1,000 -
54
Everything posted by AndBir
AndBir replied to gav240z's topic in Cars For Sale
1972 Datsun 240Z $53,000.00 Peakhurst, NSW. Clean original 240Z with 40 years of receipts. -
Incar video (not the best quality) from one of the Zeds :
Certainly looks like it is from a 2+2
1976 260Z 2 Seater (AUTO) 1976 Datsun 260Z Coupe $34,500.00 A very good example of a 1976 Datsun 260Z 2 seater auto with factory air conditioning in sterling silver with black interior & matching numbers. STRICTLY NO SCAMMER'S !! ! -
I missed getting there to see the rally, looks like it would have been challenging road conditions at times :
Any photos of the extractors if they are still available?
Yes, the POR-15 seems temperamental of put on too thickly or too soon on top of the first coat (I waited the 3+ hours and did the fingernail test as outlined in the instructions) - hard to stop it accumulating in low points. I see I have some rust on the pedal box - I assume it is due to hydraulic fluid removing the paint?
Cleaned up the areas under the front fenders/mudguards : : removed the remains of the ?foam? rubber along the seam : Minor surface rust, not sure why they did not fill the corner openings hera with seam sealer? : More surface rust : appears they had to use a hammer a couple of time to get the internal frame parts to match up prior to welding!
Wanted to see some improvements so decided to replace the cover on the driver's seat. : Seat foam looked OK other than a small tear on the edge : Off with the old and on with the new. The process of removing the old cover and installing the new on the seat is relatively painless, looking at the seat back I am sure it will be much more difficult!
Continued on with looking for rust, took off the front fenders: : Uncovered more spider habitats. : Some dirt and, : Some surface rust : A lot of dirt in the bottom of the panel : More dirt build up at the bottom of the panel : luckily not too much rust under all of the dirt
Had to evict some of the spiders today, big black "house" spiders as well as a couple of Redbacks on the underside of the bonnet. : Moved onto the the front cowl and uncovered a lot of surface rust. : Then looked at the battery area/support - lots of dirt and again rust underneath but it appears to not be too bad. : Got stuck into it with a wire wheel on a drill and a screw driver to chisel the had to reach areas. Did the Marine Clean - Metal Ready - POR-15 treatment. : Took the bob tail spoiler of to check what the panel looked like underneath and as you can see the paint not covered by the bob tail spoiler has deteriorated (probably just the undercoat now) markedly.
Well spotted, I was told the spacers came originally under the bracket the seat frame mounts onto - luckily my brother in law is not tall and he had to move them to be on top of the bracket to get the extra seat height.
Thanks Peter, I will heed your advice. I was concerned about the brass nozzle falling off the end, not the whole tube! For those that do not suffer from arachnophobia - the inside of the dogleg on the passenger side was interesting :
Thanks for all the advice re rust prevention etc. Well, I finally got the courage up to start stripping out the interior to see what nasties were hidden under the floor coverings and side trims. All I can say is that, based on what you normally see posted here regards rust etc. that it is a miracle that (so far) this car has not given any really nasty surprises - but still a way to go. First was removing the driver's seat and then carpet and jute : Found some rust spots under the kick plate but behind and under the seat areas was OK. Areas on the floor not covered by the tar sound deadener have minor surface rust. After slowly peeling off the side carpet trim which was attached by some sort of light glue, it appears all is OK in the door sill area. Looking into the upper dog leg area all appears good. Poking the iPhone camera in as far as it can go to look lower down I am not really sure what I see - some "black" seam sealer and some sprayed on ?something? Interestingly the underside of the driver's and passenger seats appear to be OK Second came the passenger side seat and floor coverings. Again behind and under the seat area was great In front of the seat the original carpet was in OK condition on the surface and even still had the clips to keep it in place. Side and end panel trim in OK condition as is the diamond pattern tunnel covering. Under the coverings no sign of rust however the picture hides the fact the middle of the passenger floor has been pushed up by ~2-3cms I had not had a good look at the rear hatch slam panel(?) before now but it looks OK as well. Took the rear bumper bar off and you can clearly see what 42 years of sun did to the paint. Purchased some new 260z style seat covers from the ZFactory and will attempt to fit these:
Also appeared (briefly) on Gumtree today
Datsun 260Z 2 seater for sale $8,000.00 Baulkham Hills http://www.gumtree.com.au/s-ad/baulkham-hills/cars-vans-utes/datsun-260z-2-seater-for-sale/1127410412 Selling my project car - a 2 seater Z! Comes with RB20det engine and gearbox Including exhaust, radiator, intercollegiate and piping. All parts are there. I recently purchase some new front wheel guards that are in great condition, also have other spare body parts. Some other spares purchased too. The car requires some bodywork. There is too much to list on here, if you have any questions txt or call. Serious buyers only $8000 firm not negotiable -
1974 Datsun 260Z Coupe $34,000.00 O'Connor, ACT http://www.gumtree.com.au/s-ad/o-connor/cars-vans-utes/1974-datsun-260z-coupe/1127317050 2 seater. Modified. Perfect condition. Nissan VG30DET, 3 litre, V6 24 valve, quad cam, intercooled single garret turbo delivering 242KW at back wheels. Haltech E11V2 Autospec CMS. 300Z gearbox, New R200 differential. Modified for touring. Quiet, insulated cabin, Saas seats, A/C. All round adjustable suspension. Sway bar. 4 spot caliper front brakes. New paint (no rust), new windscreen, new dash, simmons mags, new tyres, new BC coilover shocks, new lower control arms, new fuel pump, water pump, thermostat. Engineers report. Virtually everything has been replaced and upgraded. Complete spare motor. For complete details call Nigel -
AndBir replied to XRQTR's topic in Parts and Tools for Sale
Parts in Perth from 260z 2+2 (also includes "Z" and "Datsun" emblems.) Car parts for datsun 260z please text for info $50.00 Negotiable http://www.gumtree.com.au/s-ad/south-guildford/wrecking/car-parts-for-datsun-260z-please-text-for-info/1127015809 -
260z 2 seater fuel tank : Starting Bid = $50 http://www.ebay.com.au/itm/260z-2-seater-fuel-tank-/262663772004?hash=item3d27fb1764:g:JMIAAOSwTA9X7xP~ 1976 260z 2 seater fuel tank, no rust , has a sizeable dent that could possibly be popped out, no leaks, comes with sender. Pickup only gippsland victoria -
I forgot to add the text but as you say the pics are what matters - it looks like the advert was only up for about 5 hours. -
1975 Datsun 260Z Coupe $35,000.00 http://www.gumtree.com.au/s-ad/cradoc/cars-vans-utes/1975-datsun-260z-coupe/1125977023 (no longer shows up on Gumtree - indicates SOLD?) -
Maybe try : http://www.viczcar.com/forum/topic/15391-260z-22-parts-wrecking-2-cars/?do=findComment&comment=183631
280zx parts for sale (in Perth) : Various parts. Was going to start a restore but had a motorbike accident and now I need to be restored. Take all $500 ono http://www.gumtree.com.au/s-ad/willetton/wrecking/nissan-datsan-zx-1980-random-parts/1121476378 -
Yep, I think this is the approach I will take. It should be an interesting learning experience!
