springs and cam up the head will end up costing me more than i can charge.the same head from japan costs $5000 with cam and springs.
  • 2 weeks later...
Nice work Peter, was looking for you at the BBQ on Friday night.
Dont forget, you have a 2.6 rebuild waiting, a deals a deal........LOL
By the way that nose is going into production soon.
John
My bottom end is assembled, still waiting on the headers ??? I' running flat tops and they had to deck the block, so I have about .25mm positive deck height. Should be fine by the looks of those bad boys Peter  :o
