297 -
1
Everything posted by HKSZ
Just watching rage, MGMT cool song no.2 has a sweet 260z in it. Not a great song but got to see some booby too so all good. should be on youtube. I'm starting to feel like a rock star
Do you know why the head came off?
Thanks guys, I mulled over this motor all day,Nate your right about the extended pickup it's no easy cut and shut the inside of a Zed pan gives hardly any clearance. If I'm right the middle pickup is the start of the oil gallery, Its already drilled to the right depth just needs the hole bored out to reveal side gallery, so line will go middle pickup to front pickup to oil pump then on to filter and oil circuit? If its a straight line between middle and front pickups surely I'll have a good chance of catching the swarf.
I've got a 240z rear sump and pickup to go on. Front pickup has deeper hole, guessing the rear is still blocked Can some one tell me what has to be done now. thanks Steve
When I bought this 2.4 out of a skyline the fact it had two dipstick tubes made me think it had to be a 240z block first. This is what i found with the sump off, the middle oil boss has a hole which tapers and no bolt holes for the oil pickup
You can always get your chokes milled out to 36
EFI to Carb, missing, spluttering and just not running right.
HKSZ replied to BatmansDatsun's topic in Engine
I think its spark, put a timing light on every lead and see if you get a constant flash -
You have to have the right pressure for sure, but even if you turn the pump offcarb will have enough fuel to run properly for 10sec or so. If carb was run on LPG more than likey it needs a rebuild kit, plungers in carb dry up -
I am tempted to change the sump and put it in the rally car now, current motor is standard l28 f54 p90a with triple 40's and I've been collecting data on the G-tech
some times you can have a win on ebay $151. Yeah it's bloody clean compared to the head sitting next to it. Going off the Crow website 58 721 is medium street $405 IN open 39 IN close 73 Valve lift 0.495 EX open 75 EX close 37 Valve lift 0.495 IN duration 225 @ 0.050 Advertised 292 Ex duration 225 @ 0.050 Advertised 292 I'd love to know where it sits to say a works cam 74 76?
Its front sumped but has front and rear dipstick holders in place making me think this was a 240z motor originally
Bought this L24 off ebay untested a few years back. told it came out of a skyline rally car and went really hard (like every 2nd motor does!) I only bought because I stagged it cheap and figured I could atleast use the 133 rods and SU's Observed it had 2'' british SU's a big 2 1/2 exhaust, took the cover off the cam has a purple mark and on the back it's stamped 212 721 and crow. think the towers are shimmed and maybe the springs too. Hard to tell maybe the pistons are domed. Does it look like the head has been worked? small E88 head ports are 34.8 28.2
Same as a manual x mem aren't they? even 260z 280zx are the same part
Front Brake Caliper Rebuild Question
HKSZ replied to Cozza's topic in Brakes / Drivetrain Components
I've got a set of these spaced out calipers in the shed, the spacer being alloy but think the matching discs are peugeot -
it will be fine, thats all i use on my L28 rally car with 40mm webers
Thanks again Jason, I picked it up a couple of years back for $600 on ebay so started thinking maybe it was viscous. I'm putting it into my rally car, currently run a R180 4.8 Nismo which is the cats pyjamas on dirt but would like to try 4.4 cut down some wheel spin and more top end speed. Got a local autocross in a couple of weeks so that will give some comparison, but yeah 50lbs dosen't sound impressive Steve
Opened up the back, definately a 4.4 and all the teeth in good nick. Can anyone confirm it looks like a clutch LSD or Viscous? Steve
Thanks, Lightweight it is then
Which Redline suits a zed rally close ratio box Heavy Shockproof or Lightweight shockproof?
Thanks every one i'm going to get on and put this diff in the car You're kidding right? Isn't it just one nut up the center line? Yeah, no I've done plenty of pinion seal replacements, don't have to worry about torque just punch mark shaft and nut then count turns out, it's adding a foreign part even to factory torque may not be the same load I had before I'll have to look into getting one of your conversions cause it dosen't sound like this diff is going to be as good as the Stan holmes one I'm pulling out Steve
Thanks for all the reply guys, just took another look I'd have to swap yokes as this one is rectangle so no meat to redrill. I haven't changed yokes between two diffs before, I'll need a diff mechanic to change it Jason I'm not even sure if its clutch or viscous, any easy way to tell?
I've got a long nose r200 4.4 lsd, about to fit in my 240z but the yoke has a bigger bolt spacing what do I?
